I would like to have sdd take over for sde, which I would like to discard. These drives are rather old drives, and this is a practice environment. My server only has four bays, and as can be seen above, they are all occupied.
I’m not 100 % sure where you hang, can’t you select the spare as a replacement disk?
As of now the drive has not faulted, hence the spare did not automatically take over.
What errors does it display? If it’s old and you want to replace it anyway you can ahead. Otherwise some CRC errors may indicate an issue with cabling or power.
I am surprised that you are using an L2ARC for only 4TB of disk - we do not know how much memory your system has, but I would be surprised if it has a positive impact on your performance.
My own advice (and see standard disclaimer) would be to:
Remove the cache from this pool;
Swap sdd for sde as you suggest; and
Replace both sdb and sde with new SATA disks (of whatever capacity you fancy) and add them to your pool as a new mirror vDev.
In terms of what has already happened, as @chuck32 has said, sde has not actually errored because if it had then sdd would already have been resilvered.
Run zpool status from the shell and copy and paste the results here.
Check your alerts and see when the errors happened and what errors they were.
Do you run regular Scrubs and if so when was the last?
Running a new scrub might be a good idea but we need more info I think.
What were the last SMART results for sde?
It might be appropriate to run a SMART long test on sde - again we need more info.
Once we have more info you can decide whether these errors were temporary or not and whether changing the drive is necessary or advisory. It might simply be sufficient to clear the errors.
I was unaware of the fact that the swap-out can happen automatically. Since this system is one I am playing around with to learn about how TrueNAS behaves, I will just let that happen.
The system is a Supermicro SuperServer 6018U-TRT4+ system I picked up from eBay for very cheap. Before receiving and installing the 12-TB drives I now have, I wanted to see how it all works. The server is equipped with 64 GB or RAM:
Based on that, there’s no obvious use case for a L2ARC, and definitely not enough RAM to support 1 TB of L2ARC.
I’m also surprised this was set up as a 2-way mirror with spare rather than directly as 3-way mirror.
I would take the jump and say the drive needs replacement. You can still post the output requested by @joeschmuck but I would assume the result will still be, that we’d recommend a replacement.
@DominikHoffmann You have shown us two completely different error messages, each for two different drives.
What version of TrueNAS are you running? I will assume some variant of SCALE.
In the GUI, Left side, System Settings - > Shell
You should have a shell window.
Type zpool status -v and post the results. That will address the drive sde message.
Type smartctl -x /dev/sde and post the results. That will take care of sde drive issues.
Type smartctl -x /dev/sda and post the results. That will take care of the CRITICAL errors messages you posted.
Do not confuse zpool errors with drive errors. Drive errors may cause zpool errors, however an unstable system or improper shutdown can as well. You have not provided the correct information yet.
However, you can replace the drive sde within the pool if you desire, no harm there however it may not be required. The data will help determine what is going on.
@DominikHoffmann As Joe has pointed out you have two completely separate issues which presumably happened at two separate times. In your first information, sda was ONLINE and now it is OFFLINE. Clearly something else happened in between.
To have a hope of diagnosing these we need the info Joe asked for collected at the same time i.e. the same error state.
P.S. I would also like to add a plaudit and send you an (imaginary) Certificate of Excellence in Advanced Common Sense for spending the time playing before you commit your data to your NAS.
With hindsight I was in too much of a hurry with mine - although I am still pretty happy with my choices (though with hindsight I would have done a RAIDZ2 rather than a RAIDZ1 across my 5 drives), I wish I had taken the time to e.g. pull out a drive and corrupt the data so that I could see how to recover from a (virtual) dead drive. But with data on it, I am not going to play around and risk losing the data.
What are you going to look for in the output of those two commands?
Output of zpool status -v:
pool: Time Machine Trial
state: ONLINE
status: One or more devices has experienced an unrecoverable error. An
attempt was made to correct the error. Applications are unaffected.
see: https://openzfs.github.io/openzfs-docs/msg/ZFS-8000-9P
scan: resilvered 2.02G in 00:01:12 with 0 errors on Thu May 9 11:54:36 2024
NAME STATE READ WRITE CKSUM
Time Machine Trial ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
bee99e48-08fa-41d1-8a58-1af466b76587 ONLINE 0 0 2
f2fa3e44-5d72-4c39-b21d-5ef168fc3cdb ONLINE 0 0 0
cache
763ec928-2c91-4ef3-9674-8c5e61112d49 ONLINE 0 0 0
spares
4d1ec5f1-8f3a-4f97-a5f7-7f36fb3aad17 AVAIL
errors: No known data errors
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:21 with 0 errors on Thu May 9 15:15:42 2024
boot-pool ONLINE 0 0 0
sdc3 ONLINE 0 0 0
Output of smartctl -x /dev/sde :
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.6.20-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family: Hitachi Deskstar 7K2000
Device Model: Hitachi HDS722020ALA330
Serial Number: JK11D1YAKWB2VZ
LU WWN Device Id: 5 000cca 221f6b62b
Firmware Version: JKAOA3MA
User Capacity: 2,000,398,934,016 bytes [2.00 TB]
Sector Size: 512 bytes logical/physical
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: In smartctl database 7.3/5528
ATA Version is: ATA8-ACS T13/1699-D revision 4
SATA Version is: SATA 2.6, 3.0 Gb/s
Local Time is: Mon May 13 12:43:19 2024 EDT
SMART support is: Enabled
AAM feature is: Unavailable
APM feature is: Disabled
Rd look-ahead is: Enabled
Write cache is: Enabled
DSN feature is: Unavailable
ATA Security is: Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status: (0x84) Offline data collection activity
was suspended by an interrupting command from host.
been run.
data collection: (21889) seconds.
capabilities: (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 365) minutes.
SCT capabilities: (0x003d) SCT Status supported.
SCT Data Table supported.
ID# ATTRIBUTE_NAME FLAGS VALUE WORST THRESH FAIL RAW_VALUE
1 Raw_Read_Error_Rate PO-R-- 100 100 016 - 0
2 Throughput_Performance P-S--- 133 133 054 - 99
3 Spin_Up_Time POS--- 121 121 024 - 636 (Average 554)
4 Start_Stop_Count -O--C- 100 100 000 - 927
5 Reallocated_Sector_Ct PO--CK 100 100 005 - 2
7 Seek_Error_Rate PO-R-- 100 100 067 - 0
8 Seek_Time_Performance P-S--- 121 121 020 - 35
9 Power_On_Hours -O--C- 099 099 000 - 11514
10 Spin_Retry_Count PO--C- 100 100 060 - 0
12 Power_Cycle_Count -O--CK 100 100 000 - 22
192 Power-Off_Retract_Count -O--CK 099 099 000 - 1221
193 Load_Cycle_Count -O--C- 099 099 000 - 1221
194 Temperature_Celsius -O---- 142 142 000 - 42 (Min/Max 21/59)
196 Reallocated_Event_Count -O--CK 100 100 000 - 2
197 Current_Pending_Sector -O---K 100 100 000 - 0
198 Offline_Uncorrectable ---R-- 100 100 000 - 0
199 UDMA_CRC_Error_Count -O-R-- 200 200 000 - 18
||||||_ K auto-keep
|||||__ C event count
||||___ R error rate
|||____ S speed/performance
||_____ O updated online
|______ P prefailure warning
General Purpose Log Directory Version 1
SMART Log Directory Version 1 [multi-sector log support]
Address Access R/W Size Description
0x00 GPL,SL R/O 1 Log Directory
0x01 SL R/O 1 Summary SMART error log
0x03 GPL R/O 1 Ext. Comprehensive SMART error log
0x04 GPL R/O 7 Device Statistics log
0x06 SL R/O 1 SMART self-test log
0x07 GPL R/O 1 Extended self-test log
0x09 SL R/W 1 Selective self-test log
0x10 GPL R/O 1 NCQ Command Error log
0x11 GPL R/O 1 SATA Phy Event Counters log
0x20 GPL R/O 1 Streaming performance log
0x21 GPL R/O 1 Write stream error log
0x22 GPL R/O 1 Read stream error log
0x80-0x9f GPL,SL R/W 16 Host vendor specific log
0xe0 GPL,SL R/W 1 SCT Command/Status
0xe1 GPL,SL R/W 1 SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 0 (1 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
SCT Status Version: 3
SCT Version (vendor specific): 256 (0x0100)
Device State: SMART Off-line Data Collection executing in background (4)
Current Temperature: 43 Celsius
Power Cycle Min/Max Temperature: 28/45 Celsius
Lifetime Min/Max Temperature: 21/59 Celsius
Under/Over Temperature Limit Count: 0/0
SCT Temperature History Version: 2
Temperature Sampling Period: 1 minute
Temperature Logging Interval: 1 minute
Min/Max recommended Temperature: 0/60 Celsius
Min/Max Temperature Limit: -40/70 Celsius
Temperature History Size (Index): 128 (32)
Index Estimated Time Temperature Celsius
33 2024-05-13 10:36 43 ************************
... ..( 2 skipped). .. ************************
36 2024-05-13 10:39 43 ************************
37 2024-05-13 10:40 44 *************************
38 2024-05-13 10:41 43 ************************
... ..( 30 skipped). .. ************************
69 2024-05-13 11:12 43 ************************
70 2024-05-13 11:13 44 *************************
... ..( 6 skipped). .. *************************
77 2024-05-13 11:20 44 *************************
78 2024-05-13 11:21 43 ************************
... ..( 14 skipped). .. ************************
93 2024-05-13 11:36 43 ************************
94 2024-05-13 11:37 44 *************************
... ..( 2 skipped). .. *************************
97 2024-05-13 11:40 44 *************************
98 2024-05-13 11:41 43 ************************
... ..( 19 skipped). .. ************************
118 2024-05-13 12:01 43 ************************
119 2024-05-13 12:02 42 ***********************
120 2024-05-13 12:03 43 ************************
... ..( 17 skipped). .. ************************
10 2024-05-13 12:21 43 ************************
11 2024-05-13 12:22 44 *************************
12 2024-05-13 12:23 44 *************************
13 2024-05-13 12:24 43 ************************
... ..( 18 skipped). .. ************************
32 2024-05-13 12:43 43 ************************
SCT Error Recovery Control:
Read: Disabled
Write: Disabled
Device Statistics (GP Log 0x04)
Page Offset Size Value Flags Description
0x01 ===== = = === == General Statistics (rev 1) ==
0x01 0x008 4 22 --- Lifetime Power-On Resets
0x01 0x010 4 11514 --- Power-on Hours
0x01 0x018 6 15438536290 --- Logical Sectors Written
0x01 0x020 6 49269477 --- Number of Write Commands
0x01 0x028 6 1240225687546 --- Logical Sectors Read
0x01 0x030 6 56751045 --- Number of Read Commands
0x03 ===== = = === == Rotating Media Statistics (rev 1) ==
0x03 0x008 4 10579 --- Spindle Motor Power-on Hours
0x03 0x010 4 10579 --- Head Flying Hours
0x03 0x018 4 1221 --- Head Load Events
0x03 0x020 4 2 --- Number of Reallocated Logical Sectors
0x03 0x028 4 67 --- Read Recovery Attempts
0x03 0x030 4 0 --- Number of Mechanical Start Failures
0x04 ===== = = === == General Errors Statistics (rev 1) ==
0x04 0x008 4 0 --- Number of Reported Uncorrectable Errors
0x04 0x010 4 25 --- Resets Between Cmd Acceptance and Completion
0x05 ===== = = === == Temperature Statistics (rev 1) ==
0x05 0x008 1 42 --- Current Temperature
0x05 0x010 1 42 N-- Average Short Term Temperature
0x05 0x018 1 36 N-- Average Long Term Temperature
0x05 0x020 1 59 --- Highest Temperature
0x05 0x028 1 21 --- Lowest Temperature
0x05 0x030 1 55 N-- Highest Average Short Term Temperature
0x05 0x038 1 0 N-- Lowest Average Short Term Temperature
0x05 0x040 1 52 N-- Highest Average Long Term Temperature
0x05 0x048 1 0 N-- Lowest Average Long Term Temperature
0x05 0x050 4 0 --- Time in Over-Temperature
0x05 0x058 1 60 --- Specified Maximum Operating Temperature
0x05 0x060 4 0 --- Time in Under-Temperature
0x05 0x068 1 0 --- Specified Minimum Operating Temperature
0x06 ===== = = === == Transport Statistics (rev 1) ==
0x06 0x008 4 469 --- Number of Hardware Resets
0x06 0x010 4 306 --- Number of ASR Events
0x06 0x018 4 18 --- Number of Interface CRC Errors
|||_ C monitored condition met
||__ D supports DSN
|___ N normalized value
Pending Defects log (GP Log 0x0c) not supported
SATA Phy Event Counters (GP Log 0x11)
ID Size Value Description
0x0001 2 0 Command failed due to ICRC error
0x0002 2 0 R_ERR response for data FIS
0x0005 2 0 R_ERR response for non-data FIS
0x0009 2 1 Transition from drive PhyRdy to drive PhyNRdy
0x000a 2 1 Device-to-host register FISes sent due to a COMRESET
0x000b 2 0 CRC errors within host-to-device FIS
0x000d 2 0 Non-CRC errors within host-to-device FIS
I set it up as a 2-disk mirror first, because I found two identical 2 TB drives in my stash. Only when the errors started happening, did I discover another 2 TB drive I had, and started looking into how I would have it replace the one with the errors.
With the output of zpool status that was posted afterwards I’m not too sure anymore. Before that I would have thought the sdX IDs have changed in-between reboots, since the alerts are older.
I am planning to set up a RAIDZ2, as well. It will consist of 4 12-TB drives. Is that advisable, given hat I only have 4 drive bays in my server?
Does that mean that if one of those fails I will have to pull it out and then set up the replacement drive going into that same drive bay as a spare after the failure?
