Environment:
- Proxmox VE 9.1.9, kernel 6.17.9-1-pve
- TrueNAS 25.10.3 working fine, upgraded to 25.10.4
- VM config: Q35, OVMF (UEFI), VirtIO-SCSI-PCI controller, 8GB RAM, 2 cores (host type)
- QEMU version: 10.1.2 (pve-qemu-kvm_10.1.2-7)
Problem:
After updating to 25.10.4, the system drops to initramfs shell with:
“cannot import ‘boot-pool’: no such pool available”
Root cause identified:
- Kernel 6.12.91 appears to not initialize virtio-scsi subsystem during early boot in QEMU/KVM environment
- Inside initramfs, /dev/ has NO disk devices (no /dev/sda, /dev/vda, etc.)
- zpool import returns “no pools available”
- The virtio-scsi disk is completely invisible to the kernel 6.12.91 initramfs
- Reverting to 25.10.3 (kernel 6.12.33) boots perfectly with identical VM config
Investigation:
- initrd contains virtio_scsi.ko module - Regenerating initrd via chroot did not resolve the issue
- Tried virtio-scsi-pci, virtio-scsi-single controllers - same result
- Tried SATA and IDE controllers - disk still not visible
- initrd format is plain cpio (not compressed), modules present but not loaded
- /dev/ contains only ttys, mem, random, urandom - no block devices whatsoever
- Problem persists regardless of SCSI controller type or disk bus type
- Similar issue reported with 25.10.2 on Proxmox: Upgrade to 25.10.2 fails on Proxmox VM
Workaround:
- zectl activate 25.10.3 from initramfs (after manually importing pool)
- OR revert boot environment from Proxmox host
Expected: 25.10.4 should boot with the same VM hardware config as 25.10.3
