USB passthrough of Yubikey to LXC containers doesn't seem to work
Has anyone successfully passed through a Yubikey to an LXC container in CE 25.10.7? I can see the Yubikey inside the container with lsusb -tv, but ykman info says it got access refused when it tried to access the Yubikey. Doing some research, it appears I need to pass the device through to Incus as a unix-char or unix-hotplug device instead of just USB, but these options aren’t available in the UI.
if it’s not available via gui you may be able to edit the incus lxc config file and directly add it there…
like this
