Access to datasets randomly impossible
I noticed on two systems I managed the same issue since they both went to Truenas Scale 25.10.
From time to time, while I navigate into a dataset, Windows 10 “lost” the connection to the dataset, so I just get an error message on an empty window. I can “see” it but it shows just an empty file.
Then, if I go & come back from this dataset to other disks or virtual disks, at some point I see again the content of my dataset.
It seems more focused on some datasets, but I cannot see any pattern, all the datasets I can access from Windows 10 have the same rights and attributes.
Hi.
It may be related to this bug.
That’s it, my research did not guide me to this, so thank you very much.
I think restarting the SMB service should temporarily solve this problem. It should most likely be fixed in the next update.
