Am I missing a drive?
Version: TrueNAS-13.0-U6.1
Platform: TRUENAS-MINI-3.0-X
I am confused. geom disk list shows 5 drives, however View Enclosure in the web gui, does not.
Why is ada4 missing?
What’s the output of zpool status and camcontrol devlist?
Also, please add CORE tag for targeted help.
The “missing” drive could in fact be the SATA DOM, which is used for the boot-pool.
root@freenas[~]# zpool list
NAME           SIZE  ALLOC   FREE  CKPOINT  EXPANDSZ   FRAG    CAP  DEDUP    HEALTH  ALTROOT
foo           45.2T  19.0T  26.2T        -         -     8%    42%  1.00x    ONLINE  /mnt
freenas-boot  14.5G  6.87G  7.63G        -         -     5%    47%  1.00x    ONLINE  -
root@freenas[~]# camcontrol devlist
<WDC WD101EFAX-68LDBN0 81.00A81>   at scbus0 target 0 lun 0 (ada0,pass0)
<AHCI SGPIO Enclosure 2.00 0001>   at scbus4 target 0 lun 0 (ses0,pass1)
<WDC WD101EFAX-68LDBN0 81.00A81>   at scbus5 target 0 lun 0 (ada1,pass2)
<WDC WD101EFAX-68LDBN0 81.00A81>   at scbus6 target 0 lun 0 (ada2,pass3)
<WDC WD101EFAX-68LDBN0 81.00A81>   at scbus7 target 0 lun 0 (ada3,pass4)
<WDC WD101EFAX-68LDBN0 81.00A81>   at scbus8 target 0 lun 0 (ada4,pass5)
<16GB SATA Flash Drive SFDK004A>   at scbus9 target 0 lun 0 (ada5,pass6)
<AHCI SGPIO Enclosure 2.00 0001>   at scbus10 target 0 lun 0 (ses1,pass7)
Yup, you are missing a drive. Enterprise edition is not really my field, but I would try a reboot before anything.
Also, @winnielinnie how did you manage to add the category?
Magic. :no_mouth: :magic_wand:
@kindart, what about zpool status foo ? Perhaps that one drive is not part of any pool?
# zpool status foo
  pool: foo
 state: ONLINE
  scan: scrub repaired 0B in 10:27:46 with 0 errors on Sun Mar 31 10:27:49 2024
	foo                                             ONLINE       0     0     0
	  raidz2-0                                      ONLINE       0     0     0
	    gptid/5f24dd27-0d90-11eb-9cdc-d05099dc8f1d  ONLINE       0     0     0
	    gptid/5f287f9f-0d90-11eb-9cdc-d05099dc8f1d  ONLINE       0     0     0
	    gptid/5f7adb67-0d90-11eb-9cdc-d05099dc8f1d  ONLINE       0     0     0
	    gptid/5f7e59bf-0d90-11eb-9cdc-d05099dc8f1d  ONLINE       0     0     0
	    gptid/5f813b43-0d90-11eb-9cdc-d05099dc8f1d  ONLINE       0     0     0
Looks like it’s a bug with the GUI, then. (Referring to the “drive bays overview” in your first post.)
Either GUI or API. That’s work for iX’s team though, we have little experience with enterprise versions… I don’t seem to recall any similar thread on the old forum.
Very pretty pool illustration. I do wonder how they determine the actual hot-swap location unless they’ve become very consistent re: which cable goes to which hot-swap bay.
For the record, the same system under SCALE
That’s pretty much how they have to do it, with passive backplanes. Not a big deal with a decent production setup, though individual SATA connectors instead of SFF-8643 make for a pain in the ass and potentially higher defect rates during assembly.
Those disk drive temperatures (60+*C) scare me, even if those are flash drives are under scrub. Has the cooling system failed?
There was a thread on the old forum about overheating in Minies due to (iirc) faster than 5400RPM drives being used.
My MiniXL did an excellent job of cooking my drives in their own juices while under scrub or resilver. I tried fitting better fans, etc. and came to the conclusion that more radical case modifications would be needed to make especially the top two drive bays barely tolerable. The case design of the Mini Xl was around minimizing space / volume, not good ventilation.
Instead, I decided to go for the Lian-Li Q26A, which is still the best case out there for small (sub-10 drive) NAS systems out there as long as you can tolerate a Mini-ITX form factor motherboard squeeze. It is not much larger than a Mini XL but it uses a standard ATX PSU, offers excellent access (pop out sides), and very efficient / effective fooling with just a few Noctua 120mm fans. Best of all, the HDDs present their butts to you when you open the case so the S/Ns (at least for HGST) are there, in plain sight. Makes pulling the right hard drive trivial, no GUI display needed.
The optional backplane makes it almost as easy as the hotswap bay of the MiniXL. Unlike the MiniXL, the whole thing is KISS. All I need to know is what S/N I need to pull and I can do the rest without having to look at the GUI. Heck, I can even shut the machine down in case I don’t trust the backplane (and its missing capacitors).
I do not think so. The system is 4 years old and has been running CORE up until a few days ago.
root@freenas[~]# ipmimonitoring
ID | Name           | Type              | State    | Reading    | Units | Event
1  | 5V_AUX         | Voltage           | Nominal  | 4.95       | V     | 'OK'
2  | 3.3V_AUX       | Voltage           | Nominal  | 3.30       | V     | 'OK'
3  | CPU_Vcore      | Voltage           | Nominal  | 1.01       | V     | 'OK'
4  | VNN            | Voltage           | Nominal  | 0.81       | V     | 'OK'
5  | VCCSRAM        | Voltage           | Nominal  | 1.00       | V     | 'OK'
6  | VCCM           | Voltage           | Nominal  | 1.19       | V     | 'OK'
7  | 1.05V          | Voltage           | Nominal  | 1.04       | V     | 'OK'
8  | 1.8V           | Voltage           | Nominal  | 1.79       | V     | 'OK'
9  | BAT            | Voltage           | Nominal  | 3.10       | V     | 'OK'
10 | 12V            | Voltage           | Nominal  | 12.00      | V     | 'OK'
15 | MB Temp        | Temperature       | Nominal  | 42.00      | C     | 'OK'
16 | Card side Temp | Temperature       | Nominal  | 43.00      | C     | 'OK'
18 | CPU1 Temp      | Temperature       | Nominal  | 48.00      | C     | 'OK'
19 | MemA Temp      | Temperature       | Nominal  | 59.00      | C     | 'OK'
20 | MemB Temp      | Temperature       | Nominal  | 61.00      | C     | 'OK'
21 | CPU1_FAN1      | Fan               | Nominal  | 3400.00    | RPM   | 'OK'
24 | REAR_FAN1      | Fan               | Nominal  | 500.00     | RPM   | 'OK'
29 | ChassisIntr    | Physical Security | Nominal  | N/A        | N/A   | 'OK'
30 | CPU1_PROCHOT   | Processor         | Nominal  | N/A        | N/A   | 'OK'
31 | CPU1_THERMTRIP | Processor         | Nominal  | N/A        | N/A   | 'OK'
32 | PSU1 Status    | Power Supply      | Nominal  | N/A        | N/A   | 'OK'
34 | PSU2 Status    | Power Supply      | Nominal  | N/A        | N/A   | 'OK'
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.1.74-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Device Model:     WDC WD101EFAX-68LDBN0
LU WWN Device Id: 5 000cca 0b0c5d9e1
Firmware Version: 81.00A81
User Capacity:    10,000,831,348,736 bytes [10.0 TB]
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
Device is:        Not in smartctl database 7.3/5528
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Sun Apr 14 07:57:39 2024 CDT
SMART support is: Enabled
AAM feature is:   Unavailable
APM level is:     1 (minimum power consumption with standby)
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, frozen [SEC2]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status:  (0x84)	Offline data collection activity
					was suspended by an interrupting command from host.
Self-test execution status:      (   0)	The previous self-test routine completed
					been run.
data collection: 		(   87) seconds.
capabilities: 			 (0x5b) SMART execute Offline immediate.
					command.
					Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
Error logging capability:        (0x01)	Error logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 (1145) minutes.
SCT capabilities: 	       (0x003d)	SCT Status supported.
					SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     PO-R--   100   100   016    -    0
  2 Throughput_Performance  --S---   127   127   054    -    112
  3 Spin_Up_Time            POS---   202   202   024    -    398 (Average 406)
  4 Start_Stop_Count        -O--C-   100   100   000    -    177
  5 Reallocated_Sector_Ct   PO--CK   100   100   005    -    0
  7 Seek_Error_Rate         -O-R--   100   100   067    -    0
  8 Seek_Time_Performance   --S---   128   128   020    -    18
  9 Power_On_Hours          -O--C-   097   097   000    -    21175
 10 Spin_Retry_Count        -O--C-   100   100   060    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    177
192 Power-Off_Retract_Count -O--CK   100   100   000    -    1177
193 Load_Cycle_Count        -O--C-   100   100   000    -    1177
194 Temperature_Celsius     -O----   104   104   000    -    62 (Min/Max 22/66)
196 Reallocated_Event_Count -O--CK   100   100   000    -    0
197 Current_Pending_Sector  -O---K   100   100   000    -    0
198 Offline_Uncorrectable   ---R--   100   100   000    -    0
199 UDMA_CRC_Error_Count    -O-R--   200   200   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      1  Comprehensive SMART error log
0x03       GPL     R/O      1  Ext. Comprehensive SMART error log
0x04       GPL     R/O    256  Device Statistics log
0x04       SL      R/O    255  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x08       GPL     R/O      2  Power Conditions log
0x09           SL  R/W      1  Selective self-test log
0x0c       GPL     R/O   5501  Pending Defects log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x12       GPL     R/O      1  SATA NCQ Non-Data log
0x13       GPL     R/O      1  SATA NCQ Send and Receive log
0x15       GPL     R/W      1  Rebuild Assist log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x24       GPL     R/O    256  Current Device Internal Status Data log
0x25       GPL     R/O    256  Saved Device Internal Status Data log
0x2f       GPL     R/O      1  Set Sector Configuration
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (1 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Short offline       Completed without error       00%     16466         -
# 2  Short offline       Completed without error       00%      9915         -
# 3  Short offline       Completed without error       00%       540         -
# 4  Short offline       Completed without error       00%       539         -
SCT Status Version:                  3
SCT Version (vendor specific):       256 (0x0100)
Device State:                        SMART Off-line Data Collection executing in background (4)
Current Temperature:                    62 Celsius
Power Cycle Min/Max Temperature:     55/63 Celsius
Lifetime    Min/Max Temperature:     22/66 Celsius
Under/Over Temperature Limit Count:   0/0
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/65 Celsius
Min/Max Temperature Limit:           -40/70 Celsius
Temperature History Size (Index):    128 (102)
Index    Estimated Time   Temperature Celsius
 103    2024-04-14 05:50    62  ***************************************+
 ...    ..(126 skipped).    ..  ***************************************+
 102    2024-04-14 07:57    62  ***************************************+
SCT Error Recovery Control:
           Read:     70 (7.0 seconds)
          Write:     70 (7.0 seconds)
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4             177  ---  Lifetime Power-On Resets
0x01  0x010  4           21175  ---  Power-on Hours
0x01  0x018  6    181301589745  ---  Logical Sectors Written
0x01  0x020  6      2231081406  ---  Number of Write Commands
0x01  0x028  6    176697092260  ---  Logical Sectors Read
0x01  0x030  6       568936553  ---  Number of Read Commands
0x01  0x038  6     76232808650  ---  Date and Time TimeStamp
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4           19490  ---  Spindle Motor Power-on Hours
0x03  0x010  4           19490  ---  Head Flying Hours
0x03  0x018  4            1177  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4              15  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4               0  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              62  ---  Current Temperature
0x05  0x010  1              62  N--  Average Short Term Temperature
0x05  0x018  1              59  N--  Average Long Term Temperature
0x05  0x020  1              66  ---  Highest Temperature
0x05  0x028  1              22  ---  Lowest Temperature
0x05  0x030  1              65  N--  Highest Average Short Term Temperature
0x05  0x038  1              25  N--  Lowest Average Short Term Temperature
0x05  0x040  1              63  N--  Highest Average Long Term Temperature
0x05  0x048  1              25  N--  Lowest Average Long Term Temperature
0x05  0x050  4           12052  ---  Time in Over-Temperature
0x05  0x058  1              65  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               0  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4             446  ---  Number of Hardware Resets
0x06  0x010  4              42  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
0xff  =====  =               =  ===  == Vendor Specific Statistics (rev 1) ==
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  2            0  Command failed due to ICRC error
0x0002  2            0  R_ERR response for data FIS
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0005  2            0  R_ERR response for non-data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
0x0008  2            0  Device-to-host non-data FIS retries
0x0009  2            2  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2            3  Device-to-host register FISes sent due to a COMRESET
0x000b  2            0  CRC errors within host-to-device FIS
0x000d  2            0  Non-CRC errors within host-to-device FIS
Just wow. Glad your system is OK.
My hard drives just learned to never complain again for being run, even briefly, over 35*C.
I just upgraded memory(16GB->64GB) and it seems like it might have bumped the temperature a few degrees up.
Adding any kind of heat source can do that.
My bigger concern is that your drives were operating over the preset temperature limit for over a year and a half. To me, that suggests a high potential for trouble though various papers have yet to make a definitive link between drive longevity and disk drive temperature.
Outside of some SSD drives and HBA controllers, 60*C+ temperatures make me nervous. But my NAS also sounds like a Concorde on takeoff due to all the fans
Yikes, over 60 degrees Celsius? That’s not even “that’s bad” territory, it’s “vendor nopes out of the warranty” bad.
