Just upgraded to latest Dragonfish-24.04.2, applications stats is very nice and interesting (if they are correct), however wonder why are all CPU stats at 0% and Frigate app does not have any stats (app is running)
Not sure, but you have 9 truecharts apps that won’t get getting updates, might want to think about moving those to official/community versions. Or are you waiting for TC to get their new OS & helm/kube environment ready?
I am not partial to TC, the issue is - some apps I use a lot like Calibre, Mosquitto are missing from TN catalogue, and qBittorrent and Firefox have built in VPN in TC versions. So time will tell - I might spinup a beta of Electric Eel to see if I can just add Docker Compose versions of missing apps.
But from stats stand point - Switched Frigate from TC version to TN - and still no stats in Apps view.
Have you added a GPU? I Had the issue that Apps that used a GPU, Like jellyfin never reported Stars. If i removed the GPU Stars would work
That must be it. I am using NVIDA GPU to encode decode. Interesting why would that affect stats. Are you getting CPU stats for non GPU using apps?
When i was still using the Apps, yes but in 99% the apps were idle. Only nextcloud and authentik were using 2-5% CPU. Since all my apps were truecharts i migrated to jailmaker, docker with portainer and disabled the integrated Apps system.
