Hi all,
I’m trying to configure a Vertiv Liebert PSI5 UPS on TrueNAS SCALE 25.10.4. My question is this:
Has anyone successfully configured a Vertiv Liebert PSI5 (USB ID 10af:0002) with TrueNAS SCALE 25.10.x?
Environment
UPS: Vertiv Liebert PSI5
USB Vendor/Product ID: 10af:0002
Driver selected in the UI: Liebert ups 2 PowerSure PSA USB (usbhid-ups)
Port:
auto
Symptoms
The UPS is detected by Linux:
lsusb -vreports:-
Manufacturer: Vertiv Co.
Product: Liebert PSI5
Vendor/Product: 10af:0002
However: ‘upscale ups’ returns ‘Error: Driver not connected’
Running the driver manually as root: ‘sudo /lib/nut/usbhid-ups -a ups -DD’ produces:
Checking device 1 of 6 (10AF/0002)
Failed to open device (10AF/0002), skipping:
Access denied (insufficient permissions)
I have already verified usb cable is good. UPS works correctly when connected to a Mac. Linux detects the UPS. And, ups.conf is:
driver = usbhid-ups
port = auto
midclt call ups.configreports the expected configuration. -
upsdandupsmonare running. -
usbhid-upsimmediately exits.
Additional observations
The shipped NUT udev rules contain entries for:
10af:0001 -
10af:0004 -
10af:0008
>>>>but not for 10af:0002.
I also tested changing permissions on /dev/hidraw0 and /dev/hidraw1 (temporarily) and it did not change the behavior.
Thanks!
