Hello All,
First time poster, long-time lurker.
I have a long-running TrueNAS 13.0 system. I am looking to upgrade to 13.3 and maybe eventually transition over to TrueNAS CE. One impediment I am aware of is multi-path. When I set up this system, I didn’t really the tenuous nature of the feature and built a redundant system relying on multi-path.
Either way, it sounds like I need to safely remove that feature to upgrade cleanly to later versions of TrueNAS.
My setup consists of two DS4246 (NetApp 24-Disk JBOD expanders). I have a central TrueNAS VM that has two HBA cards passed through to it. Those HBA cards each have two ports. I have a redundant connection from each DS4246 going to a different HBA card. I also am using SAS drives where possible, although some older drives due for replacement are SATA.
The system consists of one pool that consists of 4 RAIDZ2 VDEVs, each VDEV consisting of 8 disks.
Now, this system has a lot of data, and a backup isn’t really possible (although I could save off a few critical things). I’d like to do this upgrade in place and in a way that I won’t lose data and can safely go backwards if something funny happens.
My understanding of the steps is as follows:
- Export the pool
- Break the multi-path
- This is the part that confuses me and I’ve seen different instructions. Remove the cable, run some commands? I’ve seen different pieces of advice scattered about. Would be nice if there was a guide.
- Power Off the system
- Power On the system
- Re-import the pool
- Continue merrily along.
Any advice would be greatly appreciated, command output below.
zpool status output:
root@nas-01[~]# zpool status
pool: alexandria
state: ONLINE
scan: scrub repaired 0B in 1 days 22:38:53 with 0 errors on Tue Dec 2 22:38:55 2025
NAME STATE READ WRITE CKSUM
alexandria ONLINE 0 0 0
raidz2-0 ONLINE 0 0 0
gptid/913ba8e7-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
gptid/90db3b0c-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
gptid/9105ad75-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
gptid/90783c0b-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
gptid/90dae414-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
gptid/9046e0f9-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
gptid/907ef30f-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
gptid/9105dee3-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
raidz2-1 ONLINE 0 0 0
gptid/913bf73e-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
gptid/91061215-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
gptid/917f94c7-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
gptid/9136577c-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
gptid/90db6777-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
gptid/913c2681-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
gptid/91368fbf-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
gptid/910533bf-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
raidz2-2 ONLINE 0 0 0
gptid/91b5b196-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
gptid/91bb82cb-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
gptid/92603080-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
gptid/922fb088-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
gptid/923e663e-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
gptid/926465ff-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
gptid/926c45c4-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
gptid/9266680b-4e35-11ed-afcb-90e2ba510e7c ONLINE 0 0 0
raidz2-3 ONLINE 0 0 0
gptid/d3e94ba2-82df-11ed-bb78-90e2ba510e7c ONLINE 0 0 0
gptid/72103346-6c6d-11ef-9f67-90e2ba510e7c ONLINE 0 0 0
gptid/04b15194-bbdd-11ee-8284-000c29a553bd ONLINE 0 0 0
gptid/9b368053-ad61-11ee-8df4-90e2ba510e7c ONLINE 0 0 0
gptid/279e14c5-b72e-11f0-8b20-90e2ba510e7c ONLINE 0 0 0
gptid/d45da547-82df-11ed-bb78-90e2ba510e7c ONLINE 0 0 0
gptid/d46f30eb-82df-11ed-bb78-90e2ba510e7c ONLINE 0 0 0
gptid/3a643911-64d3-11ee-a186-90e2ba510e7c ONLINE 0 0 0
cache
gptid/13cb6cba-b250-11ee-8284-000c29a553bd ONLINE 0 0 0
spares
gptid/3f4b73ff-bc68-11ee-8284-000c29a553bd AVAIL
errors: No known data errors
gmultipath status output:
root@nas-01[~]# gmultipath status
Name Status Components
multipath/disk25 OPTIMAL da58 (ACTIVE)
da31 (PASSIVE)
multipath/disk24 OPTIMAL da57 (ACTIVE)
da24 (PASSIVE)
multipath/disk20 OPTIMAL da53 (ACTIVE)
da20 (PASSIVE)
multipath/disk17 OPTIMAL da50 (ACTIVE)
da17 (PASSIVE)
multipath/disk18 OPTIMAL da51 (ACTIVE)
da18 (PASSIVE)
multipath/disk16 OPTIMAL da49 (ACTIVE)
da16 (PASSIVE)
multipath/disk15 OPTIMAL da48 (ACTIVE)
da15 (PASSIVE)
multipath/disk14 OPTIMAL da47 (ACTIVE)
da14 (PASSIVE)
multipath/disk23 OPTIMAL da56 (ACTIVE)
da23 (PASSIVE)
multipath/disk22 OPTIMAL da55 (ACTIVE)
da22 (PASSIVE)
multipath/disk12 OPTIMAL da45 (ACTIVE)
da12 (PASSIVE)
multipath/disk21 OPTIMAL da54 (ACTIVE)
da21 (PASSIVE)
multipath/disk13 OPTIMAL da46 (ACTIVE)
da13 (PASSIVE)
multipath/disk10 OPTIMAL da43 (ACTIVE)
da10 (PASSIVE)
multipath/disk19 OPTIMAL da52 (ACTIVE)
da19 (PASSIVE)
multipath/disk11 OPTIMAL da44 (ACTIVE)
da11 (PASSIVE)
multipath/disk9 OPTIMAL da42 (ACTIVE)
da9 (PASSIVE)
multipath/disk8 OPTIMAL da41 (ACTIVE)
da8 (PASSIVE)
multipath/disk7 OPTIMAL da40 (ACTIVE)
da7 (PASSIVE)
multipath/disk6 OPTIMAL da39 (ACTIVE)
da6 (PASSIVE)
multipath/disk5 OPTIMAL da38 (ACTIVE)
da5 (PASSIVE)
multipath/disk4 OPTIMAL da37 (ACTIVE)
da4 (PASSIVE)
multipath/disk2 OPTIMAL da35 (ACTIVE)
da2 (PASSIVE)
multipath/disk3 OPTIMAL da36 (ACTIVE)
da3 (PASSIVE)
multipath/disk1 OPTIMAL da34 (ACTIVE)
da1 (PASSIVE)
glabel status output
root@nas-01[~]# glabel status
gptid/13cb6cba-b250-11ee-8284-000c29a553bd N/A nvd0p1
gptid/2d3d9b62-4d93-11ed-b5a6-90e2ba510e7c N/A da0p1
iso9660/TRUENAS N/A cd0
gptid/04b15194-bbdd-11ee-8284-000c29a553bd N/A da32p2
gptid/9b368053-ad61-11ee-8df4-90e2ba510e7c N/A da30p2
gptid/3a643911-64d3-11ee-a186-90e2ba510e7c N/A da29p2
gptid/d3e94ba2-82df-11ed-bb78-90e2ba510e7c N/A da25p2
gptid/d46f30eb-82df-11ed-bb78-90e2ba510e7c N/A da28p2
gptid/d45da547-82df-11ed-bb78-90e2ba510e7c N/A da27p2
gptid/72103346-6c6d-11ef-9f67-90e2ba510e7c N/A da33p2
gptid/3f3dd6b2-bc68-11ee-8284-000c29a553bd N/A multipath/disk25p1
gptid/3f4b73ff-bc68-11ee-8284-000c29a553bd N/A multipath/disk25p2
gptid/924f685d-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk24p1
gptid/9266680b-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk24p2
gptid/920a4bcc-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk20p1
gptid/922fb088-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk20p2
gptid/91a92f6d-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk17p1
gptid/91b5b196-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk17p2
gptid/91af125a-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk18p1
gptid/91bb82cb-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk18p2
gptid/90a80cf4-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk16p1
gptid/910533bf-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk16p2
gptid/90db0f1a-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk15p1
gptid/91368fbf-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk15p2
gptid/90a4041d-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk14p1
gptid/913c2681-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk14p2
gptid/924f9688-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk23p1
gptid/926c45c4-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk23p2
gptid/924aa4dd-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk22p1
gptid/926465ff-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk22p2
gptid/90dbc2db-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk12p1
gptid/9136577c-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk12p2
gptid/92294322-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk21p1
gptid/923e663e-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk21p2
gptid/904dac8e-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk13p1
gptid/90db6777-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk13p2
gptid/907e8ece-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk10p1
gptid/91061215-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk10p2
gptid/92459dd2-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk19p1
gptid/92603080-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk19p2
gptid/90db95cc-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk11p1
gptid/917f94c7-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk11p2
gptid/90a83c81-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk9p1
gptid/913bf73e-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk9p2
gptid/90a3c8dc-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk8p1
gptid/9105dee3-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk8p2
gptid/9032104a-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk7p1
gptid/907ef30f-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk7p2
gptid/90298e1e-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk6p1
gptid/9046e0f9-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk6p2
gptid/907ec297-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk5p1
gptid/90dae414-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk5p2
gptid/9036f650-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk4p1
gptid/90783c0b-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk4p2
gptid/905583b2-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk2p1
gptid/90db3b0c-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk2p2
gptid/90a43440-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk3p1
gptid/9105ad75-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk3p2
gptid/90d54787-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk1p1
gptid/913ba8e7-4e35-11ed-afcb-90e2ba510e7c N/A multipath/disk1p2
gptid/279e14c5-b72e-11f0-8b20-90e2ba510e7c N/A da26p2
