I keep seeing “Just run the container as a privileged one”. Was this removed in 25.04? Or am I confused (highly possible).
Can you give an example?
Containers moved from Kubernetes to Docker in 24.10. I seem to recall there being a checkbox Privileged mode back in 24.04.
What specific issue are you having?
Well I’m building a container and now where in the GUI can I find a “select privileged” As you can see below. And it looks like this is incus running LXC containers. And normally you can put LXC into privileged mode, I’m just curious if we can do that also.
It is indeed. But since 25.04 is the first release of TrueNAS to support either Incus or LXCs, what do you mean by “removed in 25.04”? Removed compared to what?
Aha, I was thinking Apps and their Docker containers, not Instances.
