There is this new issue that started just last night. My network realtek network card on the Asus Z87-A Motherboard suddenly kept connecting and disconnecting repeatedly, and I didn’t understand what was happening and had lost remote control of the TrueNAS Server. I tried to plug a screen into it but didn’t get a video out. My last resort, which isn’t my favorite, was to tap the power button on the case that the server lived in. I powered it up again and the network connection had been restored thankfully. Later that night I had taken a USB PCI card out, but thought that I may need it so I tried reinstalling it into the server, and noticed I was having a connection refuse error regarding the Battery Backup for the server, I then thought maybe the USB card was causing and issue and I removed it once again, but the issue persisted. Then I read about restarting the UPS service, and now I have to keep stopping and starting the service for the UPS every time TrueNAS Core finishes starting up. I do have a backup of my TrueNAS Core Config from the last time TrueNAS had an update, and I was wondering if it’d be a good idea to reupload that config to the server and see if it fixes whatever errors I may have accidently caused my server. I wanted to ask before I did any more to it. Please let me know and thank you!
Example of current errors I am getting.
I am also using a Cyber Power 1350AVRLCD, which has worked just fine until all this strangeness.
Feb 12 15:58:58 blackbear 1 2025-02-12T15:58:58.943761-05:00 blackbear.local upsmon 1848 - - Communications with UPS ups@localhost:3493 established
Feb 12 15:59:07 blackbear 1 2025-02-12T15:59:07.734325-05:00 blackbear.local upsd 1839 - - mainloop: Interrupted system call
Feb 12 15:59:12 blackbear 1 2025-02-12T15:59:12.073774-05:00 blackbear.local upsmon 1847 - - upsmon parent: read
Feb 12 16:00:43 blackbear 1 2025-02-12T16:00:43.180723-05:00 blackbear.local upsd 2398 - - Data for UPS [ups] is stale - check driver
Feb 12 16:00:45 blackbear 1 2025-02-12T16:00:45.201858-05:00 blackbear.local upsd 2398 - - UPS [ups] data is no longer stale
Feb 12 16:02:07 blackbear 1 2025-02-12T16:02:07.893817-05:00 blackbear.local upsd 2398 - - Data for UPS [ups] is stale - check driver
Feb 12 16:02:12 blackbear 1 2025-02-12T16:02:12.732262-05:00 blackbear.local upsmon 2407 - - Poll UPS [ups@localhost:3493] failed - Data stale
Feb 12 16:02:12 blackbear 1 2025-02-12T16:02:12.732276-05:00 blackbear.local upsmon 2407 - - Communications with UPS ups@localhost:3493 lost
Feb 12 16:02:12 blackbear 1 2025-02-12T16:02:12.758724-05:00 blackbear.local collectd 2473 - - nut plugin: nut_read: upscli_list_start (ups) failed: Data stale
EDIT: I went ahead and reloaded the config that was last known good, the server seems to be ok for now. But I’d like to understand still what this error means for future troubleshooting. So please educate me! Thank you.
EDIT 2: I am still having issues with this stupid error. I’ll state again, I am using a Cyber Power 1350AVRLCD. Can someone please help me with this because I don’t want to be dealing with this issue. It’s honestly starting to piss me off now.
Feb 12 18:03:23 truenas 1 2025-02-12T18:03:23.662789-05:00 blackbear.local upsmon 2206 - - Communications with UPS ups@localhost:3493 established
Feb 12 18:03:58 truenas 1 2025-02-12T18:03:58.409751-05:00 blackbear.local upsd 2197 - - Data for UPS [ups] is stale - check driver
Feb 12 18:03:58 truenas 1 2025-02-12T18:03:58.956774-05:00 blackbear.local upsmon 2206 - - Poll UPS [ups@localhost:3493] failed - Data stale
Feb 12 18:03:58 truenas 1 2025-02-12T18:03:58.956792-05:00 blackbear.local upsmon 2206 - - Communications with UPS ups@localhost:3493 lost
Feb 12 18:04:00 truenas 1 2025-02-12T18:04:00.237328-05:00 blackbear.local upsd 2197 - - UPS [ups] data is no longer stale
Feb 12 18:04:03 truenas 1 2025-02-12T18:04:03.959293-05:00 blackbear.local upsmon 2206 - - Communications with UPS ups@localhost:3493 established
Feb 12 18:04:18 truenas 1 2025-02-12T18:04:18.469845-05:00 blackbear.local upsd 2197 - - Data for UPS [ups] is stale - check driver
Feb 12 18:04:18 truenas 1 2025-02-12T18:04:18.982783-05:00 blackbear.local upsmon 2206 - - Poll UPS [ups@localhost:3493] failed - Data stale
Feb 12 18:04:18 truenas 1 2025-02-12T18:04:18.982801-05:00 blackbear.local upsmon 2206 - - Communications with UPS ups@localhost:3493 lost
Feb 12 18:04:24 truenas 1 2025-02-12T18:04:24.054778-05:00 blackbear.local upsmon 2206 - - Poll UPS [ups@localhost:3493] failed - Data stale
Feb 12 18:04:28 truenas 1 2025-02-12T18:04:28.256829-05:00 blackbear.local collectd 2439 - - nut plugin: nut_read: upscli_list_start (ups) failed: Data stale
Feb 12 18:04:29 truenas 1 2025-02-12T18:04:29.056756-05:00 blackbear.local upsmon 2206 - - Poll UPS [ups@localhost:3493] failed - Data stale
Feb 12 18:04:30 truenas 1 2025-02-12T18:04:30.573343-05:00 blackbear.local upsd 2197 - - UPS [ups] data is no longer stale
Feb 12 18:04:34 truenas 1 2025-02-12T18:04:34.058767-05:00 blackbear.local upsmon 2206 - - Communications with UPS ups@localhost:3493 established
EDIT 3: additional errors after I turned off the service for UPS.
Feb 12 18:09:38 truenas 1 2025-02-12T18:09:38.489209-05:00 blackbear.local collectd 3944 - - nut plugin: nut_connect: upscli_connect (localhost, 3493) failed: Connection failure: Connection refused
Feb 12 18:09:58 truenas 1 2025-02-12T18:09:58.358809-05:00 blackbear.local collectd 3944 - - nut plugin: nut_connect: upscli_connect (localhost, 3493) failed: Connection failure: Connection refused
Feb 12 18:10:38 truenas 1 2025-02-12T18:10:38.409754-05:00 blackbear.local collectd 3944 - - nut plugin: nut_connect: upscli_connect (localhost, 3493) failed: Connection failure: Connection refused
Feb 12 18:11:58 truenas 1 2025-02-12T18:11:58.363482-05:00 blackbear.local collectd 3944 - - nut plugin: nut_connect: upscli_connect (localhost, 3493) failed: Connection failure: Connection refused
Feb 12 18:14:38 truenas 1 2025-02-12T18:14:38.434157-05:00 blackbear.local collectd 3944 - - nut plugin: nut_connect: upscli_connect (localhost, 3493) failed: Connection failure: Connection refused
And now for some really odd reason, Services is using all of my system Ram. Do I need to reinstall TrueNAS Core and then reupload my config? I feel like some horrible has gone wrong.
