When TrueNAS is running in PVE, SMB performs poorly on 10G NICs
When TrueNAS is running in PVE, SMB performs poorly under the 10G network card.
The following output can be run with the TrueNAS 10G network card through iperf 3:
iperf3.exe -c 192.168.100.3
Connecting to host 192.168.100.3, port 5201
[ 5] local 192.168.100.198 port 5756 connected to 192.168.100.3 port 5201
[ ID] Interval Transfer Bitrate
[ 5] 0.00-1.00 sec 1.04 GBytes 8.89 Gbits/sec
[ 5] 1.00-2.00 sec 1.07 GBytes 9.20 Gbits/sec
[ 5] 2.00-3.00 sec 1.05 GBytes 9.05 Gbits/sec [5] 3.00-4.00 sec 1.03 GBytes 8.86 Gbits/sec [5] 4.00-5.00 sec 1.07 GBytes 9.19 Gbits/sec [5] 5.00-6.00 sec 1.07 GBytes 9.22 Gbits/sec [5] 6.00-7.00 sec 1.08 GBytes 9.29 Gbits/sec [5] 7.00-8.00 sec 1.07 GBytes 9.21 Gbits/sec [5] 8.00-9.00 sec 1005 MBytes 8.44 Gbits/sec [5] 9.00-10.00 sec 1.03 GBytes 8.84 Gbits/sec
- - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - [ID] Interval Transfer Bitrate
[5] 0.00-10.00 sec 10.5 GBytes 9.02 Gbits/sec sender
[5] 0.00-10.01 sec 10.5 GBytes 9.01 Gbits/sec receiver
iperf Done.
But through TrueNAS’s SMB share, it can only run about 3.5Gbps
But it used to run normally at the 10G level, but it suddenly slowed down one day
Host information:
CPU: Intel(R) Xeon(R) CPU E5-2678 v3
PVE information:
256GiB memory
10G network card: ens6 MTU: 9014 Linux Bridge
Linux 6.8.12-4-pve (2024-11-06T15:04Z)
Manager version: pve-manager/8.3.3/f157a38b211595d6
Package version:
proxmox-ve: 8.3.0 (running kernel: 6.8.12-4-pve)
pve-manager: 8.3.3 (running version: 8.3.3/f157a38b211595d6)
proxmox-kernel-helper: 8.1.0
proxmox-kernel-6.8: 6.8.12-8
proxmox-kernel-6.8.12-8-pve-signed: 6.8.12-8
proxmox-kernel-6.8.12-4-pve-signed: 6.8.12-4
proxmox-kernel-6.8.12-3-pve-signed: 6.8.12-3
proxmox-kernel-6.8.12-2-pve-signed: 6.8.12-2
proxmox-kernel-6.8.4-2-pve-signed: 6.8.4-2
ceph-fuse: 17.2.7-pve3
corosync: 3.1.7-pve3
criu: 3.17.1-2+deb12u1
glusterfs-client: 10.3-5
ifupdown2: 3.2.0-1+pmx11
ksm-control-daemon: 1.5-1
libjs-extjs: 7.0.0-5
libknet1: 1.28-pve1
libproxmox-acme-perl: 1.5.1
libproxmox-backup-qemu0: 1.5.1
libproxmox-rs-perl: 0.3.4
libpve-access-control: 8.2.0
libpve-apiclient-perl: 3.3.2
libpve-cluster-api-perl: 8.0.10
libpve-cluster-perl: 8.0.10
libpve-common-perl: 8.2.9
libpve-guest-common-perl: 5.1.6
libpve-http-server-perl: 5.2.0
libpve-network-perl: 0.10.0
libpve-rs-perl: 0.9.1
libpve-storage-perl: 8.3.3
libspice-server1: 0.15.1-1
lvm2: 2.03.16-2
lxc-pve: 6.0.0-1
lxcfs: 6.0.0-pve2
novnc-pve: 1.5.0-1
openvswitch-switch: 3.1.0-2+deb12u1
proxmox-backup-client: 3.3.2-1
proxmox-backup-file-restore: 3.3.2-2
proxmox-firewall: 0.6.0
proxmox-mail-forward: 0.3.1
proxmox-mini-journalreader: 1.4.0
proxmox-offline-mirror-helper: 0.6.7
proxmox-widget-toolkit: 4.3.4
pve-cluster: 8.0.10
pve-container: 5.2.3
pve-docs: 8.3.1
pve-edk2-firmware: 4.2023.08-4
pve-esxi-import-tools: 0.7.2
pve-firewall: 5.1.0
pve-firmware: 3.14-3
pve-ha-manager: 4.0.6
pve-i18n: 3.3.3
pve-qemu-kvm: 9.0.2-5
pve-xtermjs: 5.3.0-3
qemu-server: 8.3.7
smartmontools: 7.3-pve1
spiceterm: 3.3.0
swtpm: 0.8.0+pve1
vncterm: 1.8.0
zfsutils-linux: 2.2.7-pve1
TrueNAS virtual machine information:
CPU: host 1sockets,24cores
126GiB memory
Disks are used as pass-through PCI devices in PVE
HDD disk array:
Data vdev 1 x RAIDZ1 | 8 disks | 14.55 TiB (newly purchased Seagate hard drives)
Metadata vdev 1 x MIRROR | 2 disks | 238.47 GiB (SSD)
log vdev 2 x DISK | 1 disk | 238.47 GiB (SSD)
Cache vdev 1 x 232.89 GiB (SSD)
Array utilization: 36.2%
ZFS health: online
Failed S.M.A.R.T. Tests: 0
TrueNAS-SCALE-ElectricEel - TrueNAS SCALE ElectricEel 24.10 [release]
TrueNAS-SCALE-24.10.2
Standard PC (Q35 + ICH9, 2009)
10G NIC information: VirtIO MTU:9014 Multiqueue:24
Windows information:
Version Windows 11 Professional Edition
Version number 24H2
Installation date 2024/9/2
Operating system version 26100.2605
Experience Windows feature experience package 1000.26100.36.0
10G NIC: External 10G NIC via Thunderbolt 4
Model: QNA-T310G1S (QNAP)
Identified as 10.0Gbps in Windows system
I had exactly same problem, have a read here Very slow SMB speed vs competitors
Short answer, make sure CPUs assigned to VM are passed through as Host and not QEMU or any other kind.
Likely Windows uses signing/encryption that can be sped up massively with proper CPU instructions.
I have mentioned in the post:
CPU: host 1sockets, 24cores
Ok, then you have to check that SMB multichannel is enabled and Samba correctly recognizes RSS capability of your NIC. Run powershell commands on Windows client to make sure Multichannel is established and RSS capability is enabled (you can see all them in my thread).
Also make sure you use jumbo frames, 9000 on VM, 9014 on Windows
9014 is wrong mtu size on Linux side IMO
Since you pass Virtual NIC, likely Samba won’t be able to autodetect speed and RSS capability, so you need to force it via cli command with smb_options in TrueNAS
How to do this?
Format looks like this :
cli
service smb update smb_options="server min protocol = SMB3_11\nserver smb encrypt = required\nserver signing = required\nclient min protocol = SMB3_11\nclient smb encrypt = required\nclient signing = required"
What you want is to add this (ignore all above commands, it’s just example)
interfaces = "10.10.10.10;capability=RSS,speed=10000000000"
Don’t forget to restart smbd after you do it
I enabled jumbo packet 9014 on the Windows network card, and set the MTU of the VM network card and Linux Bridge to 9000.
But for some reason, the SMB speed has become around 1~2Gbps.
This is a new test of iperf3.
[  5] local 192.168.100.198 port 14859 connected to 192.168.100.3 port 5201
[  5]   0.00-1.00   sec  1.15 GBytes  9.87 Gbits/sec
[  5]   1.00-2.00   sec  1.15 GBytes  9.84 Gbits/sec
[  5]   2.00-3.00   sec  1.15 GBytes  9.91 Gbits/sec
[  5]   3.00-4.00   sec  1.13 GBytes  9.71 Gbits/sec
[  5]   4.00-5.00   sec  1.15 GBytes  9.87 Gbits/sec
[  5]   5.00-6.00   sec  1.14 GBytes  9.82 Gbits/sec
[  5]   6.00-7.00   sec  1.14 GBytes  9.79 Gbits/sec
[  5]   7.00-8.00   sec  1.14 GBytes  9.81 Gbits/sec
[  5]   8.00-9.00   sec  1.14 GBytes  9.80 Gbits/sec
[  5]   9.00-10.00  sec  1.15 GBytes  9.89 Gbits/sec
[  5]   0.00-10.00  sec  11.4 GBytes  9.83 Gbits/sec                  sender
[  5]   0.00-10.01  sec  11.4 GBytes  9.82 Gbits/sec                  receiver
iperf Done.
After I restarted Windows, the SMB speed was around 800MB. Is this normal? Has the array reached its limit?
But it will drop to 200~300MB
Did you set MTU 9000 in 3 places on Proxmox? One on actual interface, second on bridge and third on Virt interface that you give to VM?
OK, I have now set it to 9000 on ens6 and tested the SMB speed again. It is stable at 800+MB. Is the current situation normal?
I get 1.15gb/s off NVMe or after repeat reads from spinning disks with l2arc cache. Spinning disk alone won’t saturate 10gbps
HDD disk array:
I read that, try to copy one big file (50gb+) multiple times, hopefully it will end up in cache. How fast is cache SSD?
After a period of stable 10Gbps, the speed suddenly dropped to around 600MB when copying files today. I retested using iperf and the results were as follows:
But the Windows network card still shows 10Gbps
[  5] local 100.70.249.108 port 4193 connected to 192.168.100.3 port 5201
[  5]   0.00-1.00   sec  64.6 MBytes   542 Mbits/sec
[  5]   1.00-2.00   sec  68.0 MBytes   570 Mbits/sec
[  5]   2.00-3.00   sec  67.0 MBytes   562 Mbits/sec
[  5]   3.00-4.00   sec  68.4 MBytes   574 Mbits/sec
[  5]   4.00-5.00   sec  69.8 MBytes   585 Mbits/sec
[  5]   5.00-6.00   sec  65.6 MBytes   551 Mbits/sec
[  5]   6.00-7.00   sec  64.8 MBytes   543 Mbits/sec
[  5]   7.00-8.00   sec  69.0 MBytes   579 Mbits/sec
[  5]   8.00-9.00   sec  66.6 MBytes   559 Mbits/sec
[  5]   9.00-10.00  sec  60.0 MBytes   503 Mbits/sec
[  5]   0.00-10.00  sec   664 MBytes   557 Mbits/sec                  sender
[  5]   0.00-10.01  sec   660 MBytes   553 Mbits/sec                  receiver
I restarted the network card on Windows and it didn’t work.
After I adjusted the encryption to negotiated on TrueNAS, the speed suddenly returned to around 8Gbps(Fastcopy shows a speed of 800MB~1000MB/s)
But the iperf test was still very low
[  5]   0.00-10.00  sec   661 MBytes   554 Mbits/sec                  sender
[  5]   0.00-10.01  sec   659 MBytes   552 Mbits/sec                  receiver
