Relatively new to TrueNAS, please pardon any oversight. I’ve read a number of threads regarding slow write speeds on NVMe drives but most of them seemed to involve networking. The issue I’m facing is directly on TrueNAS Community (25.04.0) itself, verified with fio.
First, a bit about the setup:
- CPU: Intel i7-8700k
- Motherboard: ASRock Z370 Extreme4
- RAM: 4 * CORSAIR VENGEANCE LPX 16GB DDR4 RAM 3200MHz
- NVMe: 2 * 500GB m.2 NVMe drives (populated on the motherboard slots)
- HDD: 6 * Seagate Exos X18 16TB 7.2K RPM SATA 6Gb/s 3.5in Hard Drive
The 6 SATA HDDs are plugged into an Lsi Logic Controller Card 9305-16i 16-port Sas 12gb/s Pci-express 3.0 Host Bus Adapter in the PCIe x 16 slot (where a graphics card would typically reside).
All SATA ports on the motherboard are unpopulated:
If an M.2 drive is installed in M.2_1, the SATA ports 3_0 and 3_1 are disabled, and if an M.2 drive is installed in M.2_2, the SATA ports 3_4 and 3_5 are disabled.
TrueNAS is natively installed (not virtualized).
The 2 NVMe drives are:
- Samsung 960 EVO 500GB (PCIe 3.0 x4, NVMe)
- Expected Performance:
- Sequential Read: Up to ~3200 MB/s
- Sequential Write: Up to ~1800 MB/s
- Random Read/Write: ~330K/300K IOPS
- Crucial P3 Plus 500GB (PCIe 4.0 x4, NVMe):
- Sequential Read: Up to ~5000 MB/s
- Sequential Write: Up to ~3600 MB/s
- Random Read/Write: ~650K/800K IOPS
There are 2 pools: boot-pool and nfs. The boot-pool is a mirror comprised of the 2 500GB NVMe drives:
pool: boot-pool
state: ONLINE
scan: scrub repaired 0B in 00:00:04 with 0 errors on Tue Jun 24 03:45:05 2025
NAME STATE READ WRITE CKSUM
boot-pool ONLINE 0 0 0
mirror-0 ONLINE 0 0 0
nvme1n1p3 ONLINE 0 0 0
nvme0n1p3 ONLINE 0 0 0
The second pool, nfs, is a raidz2 comprised of all 6 Seagate drives mentioned above.
Here are the results of an fio test on the NVMe pool - with read and write speeds of 440MB/s:
root@truenas[~]# fio --bs=128k --direct=1 --directory=/mnt/nfs/nvme/downloads/ --gtod_reduce=1 --ioengine=posixaio --iodepth=32 --group_reporting --name=randrw --numjobs=16 --ramp_time=10 --runtime=60 --rw=randrw --size=256M --time_based
randrw: (g=0): rw=randrw, bs=(R) 128KiB-128KiB, (W) 128KiB-128KiB, (T) 128KiB-128KiB, ioengine=posixaio, iodepth=32
fio-3.33
Starting 16 processes
Jobs: 16 (f=16): [m(16)][100.0%][r=222MiB/s,w=223MiB/s][r=1772,w=1784 IOPS][eta 00m:00s]
randrw: (groupid=0, jobs=16): err= 0: pid=1205172: Sun Jun 29 13:27:42 2025
read: IOPS=3351, BW=419MiB/s (440MB/s)(24.7GiB/60320msec)
bw ( KiB/s): min=162577, max=1007210, per=100.00%, avg=430880.11, stdev=10956.70, samples=1920
iops : min= 1269, max= 7865, avg=3364.80, stdev=85.62, samples=1920
write: IOPS=3354, BW=420MiB/s (440MB/s)(24.7GiB/60320msec); 0 zone resets
bw ( KiB/s): min=213446, max=1017983, per=100.00%, avg=431312.76, stdev=10284.48, samples=1920
iops : min= 1665, max= 7947, avg=3368.17, stdev=80.37, samples=1920
cpu : usr=0.41%, sys=0.13%, ctx=90940, majf=0, minf=585
IO depths : 1=0.1%, 2=0.1%, 4=0.1%, 8=1.1%, 16=72.9%, 32=26.0%, >=64=0.0%
submit : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.0%, >=64=0.0%
complete : 0=0.0%, 4=93.9%, 8=3.7%, 16=2.0%, 32=0.3%, 64=0.0%, >=64=0.0%
issued rwts: total=202154,202367,0,0 short=0,0,0,0 dropped=0,0,0,0
latency : target=0, window=0, percentile=100.00%, depth=32
Run status group 0 (all jobs):
READ: bw=419MiB/s (440MB/s), 419MiB/s-419MiB/s (440MB/s-440MB/s), io=24.7GiB (26.5GB), run=60320-60320msec
WRITE: bw=420MiB/s (440MB/s), 420MiB/s-420MiB/s (440MB/s-440MB/s), io=24.7GiB (26.6GB), run=60320-60320msec
Confirmation /mnt/nfs/nvme/downloads/ is in fact the NVMe drives:
# zfs list boot-pool/nvme/downloads
NAME USED AVAIL REFER MOUNTPOINT
boot-pool/nvme/downloads 16.4M 400G 16.4M /mnt/nfs/nvme/downloads
Here’s the output of the same test on the raidz2 HDD pool (1000MB/s ??):
root@truenas[~]# fio --bs=128k --direct=1 --directory=/mnt/nfs/userdata/ --gtod_reduce=1 --ioengine=posixaio --iodepth=32 --group_reporting --name=randrw --numjobs=16 --ramp_time=10 --runtime=60 --rw=randrw --size=256M --time_based
fio-3.33
Jobs: 16 (f=16): [m(16)][100.0%][r=1203MiB/s,w=1209MiB/s][r=9622,w=9674 IOPS][eta 00m:00s]
randrw: (groupid=0, jobs=16): err= 0: pid=1214483: Sun Jun 29 13:30:16 2025
read: IOPS=7681, BW=961MiB/s (1007MB/s)(56.4GiB/60114msec)
bw ( KiB/s): min=379745, max=1717750, per=100.00%, avg=988377.85, stdev=17970.56, samples=1904
iops : min= 2966, max=13418, avg=7720.12, stdev=140.40, samples=1904
write: IOPS=7666, BW=959MiB/s (1005MB/s)(56.3GiB/60114msec); 0 zone resets
bw ( KiB/s): min=420359, max=1683082, per=100.00%, avg=986025.17, stdev=17259.12, samples=1904
iops : min= 3282, max=13148, avg=7701.59, stdev=134.85, samples=1904
cpu : usr=0.72%, sys=0.20%, ctx=225568, majf=0, minf=584
IO depths : 1=0.1%, 2=0.1%, 4=0.2%, 8=3.5%, 16=72.6%, 32=23.7%, >=64=0.0%
complete : 0=0.0%, 4=94.5%, 8=2.7%, 16=2.0%, 32=0.8%, 64=0.0%, >=64=0.0%
issued rwts: total=461770,460882,0,0 short=0,0,0,0 dropped=0,0,0,0
READ: bw=961MiB/s (1007MB/s), 961MiB/s-961MiB/s (1007MB/s-1007MB/s), io=56.4GiB (60.6GB), run=60114-60114msec
WRITE: bw=959MiB/s (1005MB/s), 959MiB/s-959MiB/s (1005MB/s-1005MB/s), io=56.3GiB (60.4GB), run=60114-60114msec
Needless to say, 400MB/s seems abysmally slow for NVMe drives, I would expect closer to ~1200-1800MB/s given the 960 EVO is the laggard of the two.
I’ve turned compression and atime off on boot-pool/nvme/downloads and set sync to standard. As far as I can tell the i7-8700k is barely breaking a sweat so a CPU bottleneck seems unlikely, especially when considering the HDD’s are supposedly reaching 1000MB/s?
Here’s another fio test on the NVMe drives with different parameters that shows 5092MB/s reads and 302MB/s writes:
root@truenas[~]# cat nvme-seq.fio
[global]
name=nvme-seq-test
time_based
ramp_time=5
runtime=30
ioengine=libaio
direct=1
bs=1M
iodepth=64
group_reporting=1
size=10G
[read-test]
readwrite=read
filename=/mnt/nfs/nvme/downloads/test.img
numjobs=1
[write-test]
readwrite=write
numjobs=1
root@truenas[~]# fio nvme-seq.fio
read-test: (g=0): rw=read, bs=(R) 1024KiB-1024KiB, (W) 1024KiB-1024KiB, (T) 1024KiB-1024KiB, ioengine=libaio, iodepth=64
write-test: (g=0): rw=write, bs=(R) 1024KiB-1024KiB, (W) 1024KiB-1024KiB, (T) 1024KiB-1024KiB, ioengine=libaio, iodepth=64
fio-3.33
Starting 2 processes
read-test: Laying out IO file (1 file / 10240MiB)
Jobs: 2 (f=1): [f(1),W(1)][100.0%][r=5949MiB/s,w=229MiB/s][r=5949,w=229 IOPS][eta 00m:00s]
read-test: (groupid=0, jobs=2): err= 0: pid=1639560: Sun Jun 29 15:23:41 2025
read: IOPS=4853, BW=4856MiB/s (5092MB/s)(142GiB/30001msec)
slat (usec): min=57, max=4848, avg=204.39, stdev=312.79
clat (usec): min=3, max=292916, avg=12977.56, stdev=18802.01
lat (usec): min=139, max=297490, avg=13181.95, stdev=19087.15
clat percentiles (msec):
| 1.00th=[ 6], 5.00th=[ 7], 10.00th=[ 7], 20.00th=[ 7],
| 30.00th=[ 7], 40.00th=[ 14], 50.00th=[ 14], 60.00th=[ 14],
| 70.00th=[ 14], 80.00th=[ 14], 90.00th=[ 15], 95.00th=[ 15],
| 99.00th=[ 40], 99.50th=[ 209], 99.90th=[ 279], 99.95th=[ 288],
| 99.99th=[ 292]
bw ( MiB/s): min= 222, max= 8726, per=99.58%, avg=4835.47, stdev=1979.97, samples=59
iops : min= 222, max= 8726, avg=4835.46, stdev=1979.99, samples=59
write: IOPS=285, BW=288MiB/s (302MB/s)(8634MiB/30001msec); 0 zone resets
slat (usec): min=2273, max=48652, avg=3492.68, stdev=720.93
clat (usec): min=3, max=292816, avg=219586.38, stdev=32207.07
lat (msec): min=4, max=297, avg=223.07, stdev=32.64
| 1.00th=[ 153], 5.00th=[ 169], 10.00th=[ 178], 20.00th=[ 186],
| 30.00th=[ 213], 40.00th=[ 218], 50.00th=[ 220], 60.00th=[ 224],
| 70.00th=[ 230], 80.00th=[ 253], 90.00th=[ 262], 95.00th=[ 271],
| 99.00th=[ 288], 99.50th=[ 288], 99.90th=[ 292], 99.95th=[ 292],
| 99.99th=[ 292]
bw ( KiB/s): min=227328, max=407552, per=99.66%, avg=293701.64, stdev=41667.91, samples=59
iops : min= 222, max= 398, avg=286.71, stdev=40.68, samples=59
lat (usec) : 4=0.01%, 250=0.01%, 500=0.01%, 750=0.01%, 1000=0.01%
lat (msec) : 2=0.01%, 4=0.01%, 10=30.54%, 20=62.67%, 50=0.54%
lat (msec) : 100=0.15%, 250=4.60%, 500=1.56%
cpu : usr=1.22%, sys=47.23%, ctx=13257, majf=0, minf=75
IO depths : 1=0.0%, 2=0.0%, 4=0.0%, 8=0.0%, 16=0.0%, 32=0.0%, >=64=100.0%
complete : 0=0.0%, 4=100.0%, 8=0.0%, 16=0.0%, 32=0.0%, 64=0.1%, >=64=0.0%
issued rwts: total=145619,8570,0,0 short=0,0,0,0 dropped=0,0,0,0
latency : target=0, window=0, percentile=100.00%, depth=64
READ: bw=4856MiB/s (5092MB/s), 4856MiB/s-4856MiB/s (5092MB/s-5092MB/s), io=142GiB (153GB), run=30001-30001msec
WRITE: bw=288MiB/s (302MB/s), 288MiB/s-288MiB/s (302MB/s-302MB/s), io=8634MiB (9053MB), run=30001-30001msec
root@truenas[~]#
What am I missing here? Why are the NVMe drives performing so poorly?
