Every time I access the webUI dashboard module, whether logging in or returning from any other module, the following line is thrown in console:
Sep 27 15:33:34 truenas kernel: loop0: detected capacity change from 0 to 3273992
Do others have this issue?
Is it just benign console spam?
Is it a bug, reported?
Is there a fix?
Thanks!
No that one, but I have SPAM of my own.
This is my ticket:
Hi, and thanks for the interest.
How should I go about disabling constant “systemd” SPAM in the console?
I enabled “Show Console Messages” many months ago in the GUI settings, and I like it.
Thing is, I don’t remember if I somehow triggered the SPAM behavior while I was fiddling with the Audit and Syslog, and I can’t seem to find any non-default settings relating to those in the GUI.
It could be that the “systemd” messages are the expected behavior, and are not any kind of error, but they fi…
Home someone provides insight for us
I have this exact issue running 25.04.2.5 (well my changed to size is different but same symptom, kernel log spam using the UI)
Nov 4 05:44:24 truenas kernel: loop0: detected capacity change from 0 to 3277304
I updated to 25.10.2 Goldeye and this console spam stopped so I guess it’s fixed.
Aside, 25.10 added update profiles and the only profile options are “developer” or “early adopter”, so I’m no longer on the “general” train.
