I’ve not been very good at keeping up to date with latest developments and was hoping someone could take a moment to point me to an explanation or discussion regarding moving from core to scale?
I’m currently running TrueNAS-13.0-U6.8 and that is fully up to date, but my son keeps asking me if I can set up a minecraft server. From my initial (somewhat poor I guess) research I seem to need to migrate from CORE to SCALE and then would have access to apps for such things. THis would also allow to so start playing with home assistant, although I still haven’t decided if that may be better just set up independently.
Is this migration straight forward? I’m currently only using file storage and a plex server but I’m treading water a little when it comes to understanding jails etc…but again, would be happy to put in some time learning as I really want to start taking ownership of my tech and in particular help my kids to understand and encourage investigation/ tweaking/ device hacking as their interests develop.
It’s probably a big ask, but if anyone can suggest some guidance on this it would be appreciated as I tend to get a bit overwhelmed when trying to learn new things.
Start by looking at the Online Docs and see if there is anything that may cause issues. Legacy GELI encryption would be one.
If you have just data and are willing to set up Plex fresh, your setup seem pretty straightforward to move to Scale / CE.
I would suggest seting up a VM or a test server with 25.10.8 and get a feel for the changes. You will have to decide between attempting to upgrade through multiple versions of Scale or do a fresh install of Scale, importing your pools and doing cleanup of issues like permissions, smb sharing, etc. I would say fresh install and just getting used to the way Scale is currently doing this would be best.
I’m running the same version as you do for now, and I was running HA in a VM (still do), so that it keeps it safe and upgradable. I will eventually migrate to Scale when i have a separate off site backup with the data…until then FreeBSD for life
Hi there. I just wanted to drop a quick note to thank you all for your comments. I’ve been a little unwell and so this hasn’t been top of my to-do list just yet, but I wanted to let you know your replies are appreciated and I’m have a good read through the documentation as suggested. Thanks again
This has been mentioned in other topics before, but here again:
If you’re interested in virtualisation, the latest version of vanilla FreeBSD (15.1 at the time of writing) with Sylve is worth checking out. I migrated some machines and it’s almost perfect. (NFS management isn’t included, yet. But it’s easy to do from the CLI.) ZFS 2.4.x is supported. There are easy upgrade paths. daemonless is there, etc.
