i tried to enable the SMB to access from windowz and i get this… but in the shell i see data… omg i had given up hope…
Click on EDIT for the SMB share and verify the path is valid. Uppercase, lowercase, spaces, all those things are important in Linux.
Do you have a pool called “VMData” ? If you are in the shell and in the directory where the files are located, type pwd
to see the full path.
admin@truenasvm[~]$ cd …
admin@truenasvm[/home]$ cd …
admin@truenasvm[/]$ cd …
admin@truenasvm[/]$ ls
audit bin boot conf data dev etc home initrd.img initrd.img.old lib lib32 lib64 libx32 media mnt opt packages proc root run sbin srv sys tmp usr var vmlinuz vmlinuz.old
admin@truenasvm[/]$ cd mnt
admin@truenasvm[/mnt]$ ls
VMData VMData2
admin@truenasvm[/mnt]$ cd VMData
admin@truenasvm[/mnt/VMData]$ ls
ix-applications vmroot
admin@truenasvm[/mnt/VMData]$ cd vmroot
admin@truenasvm[/mnt/VMData/vmroot]$ ls
‘7 Days To Die ExistentialEgg_A21Fix.xpadderprofile’ ‘Build Projects’ Gaming ‘Old Windows 2019 Server Desktop’ Prvate Work
‘Animation Resources’ ‘Client Info’ GoToAssist_Remote_Support_Unattended.msi PAOmar ‘Samsung SSD 850 EVO 1TB_full_b3_s1_v1.tib’ animation
Backups Clients Labels ‘Personal Data’ ‘Untitled Document’ ‘cds pelican.pdf’
Basement Ebooks ‘Movie Encoding’ Projects Vintage ‘for sale’
still no joy
What is output of df -T /mnt/VMData/vmroot
Its ok i got it… im using MC to copy the data from one pool to another that has SMB working then im going to copy to another TrueNas Server i have and make sure i setup offsite backups for 13TB if Data im not going to be in thi situation ever again and as they say in IT if your data is not written in three places its nowhere…
didnt realise MC was in TrueNas Scale…
I want to thank everyone for their help this has been a learning curce for me and i wont for get this… also i will be bouncing this truenas server and then be looking for advice on setup… using the mirrors as suggested.
Thank you all so much…
Eugenio Steele from Plan-Net CSS Canada
Did you import this pool through our UI or through shell? If it’s a totally unexpected pool (not imported the proper way), then we won’t allow you to share it out.
This topic appears to be an off-shot of this:
yes its is sorry…
oh the days of chat and send on the old BBS’s
