TLDR: I created a script for actually usable automatic memory ballooning (working dynamic RAM assignments for VMs) in TrueNAS: Notizen/TrueNAS/auto-ballooning.py at main · Momi-V/Notizen · GitHub . You can add it as a Post Init Script, or if you want to be able to see it’s outputs a Post Init Command like tmux new -s balloon -d '/path/to/the/script/auto-ballooning.py'. It will dynamically apply to all running VMs, whether they’re configured for autostart, started afterwards or didn’t even exist yet and were only created later.
There are a few threads about auto ballooning (aka. using dynamic memory for VMs), like this one: Memory ballooning not functioning | TrueNAS Community with the general consensus being: It doesn’t work properly, don’t touch it. The tooltip for Minimum Memory Size states:
When not specified, guest system is given fixed amount of memory specified above.
When minimum memory is specified, guest system is given memory within range between minimum and fixed as needed.
This isn’t entirely correct, because libvirt (using qemu+kvm) doesn’t actually support dynamically adjusting assigned memory based on the VMs usage and the middleware does nothing to change that. Proxmox is using their own autoballoon mechanism, there are a few scripts floating around to make something similar work with libvirt and mine is based on some of them and specifically adapted for TrueNAS.
One parameter in the domains XML config: autodeflate='on' sounds a bit like auto ballooning, but isn’t really that, because it will only ever increase assigned memory, never decrease it. And it will wait until the VM is on the very brink of OOM, after the VM has already dropped all it’s caches, saturated all it’s swap (or ZRAM) and run through several memory reclaim cycles before reluctantly deflating the balloon by a few MB.
This means when a process in a VM with 64GB max, 4GB min tries to use an extra 8GB, the VM will literally lock up for tens of minutes, running through reclaim cycle after reclaim cycle, desperately fighting for every single byte of extra memory granted by the autodeflate mechanism. And it won’t just OOM kill anything either, because just before it would the balloon gives it a few extra MB to prevent that.
This script polls VM memory usage every few seconds and tries to keep always 1GB of available memory in the VM. It works together with autodeflate, so if there’s a large spike in usage and the VM runs out of memory before the next iteration the emergency autodeflate will keep it alive long enough for the script to properly adjust the assigned RAM.
Unlike autodeflate my script is proactive, so it will assign extra memory before the VM runs completely out of RAM. It’s also more aggressive in granting extra RAM: For example if the available memory on one poll is only 0.75GiB, it will deflate the balloon by 4 * (1GiB - 0.75GiB) = 1GiB to prepare for future growth (that can be adjusted with the INFLATE_FACTOR), for a maximum growth of 4GiB per iteration. autodeflate in my tests only grew the VM around 10-20 MiB per second. And finally, unlike autodeflate alone it actually re-inflates the balloon to reclaim unused memory when it is no longer needed. Currently very slowly with at most 256MiB per iteration, but that can also be adjusted with the REDUCE_SIZE.
It’s still not perfect, it doesn’t currently respect the configured per VM Minimum Memory Size and instead uses the same MIN_MEMORY variable in the script for all VMs, but retaining the per VM settings is a bit more complicated because libvirt only saves current and maximum RAM, not the minimum.
