Are my drives ok? (disk-burnin-and-testing analyse help needed)
Hi all,
after my HBA finally arrived I have managed to build my new server.
I saw many posts that suggests to test new drives and had links to this repo:
Did not expect the test to run 2 weeks long, but it finished finally, but I am more then unable to interpret the results.
It would be great if someone with more knowledge can take a look at the logs. (gpt-5 said everything is fine but that there were still some findings).
sda
.bb file is empty
+ Started burn-in of /dev/sda : Mon Sep  1 16:57:16 UTC 2025
Host: ubuntu-hdd
Drive Model: TOSHIBA MG10ACA20TE
Serial Number: Z4X0A0D9F4MJ
Short test duration: 2 minutes
Short test sleep duration: 120 seconds
Conveyance test duration:  minutes
Conveyance test sleep duration: 0 seconds
Extended test duration: 1709 minutes
Extended test sleep duration: 102540 seconds
Log file: ./burnin-TOSHIBA MG10ACA20TE-Z4X0A0D9F4MJ-20250901-1657+0.log
Bad blocks file: ./burnin-TOSHIBA MG10ACA20TE-Z4X0A0D9F4MJ-20250901-1657+0.bb
SCT Error Recovery Control:
           Read:     70 (7.0 seconds)
          Write:     70 (7.0 seconds)
+ Run SMART short test on drive /dev/sda: Mon Sep  1 16:57:16 UTC 2025
Short test started, sleeping 120 seconds until it finishes
SMART self-test complete
# 1  Short offline       Completed without error       00%       307         -
# 2  Extended offline    Completed without error       00%       236         -
# 3  Short offline       Completed without error       00%       211         -
Finished SMART short test on drive /dev/sda: Mon Sep  1 16:59:16 UTC 2025
+ SMART conveyance test not supported by /dev/sda; skipping.
+ Run SMART extended test on drive /dev/sda: Mon Sep  1 16:59:16 UTC 2025
Extended test started, sleeping 102540 seconds until it finishes
# 1  Extended offline    Completed without error       00%       332         -
# 2  Short offline       Completed without error       00%       307         -
# 3  Extended offline    Completed without error       00%       236         -
# 4  Short offline       Completed without error       00%       211         -
Finished SMART extended test on drive /dev/sda: Tue Sep  2 21:28:16 UTC 2025
+ Run SMART offline test on drive /dev/sda: Tue Sep  2 21:28:16 UTC 2025.
Offline test started, sleeping 120 seconds until it finishes.
=== START OF ENABLE/DISABLE COMMANDS SECTION ===
SMART Automatic Offline Testing Enabled every four hours.
Finished SMART offline test and activated automated testing (if supported) on drive /dev/sda: Tue Sep  2 21:30:17 UTC 2025.
+ Run badblocks test on drive /dev/sda: Tue Sep  2 21:30:17 UTC 2025
Finished badblocks test on drive /dev/sda: Thu Sep 11 09:02:06 UTC 2025
+ Run SMART short test on drive /dev/sda: Thu Sep 11 09:02:06 UTC 2025
# 1  Short offline       Completed without error       00%       539         -
# 2  Extended offline    Completed without error       00%       332         -
# 3  Short offline       Completed without error       00%       307         -
# 4  Extended offline    Completed without error       00%       236         -
# 5  Short offline       Completed without error       00%       211         -
Finished SMART short test on drive /dev/sda: Thu Sep 11 09:04:07 UTC 2025
+ Run SMART extended test on drive /dev/sda: Thu Sep 11 09:04:07 UTC 2025
# 1  Extended offline    Completed without error       00%       564         -
# 2  Short offline       Completed without error       00%       539         -
# 3  Extended offline    Completed without error       00%       332         -
# 4  Short offline       Completed without error       00%       307         -
# 5  Extended offline    Completed without error       00%       236         -
# 6  Short offline       Completed without error       00%       211         -
Finished SMART extended test on drive /dev/sda: Fri Sep 12 13:33:08 UTC 2025
+ Run SMART offline test on drive /dev/sda: Fri Sep 12 13:33:08 UTC 2025.
Finished SMART offline test and activated automated testing (if supported) on drive /dev/sda: Fri Sep 12 13:35:08 UTC 2025.
+ SMART information for drive /dev/sda: Fri Sep 12 13:35:08 UTC 2025
Model Family:     Toshiba MG10ACA... Enterprise Capacity HDD
Device Model:     TOSHIBA MG10ACA20TE
LU WWN Device Id: 5 000039 db8d89f9b
Firmware Version: 0104
User Capacity:    20,000,588,955,648 bytes [20.0 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database 7.3/5528
ATA Version is:   ACS-4 T13/BSR INCITS 529 revision 5
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri Sep 12 13:35:08 2025 UTC
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Disabled
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Disabled
ATA Security is:  Disabled, NOT FROZEN [SEC1]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status:  (0x84)	Offline data collection activity
					was suspended by an interrupting command from host.
Self-test execution status:      (   0)	The previous self-test routine completed
					been run.
data collection: 		(  120) seconds.
capabilities: 			 (0x5b) SMART execute Offline immediate.
					command.
					Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
Error logging capability:        (0x01)	Error logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 (1709) minutes.
SCT capabilities: 	       (0x003d)	SCT Status supported.
					SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     PO-R--   100   100   050    -    0
  2 Throughput_Performance  P-S---   100   100   050    -    0
  3 Spin_Up_Time            POS--K   100   100   001    -    9514
  4 Start_Stop_Count        -O--CK   100   100   000    -    30
  5 Reallocated_Sector_Ct   PO--CK   100   100   010    -    0
  7 Seek_Error_Rate         PO-R--   100   100   050    -    0
  8 Seek_Time_Performance   P-S---   100   100   050    -    0
  9 Power_On_Hours          -O--CK   099   099   000    -    567
 10 Spin_Retry_Count        PO--CK   100   100   030    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    30
 23 Helium_Condition_Lower  PO---K   100   100   075    -    0
 24 Helium_Condition_Upper  PO---K   100   100   075    -    0
 27 MAMR_Health_Monitor     PO---K   100   100   030    -    2397
191 G-Sense_Error_Rate      -O--CK   100   100   000    -    0
192 Power-Off_Retract_Count -O--CK   100   100   000    -    29
193 Load_Cycle_Count        -O--CK   100   100   000    -    48
194 Temperature_Celsius     -O---K   100   100   000    -    32 (Min/Max 22/34)
196 Reallocated_Event_Count PO--CK   100   100   010    -    0
197 Current_Pending_Sector  -O--CK   100   100   000    -    0
198 Offline_Uncorrectable   ----CK   100   100   000    -    0
199 UDMA_CRC_Error_Count    -O--CK   200   200   000    -    1200
220 Disk_Shift              -O----   100   100   000    -    1572864
222 Loaded_Hours            -O--CK   099   099   000    -    528
226 Load-in_Time            -OS--K   100   100   000    -    702
240 Head_Flying_Hours       P-----   100   100   001    -    0
241 Total_LBAs_Written      -O--CK   100   100   000    -    223318247425
242 Total_LBAs_Read         -O--CK   100   100   000    -    195318810414
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O     51  Comprehensive SMART error log
0x03       GPL     R/O      5  Ext. Comprehensive SMART error log
0x04       GPL,SL  R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x08       GPL     R/O      2  Power Conditions log
0x09           SL  R/W      1  Selective self-test log
0x0a       GPL     R/W      2  Device Statistics Notification
0x0c       GPL     R/O    513  Pending Defects log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x24       GPL     R/O  65520  Current Device Internal Status Data log
0x25       GPL     R/O  65520  Saved Device Internal Status Data log
0x2f       GPL     R/O      1  Set Sector Configuration
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xab       GPL     VS    1024  Device vendor specific log
0xae       GPL     VS      25  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
Device Error Count: 1163 (device log contains only the most recent 20 errors)
	CR     = Command Register
	FEATR  = Features Register
	COUNT  = Count (was: Sector Count) Register
	LBA_48 = Upper bytes of LBA High/Mid/Low Registers ]  ATA-8
	LH     = LBA High (was: Cylinder High) Register    ]   LBA
	LM     = LBA Mid (was: Cylinder Low) Register      ] Register
	LL     = LBA Low (was: Sector Number) Register     ]
	DV     = Device (was: Device/Head) Register
	DC     = Device Control Register
	ER     = Error register
	ST     = Status register
Error 1163 [2] occurred at disk power-on lifetime: 48 hours (2 days + 0 hours)
  ER -- ST COUNT  LBA_48  LH LM LL DV DC
  84 -- 43 00 00 00 09 18 5f ff 8f 40 00  Error: ICRC, ABRT at LBA = 0x9185fff8f = 39063650191
  CR FEATR COUNT  LBA_48  LH LM LL DV DC  Powered_Up_Time  Command/Feature_Name
  60 00 08 00 00 00 09 18 5f ff 88 40 00     04:28:50.475  READ FPDMA QUEUED
  60 00 08 00 00 00 09 18 5f ff 80 40 00     04:28:50.046  READ FPDMA QUEUED
  2f 00 00 00 01 00 00 00 00 00 10 00 00     04:28:50.038  READ LOG EXT
  60 00 08 00 00 00 09 18 5f ff 80 40 00     04:28:49.096  READ FPDMA QUEUED
  2f 00 00 00 01 00 00 00 00 00 10 00 00     04:28:49.088  READ LOG EXT
Error 1162 [1] occurred at disk power-on lifetime: 48 hours (2 days + 0 hours)
  84 -- 43 00 00 00 09 18 5f ff 87 40 00  Error: ICRC, ABRT at LBA = 0x9185fff87 = 39063650183
  60 00 08 00 00 00 09 18 5f ff 80 40 00     04:28:48.156  READ FPDMA QUEUED
  2f 00 00 00 01 00 00 00 00 00 10 00 00     04:28:48.131  READ LOG EXT
  60 00 08 00 00 00 09 18 5f ff 80 40 00     04:28:47.159  READ FPDMA QUEUED
Error 1161 [0] occurred at disk power-on lifetime: 48 hours (2 days + 0 hours)
  2f 00 00 00 01 00 00 00 00 00 10 00 00     04:28:47.158  READ LOG EXT
  60 00 80 00 00 00 09 18 5f ff 80 40 00     04:28:46.598  READ FPDMA QUEUED
Error 1160 [19] occurred at disk power-on lifetime: 48 hours (2 days + 0 hours)
  60 00 08 00 00 00 00 00 00 00 78 40 00     04:28:46.597  READ FPDMA QUEUED
  60 00 08 00 00 00 00 00 00 00 70 40 00     04:28:46.597  READ FPDMA QUEUED
Error 1159 [18] occurred at disk power-on lifetime: 48 hours (2 days + 0 hours)
  84 -- 43 00 00 00 09 18 5f ff ff 40 00  Error: ICRC, ABRT at LBA = 0x9185fffff = 39063650303
  60 00 08 00 00 00 00 00 00 00 68 40 00     04:28:46.597  READ FPDMA QUEUED
  60 00 08 00 00 00 00 00 00 00 60 40 00     04:28:46.597  READ FPDMA QUEUED
Error 1158 [17] occurred at disk power-on lifetime: 48 hours (2 days + 0 hours)
  84 -- 43 00 00 00 00 00 00 00 ff 40 00  Error: ICRC, ABRT at LBA = 0x000000ff = 255
  60 00 08 00 08 00 00 00 00 00 00 40 00     04:28:45.264  READ FPDMA QUEUED
  60 01 00 00 00 00 00 00 00 00 00 40 00     04:28:45.254  READ FPDMA QUEUED
  2f 00 00 00 01 00 00 00 00 00 10 00 00     04:28:45.246  READ LOG EXT
  60 00 08 00 08 00 00 00 00 00 00 40 00     04:28:44.338  READ FPDMA QUEUED
  60 01 00 00 00 00 00 00 00 00 00 40 00     04:28:44.338  READ FPDMA QUEUED
Error 1157 [16] occurred at disk power-on lifetime: 48 hours (2 days + 0 hours)
  2f 00 00 00 01 00 00 00 00 00 10 00 00     04:28:44.338  READ LOG EXT
  60 00 80 00 08 00 00 00 00 00 00 40 00     04:28:43.441  READ FPDMA QUEUED
  60 01 00 00 00 00 00 00 00 00 00 40 00     04:28:43.424  READ FPDMA QUEUED
Error 1156 [15] occurred at disk power-on lifetime: 48 hours (2 days + 0 hours)
  ec 00 00 00 01 00 00 00 00 00 00 00 00     04:28:43.421  IDENTIFY DEVICE
  2f 00 00 00 01 00 00 00 00 00 10 00 00     04:28:43.421  READ LOG EXT
  60 01 00 00 00 00 00 00 00 00 00 40 00     04:28:42.607  READ FPDMA QUEUED
SMART Extended Self-test Log Version: 1 (1 sectors)
SCT Status Version:                  3
SCT Version (vendor specific):       1 (0x0001)
Device State:                        SMART Off-line Data Collection executing in background (4)
Current Temperature:                    32 Celsius
Power Cycle Min/Max Temperature:     27/34 Celsius
Lifetime    Min/Max Temperature:     22/34 Celsius
Specified Max Operating Temperature:    60 Celsius
Under/Over Temperature Limit Count:   0/0
SMART Status:                        0xc24f (PASSED)
Vendor specific:
00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:     10/40 Celsius
Min/Max Temperature Limit:            5/60 Celsius
Temperature History Size (Index):    478 (77)
Index    Estimated Time   Temperature Celsius
  78    2025-09-12 05:38    31  ************
 ...    ..( 97 skipped).    ..  ************
 176    2025-09-12 07:16    31  ************
 177    2025-09-12 07:17    32  *************
 178    2025-09-12 07:18    31  ************
 ...    ..( 11 skipped).    ..  ************
 190    2025-09-12 07:30    31  ************
 191    2025-09-12 07:31    32  *************
 192    2025-09-12 07:32    31  ************
 193    2025-09-12 07:33    31  ************
 194    2025-09-12 07:34    32  *************
 195    2025-09-12 07:35    31  ************
 196    2025-09-12 07:36    31  ************
 197    2025-09-12 07:37    31  ************
 198    2025-09-12 07:38    32  *************
 199    2025-09-12 07:39    32  *************
 200    2025-09-12 07:40    32  *************
 201    2025-09-12 07:41    31  ************
 202    2025-09-12 07:42    32  *************
 203    2025-09-12 07:43    31  ************
 204    2025-09-12 07:44    32  *************
 205    2025-09-12 07:45    31  ************
 206    2025-09-12 07:46    31  ************
 207    2025-09-12 07:47    31  ************
 208    2025-09-12 07:48    32  *************
 ...    ..(  9 skipped).    ..  *************
 218    2025-09-12 07:58    32  *************
 219    2025-09-12 07:59    31  ************
 220    2025-09-12 08:00    32  *************
 ...    ..(153 skipped).    ..  *************
 374    2025-09-12 10:34    32  *************
 375    2025-09-12 10:35    33  **************
 376    2025-09-12 10:36    32  *************
 377    2025-09-12 10:37    32  *************
 378    2025-09-12 10:38    33  **************
 ...    ..( 42 skipped).    ..  **************
 421    2025-09-12 11:21    33  **************
 422    2025-09-12 11:22    32  *************
 423    2025-09-12 11:23    33  **************
 466    2025-09-12 12:06    33  **************
 467    2025-09-12 12:07    32  *************
 ...    ..(  2 skipped).    ..  *************
 470    2025-09-12 12:10    32  *************
 471    2025-09-12 12:11    33  **************
 472    2025-09-12 12:12    32  *************
 473    2025-09-12 12:13    32  *************
 474    2025-09-12 12:14    33  **************
 475    2025-09-12 12:15    32  *************
 ...    ..( 79 skipped).    ..  *************
  77    2025-09-12 13:35    32  *************
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 3) ==
0x01  0x008  4              30  ---  Lifetime Power-On Resets
0x01  0x010  4             567  ---  Power-on Hours
0x01  0x018  6    223318247425  ---  Logical Sectors Written
0x01  0x020  6       436168453  ---  Number of Write Commands
0x01  0x028  6    195318810414  ---  Logical Sectors Read
0x01  0x030  6       381494466  ---  Number of Read Commands
0x01  0x038  6      2041200000  ---  Date and Time TimeStamp
0x01  0x040  4               0  ---  Pending Error Count
0x02  =====  =               =  ===  == Free-Fall Statistics (rev 1) ==
0x02  0x010  4               0  ---  Overlimit Shock Events
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4             567  ---  Spindle Motor Power-on Hours
0x03  0x010  4             528  ---  Head Flying Hours
0x03  0x018  4              48  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4              24  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x03  0x038  4               0  ---  Number of Realloc. Candidate Logical Sectors
0x03  0x040  4              29  ---  Number of High Priority Unload Events
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4              13  ---  Resets Between Cmd Acceptance and Completion
0x04  0x018  4               0  -D-  Physical Element Status Changed
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              32  ---  Current Temperature
0x05  0x010  1              31  N--  Average Short Term Temperature
0x05  0x018  1               -  N--  Average Long Term Temperature
0x05  0x020  1              34  ---  Highest Temperature
0x05  0x028  1              22  ---  Lowest Temperature
0x05  0x030  1              33  N--  Highest Average Short Term Temperature
0x05  0x038  1              26  N--  Lowest Average Short Term Temperature
0x05  0x040  1               -  N--  Highest Average Long Term Temperature
0x05  0x048  1               -  N--  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              60  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               5  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4            2548  ---  Number of Hardware Resets
0x06  0x010  4              66  ---  Number of ASR Events
0x06  0x018  4            1200  ---  Number of Interface CRC Errors
0x07  =====  =               =  ===  == Solid State Device Statistics (rev 1) ==
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  4            0  Command failed due to ICRC error
0x0002  4            0  R_ERR response for data FIS
0x0003  4            0  R_ERR response for device-to-host data FIS
0x0004  4            0  R_ERR response for host-to-device data FIS
0x0005  4            0  R_ERR response for non-data FIS
0x0006  4            0  R_ERR response for device-to-host non-data FIS
0x0007  4            0  R_ERR response for host-to-device non-data FIS
0x0008  4            0  Device-to-host non-data FIS retries
0x0009  4            2  Transition from drive PhyRdy to drive PhyNRdy
0x000a  4            2  Device-to-host register FISes sent due to a COMRESET
0x000b  4            0  CRC errors within host-to-device FIS
0x000d  4            0  Non-CRC errors within host-to-device FIS
0x000f  4            0  R_ERR response for host-to-device data FIS, CRC
0x0010  4            0  R_ERR response for host-to-device data FIS, non-CRC
0x0012  4            0  R_ERR response for host-to-device non-data FIS, CRC
0x0013  4            0  R_ERR response for host-to-device non-data FIS, non-CRC
+ Finished burn-in of /dev/sda : Fri Sep 12 13:35:08 UTC 2025
.bb file is empty
sdb
.bb is empty
+ Started burn-in of /dev/sdb : Mon Sep  1 16:57:16 UTC 2025
Host: ubuntu-hdd
Serial Number: Z4T0A1VZF4MJ
Extended test duration: 1680 minutes
Extended test sleep duration: 100800 seconds
Log file: ./burnin-TOSHIBA MG10ACA20TE-Z4T0A1VZF4MJ-20250901-1657+0.log
Bad blocks file: ./burnin-TOSHIBA MG10ACA20TE-Z4T0A1VZF4MJ-20250901-1657+0.bb
+ Run SMART short test on drive /dev/sdb: Mon Sep  1 16:57:16 UTC 2025
# 1  Short offline       Completed without error       00%       260         -
# 2  Extended offline    Completed without error       00%       189         -
# 3  Short offline       Completed without error       00%       164         -
Finished SMART short test on drive /dev/sdb: Mon Sep  1 16:59:16 UTC 2025
+ SMART conveyance test not supported by /dev/sdb; skipping.
+ Run SMART extended test on drive /dev/sdb: Mon Sep  1 16:59:16 UTC 2025
Extended test started, sleeping 100800 seconds until it finishes
# 1  Extended offline    Completed without error       00%       285         -
# 2  Short offline       Completed without error       00%       260         -
# 3  Extended offline    Completed without error       00%       189         -
# 4  Short offline       Completed without error       00%       164         -
Finished SMART extended test on drive /dev/sdb: Tue Sep  2 20:59:16 UTC 2025
+ Run SMART offline test on drive /dev/sdb: Tue Sep  2 20:59:16 UTC 2025.
Finished SMART offline test and activated automated testing (if supported) on drive /dev/sdb: Tue Sep  2 21:01:17 UTC 2025.
+ Run badblocks test on drive /dev/sdb: Tue Sep  2 21:01:17 UTC 2025
Finished badblocks test on drive /dev/sdb: Thu Sep 11 05:17:29 UTC 2025
+ Run SMART short test on drive /dev/sdb: Thu Sep 11 05:17:29 UTC 2025
# 1  Short offline       Completed without error       00%       488         -
# 2  Extended offline    Completed without error       00%       285         -
# 3  Short offline       Completed without error       00%       260         -
# 4  Extended offline    Completed without error       00%       189         -
# 5  Short offline       Completed without error       00%       164         -
Finished SMART short test on drive /dev/sdb: Thu Sep 11 05:19:30 UTC 2025
+ Run SMART extended test on drive /dev/sdb: Thu Sep 11 05:19:30 UTC 2025
# 1  Extended offline    Completed without error       00%       514         -
# 2  Short offline       Completed without error       00%       488         -
# 3  Extended offline    Completed without error       00%       285         -
# 4  Short offline       Completed without error       00%       260         -
# 5  Extended offline    Completed without error       00%       189         -
# 6  Short offline       Completed without error       00%       164         -
Finished SMART extended test on drive /dev/sdb: Fri Sep 12 09:19:30 UTC 2025
+ Run SMART offline test on drive /dev/sdb: Fri Sep 12 09:19:30 UTC 2025.
Finished SMART offline test and activated automated testing (if supported) on drive /dev/sdb: Fri Sep 12 09:21:31 UTC 2025.
+ SMART information for drive /dev/sdb: Fri Sep 12 09:21:31 UTC 2025
LU WWN Device Id: 5 000039 db8d959b0
Local Time is:    Fri Sep 12 09:21:31 2025 UTC
					been run.
					command.
					power-saving mode.
recommended polling time: 	 (1680) minutes.
  3 Spin_Up_Time            POS--K   100   100   001    -    9485
  9 Power_On_Hours          -O--CK   099   099   000    -    516
 27 MAMR_Health_Monitor     PO---K   100   100   030    -    723295
193 Load_Cycle_Count        -O--CK   100   100   000    -    30
199 UDMA_CRC_Error_Count    -O--CK   200   200   000    -    0
220 Disk_Shift              -O----   100   100   000    -    1703936
222 Loaded_Hours            -O--CK   099   099   000    -    516
226 Load-in_Time            -OS--K   100   100   000    -    692
241 Total_LBAs_Written      -O--CK   100   100   000    -    225472908288
242 Total_LBAs_Read         -O--CK   100   100   000    -    195318302960
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
Vendor specific:
Temperature History Size (Index):    478 (440)
 441    2025-09-12 01:24    31  ************
 ...    ..( 55 skipped).    ..  ************
  19    2025-09-12 02:20    31  ************
  20    2025-09-12 02:21    30  ***********
  21    2025-09-12 02:22    31  ************
 ...    ..( 20 skipped).    ..  ************
  42    2025-09-12 02:43    31  ************
  43    2025-09-12 02:44    30  ***********
  44    2025-09-12 02:45    31  ************
  45    2025-09-12 02:46    31  ************
  46    2025-09-12 02:47    30  ***********
  47    2025-09-12 02:48    31  ************
  48    2025-09-12 02:49    31  ************
  49    2025-09-12 02:50    31  ************
  50    2025-09-12 02:51    30  ***********
  51    2025-09-12 02:52    31  ************
  52    2025-09-12 02:53    31  ************
  53    2025-09-12 02:54    31  ************
  54    2025-09-12 02:55    30  ***********
  55    2025-09-12 02:56    31  ************
  56    2025-09-12 02:57    30  ***********
  57    2025-09-12 02:58    30  ***********
  58    2025-09-12 02:59    31  ************
 ...    ..( 13 skipped).    ..  ************
  72    2025-09-12 03:13    31  ************
  73    2025-09-12 03:14    30  ***********
  74    2025-09-12 03:15    30  ***********
  75    2025-09-12 03:16    31  ************
 ...    ..(  5 skipped).    ..  ************
  81    2025-09-12 03:22    31  ************
  82    2025-09-12 03:23    30  ***********
  83    2025-09-12 03:24    31  ************
  84    2025-09-12 03:25    30  ***********
  85    2025-09-12 03:26    31  ************
  86    2025-09-12 03:27    30  ***********
  87    2025-09-12 03:28    31  ************
  88    2025-09-12 03:29    31  ************
  89    2025-09-12 03:30    30  ***********
  90    2025-09-12 03:31    30  ***********
  91    2025-09-12 03:32    31  ************
  92    2025-09-12 03:33    30  ***********
  93    2025-09-12 03:34    31  ************
  94    2025-09-12 03:35    30  ***********
  95    2025-09-12 03:36    31  ************
  96    2025-09-12 03:37    30  ***********
  97    2025-09-12 03:38    31  ************
  98    2025-09-12 03:39    30  ***********
  99    2025-09-12 03:40    31  ************
 100    2025-09-12 03:41    31  ************
 101    2025-09-12 03:42    30  ***********
 102    2025-09-12 03:43    30  ***********
 103    2025-09-12 03:44    31  ************
 104    2025-09-12 03:45    30  ***********
 ...    ..(  8 skipped).    ..  ***********
 113    2025-09-12 03:54    30  ***********
 114    2025-09-12 03:55    31  ************
 115    2025-09-12 03:56    30  ***********
 118    2025-09-12 03:59    30  ***********
 119    2025-09-12 04:00    31  ************
 120    2025-09-12 04:01    30  ***********
 ...    ..(  3 skipped).    ..  ***********
 124    2025-09-12 04:05    30  ***********
 125    2025-09-12 04:06    31  ************
 126    2025-09-12 04:07    31  ************
 127    2025-09-12 04:08    30  ***********
 128    2025-09-12 04:09    30  ***********
 129    2025-09-12 04:10    30  ***********
 130    2025-09-12 04:11    31  ************
 131    2025-09-12 04:12    30  ***********
 132    2025-09-12 04:13    30  ***********
 133    2025-09-12 04:14    30  ***********
 134    2025-09-12 04:15    31  ************
 ...    ..(  3 skipped).    ..  ************
 138    2025-09-12 04:19    31  ************
 139    2025-09-12 04:20    30  ***********
 140    2025-09-12 04:21    31  ************
 ...    ..(125 skipped).    ..  ************
 266    2025-09-12 06:27    31  ************
 267    2025-09-12 06:28    32  *************
 ...    ..(172 skipped).    ..  *************
 440    2025-09-12 09:21    32  *************
0x01  0x010  4             516  ---  Power-on Hours
0x01  0x018  6    225472908288  ---  Logical Sectors Written
0x01  0x020  6       440376774  ---  Number of Write Commands
0x01  0x028  6    195318302960  ---  Logical Sectors Read
0x01  0x030  6       381482251  ---  Number of Read Commands
0x01  0x038  6      1857600000  ---  Date and Time TimeStamp
0x03  0x008  4             516  ---  Spindle Motor Power-on Hours
0x03  0x010  4             516  ---  Head Flying Hours
0x03  0x018  4              30  ---  Head Load Events
0x03  0x028  4              80  ---  Read Recovery Attempts
0x04  0x010  4            2348  ---  Resets Between Cmd Acceptance and Completion
0x05  0x030  1              32  N--  Highest Average Short Term Temperature
0x06  0x008  4            6616  ---  Number of Hardware Resets
0x06  0x010  4             902  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
                                ||__ D supports DSN
No Defects Logged
0x0009  4            3  Transition from drive PhyRdy to drive PhyNRdy
0x000a  4            3  Device-to-host register FISes sent due to a COMRESET
+ Finished burn-in of /dev/sdb : Fri Sep 12 09:21:31 UTC 2025
sdc
.bb file is empty
next post
sdd
.bb file is empty
next post
I can see for my self that there are some kind of errors, but don’t know what the really mean for me.
sdc
.bb file is empty
+ Started burn-in of /dev/sdc : Mon Sep  1 16:57:16 UTC 2025
Host: ubuntu-hdd
Serial Number: 1530A1DZF4MJ
Extended test duration: 1684 minutes
Extended test sleep duration: 101040 seconds
Log file: ./burnin-TOSHIBA MG10ACA20TE-1530A1DZF4MJ-20250901-1657+0.log
Bad blocks file: ./burnin-TOSHIBA MG10ACA20TE-1530A1DZF4MJ-20250901-1657+0.bb
+ Run SMART short test on drive /dev/sdc: Mon Sep  1 16:57:16 UTC 2025
# 1  Short offline       Completed without error       00%       306         -
# 2  Extended offline    Completed without error       00%       235         -
# 3  Short offline       Completed without error       00%       210         -
Finished SMART short test on drive /dev/sdc: Mon Sep  1 16:59:16 UTC 2025
+ SMART conveyance test not supported by /dev/sdc; skipping.
+ Run SMART extended test on drive /dev/sdc: Mon Sep  1 16:59:16 UTC 2025
Extended test started, sleeping 101040 seconds until it finishes
# 1  Extended offline    Completed without error       00%       331         -
# 2  Short offline       Completed without error       00%       306         -
# 3  Extended offline    Completed without error       00%       235         -
# 4  Short offline       Completed without error       00%       210         -
Finished SMART extended test on drive /dev/sdc: Tue Sep  2 21:03:16 UTC 2025
+ Run SMART offline test on drive /dev/sdc: Tue Sep  2 21:03:16 UTC 2025.
Finished SMART offline test and activated automated testing (if supported) on drive /dev/sdc: Tue Sep  2 21:05:17 UTC 2025.
+ Run badblocks test on drive /dev/sdc: Tue Sep  2 21:05:17 UTC 2025
Finished badblocks test on drive /dev/sdc: Thu Sep 11 05:52:44 UTC 2025
+ Run SMART short test on drive /dev/sdc: Thu Sep 11 05:52:44 UTC 2025
# 1  Short offline       Completed without error       00%       535         -
# 2  Extended offline    Completed without error       00%       331         -
# 3  Short offline       Completed without error       00%       306         -
# 4  Extended offline    Completed without error       00%       235         -
# 5  Short offline       Completed without error       00%       210         -
Finished SMART short test on drive /dev/sdc: Thu Sep 11 05:54:45 UTC 2025
+ Run SMART extended test on drive /dev/sdc: Thu Sep 11 05:54:45 UTC 2025
# 1  Extended offline    Completed without error       00%       560         -
# 2  Short offline       Completed without error       00%       535         -
# 3  Extended offline    Completed without error       00%       331         -
# 4  Short offline       Completed without error       00%       306         -
# 5  Extended offline    Completed without error       00%       235         -
# 6  Short offline       Completed without error       00%       210         -
Finished SMART extended test on drive /dev/sdc: Fri Sep 12 09:58:45 UTC 2025
+ Run SMART offline test on drive /dev/sdc: Fri Sep 12 09:58:45 UTC 2025.
Finished SMART offline test and activated automated testing (if supported) on drive /dev/sdc: Fri Sep 12 10:00:46 UTC 2025.
+ SMART information for drive /dev/sdc: Fri Sep 12 10:00:46 UTC 2025
LU WWN Device Id: 5 000039 dc8c8070a
Local Time is:    Fri Sep 12 10:00:46 2025 UTC
					been run.
					command.
					power-saving mode.
recommended polling time: 	 (1684) minutes.
  3 Spin_Up_Time            POS--K   100   100   001    -    9494
  9 Power_On_Hours          -O--CK   099   099   000    -    563
 27 MAMR_Health_Monitor     PO---K   100   100   030    -    592735
194 Temperature_Celsius     -O---K   100   100   000    -    32 (Min/Max 21/34)
222 Loaded_Hours            -O--CK   099   099   000    -    523
226 Load-in_Time            -OS--K   100   100   000    -    708
241 Total_LBAs_Written      -O--CK   100   100   000    -    225947873793
242 Total_LBAs_Read         -O--CK   100   100   000    -    195318583573
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
Lifetime    Min/Max Temperature:     21/34 Celsius
Vendor specific:
Temperature History Size (Index):    478 (455)
 456    2025-09-12 02:03    30  ***********
 ...    ..(168 skipped).    ..  ***********
 147    2025-09-12 04:52    30  ***********
 148    2025-09-12 04:53    31  ************
 149    2025-09-12 04:54    30  ***********
 ...    ..( 10 skipped).    ..  ***********
 160    2025-09-12 05:05    30  ***********
 161    2025-09-12 05:06    31  ************
 ...    ..( 10 skipped).    ..  ************
 172    2025-09-12 05:17    31  ************
 173    2025-09-12 05:18    30  ***********
 174    2025-09-12 05:19    31  ************
 ...    ..(107 skipped).    ..  ************
 282    2025-09-12 07:07    31  ************
 283    2025-09-12 07:08    32  *************
 ...    ..( 52 skipped).    ..  *************
 336    2025-09-12 08:01    32  *************
 337    2025-09-12 08:02    31  ************
 338    2025-09-12 08:03    32  *************
 339    2025-09-12 08:04    31  ************
 340    2025-09-12 08:05    32  *************
 ...    ..( 59 skipped).    ..  *************
 400    2025-09-12 09:05    32  *************
 401    2025-09-12 09:06    31  ************
 402    2025-09-12 09:07    32  *************
 403    2025-09-12 09:08    31  ************
 407    2025-09-12 09:12    31  ************
 408    2025-09-12 09:13    32  *************
 ...    ..( 45 skipped).    ..  *************
 454    2025-09-12 09:59    32  *************
 455    2025-09-12 10:00    31  ************
0x01  0x010  4             563  ---  Power-on Hours
0x01  0x018  6    225947873793  ---  Logical Sectors Written
0x01  0x020  6       441304442  ---  Number of Write Commands
0x01  0x028  6    195318583573  ---  Logical Sectors Read
0x01  0x030  6       381486655  ---  Number of Read Commands
0x01  0x038  6      2026800000  ---  Date and Time TimeStamp
0x03  0x008  4             563  ---  Spindle Motor Power-on Hours
0x03  0x010  4             523  ---  Head Flying Hours
0x03  0x028  4               0  ---  Read Recovery Attempts
0x04  0x010  4               0  ---  Resets Between Cmd Acceptance and Completion
0x05  0x028  1              21  ---  Lowest Temperature
0x06  0x008  4             146  ---  Number of Hardware Resets
0x06  0x010  4              53  ---  Number of ASR Events
                                ||__ D supports DSN
No Defects Logged
+ Finished burn-in of /dev/sdc : Fri Sep 12 10:00:46 UTC 2025
sdd
.bb file is empty
+ Started burn-in of /dev/sdd : Mon Sep  1 16:57:16 UTC 2025
Host: ubuntu-hdd
Serial Number: Z4X0A0D4F4MJ
Extended test duration: 1687 minutes
Extended test sleep duration: 101220 seconds
Log file: ./burnin-TOSHIBA MG10ACA20TE-Z4X0A0D4F4MJ-20250901-1657+0.log
Bad blocks file: ./burnin-TOSHIBA MG10ACA20TE-Z4X0A0D4F4MJ-20250901-1657+0.bb
+ Run SMART short test on drive /dev/sdd: Mon Sep  1 16:57:16 UTC 2025
Finished SMART short test on drive /dev/sdd: Mon Sep  1 16:59:16 UTC 2025
+ SMART conveyance test not supported by /dev/sdd; skipping.
+ Run SMART extended test on drive /dev/sdd: Mon Sep  1 16:59:16 UTC 2025
Extended test started, sleeping 101220 seconds until it finishes
Finished SMART extended test on drive /dev/sdd: Tue Sep  2 21:06:16 UTC 2025
+ Run SMART offline test on drive /dev/sdd: Tue Sep  2 21:06:16 UTC 2025.
Finished SMART offline test and activated automated testing (if supported) on drive /dev/sdd: Tue Sep  2 21:08:17 UTC 2025.
+ Run badblocks test on drive /dev/sdd: Tue Sep  2 21:08:17 UTC 2025
Finished badblocks test on drive /dev/sdd: Thu Sep 11 06:26:41 UTC 2025
+ Run SMART short test on drive /dev/sdd: Thu Sep 11 06:26:41 UTC 2025
# 1  Short offline       Completed without error       00%       536         -
Finished SMART short test on drive /dev/sdd: Thu Sep 11 06:28:42 UTC 2025
+ Run SMART extended test on drive /dev/sdd: Thu Sep 11 06:28:42 UTC 2025
# 1  Extended offline    Completed without error       00%       561         -
# 2  Short offline       Completed without error       00%       536         -
Finished SMART extended test on drive /dev/sdd: Fri Sep 12 10:35:43 UTC 2025
+ Run SMART offline test on drive /dev/sdd: Fri Sep 12 10:35:43 UTC 2025.
Finished SMART offline test and activated automated testing (if supported) on drive /dev/sdd: Fri Sep 12 10:37:43 UTC 2025.
+ SMART information for drive /dev/sdd: Fri Sep 12 10:37:43 UTC 2025
LU WWN Device Id: 5 000039 db8d89f52
Local Time is:    Fri Sep 12 10:37:43 2025 UTC
					been run.
					command.
					power-saving mode.
recommended polling time: 	 (1687) minutes.
  3 Spin_Up_Time            POS--K   100   100   001    -    9567
  9 Power_On_Hours          -O--CK   099   099   000    -    564
 27 MAMR_Health_Monitor     PO---K   100   100   030    -    460638
194 Temperature_Celsius     -O---K   100   100   000    -    33 (Min/Max 22/35)
220 Disk_Shift              -O----   100   100   000    -    524288
222 Loaded_Hours            -O--CK   099   099   000    -    525
226 Load-in_Time            -OS--K   100   100   000    -    681
241 Total_LBAs_Written      -O--CK   100   100   000    -    225686261249
242 Total_LBAs_Read         -O--CK   100   100   000    -    195318572380
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
Current Temperature:                    33 Celsius
Power Cycle Min/Max Temperature:     27/35 Celsius
Lifetime    Min/Max Temperature:     22/35 Celsius
Vendor specific:
Temperature History Size (Index):    478 (271)
 272    2025-09-12 02:40    31  ************
 ...    ..(167 skipped).    ..  ************
 440    2025-09-12 05:28    31  ************
 441    2025-09-12 05:29    32  *************
 442    2025-09-12 05:30    31  ************
 443    2025-09-12 05:31    31  ************
 444    2025-09-12 05:32    32  *************
 445    2025-09-12 05:33    31  ************
 446    2025-09-12 05:34    31  ************
 447    2025-09-12 05:35    31  ************
 448    2025-09-12 05:36    32  *************
 449    2025-09-12 05:37    31  ************
 450    2025-09-12 05:38    32  *************
 451    2025-09-12 05:39    31  ************
 452    2025-09-12 05:40    32  *************
 453    2025-09-12 05:41    31  ************
 454    2025-09-12 05:42    32  *************
 ...    ..(  3 skipped).    ..  *************
 458    2025-09-12 05:46    32  *************
 459    2025-09-12 05:47    31  ************
 460    2025-09-12 05:48    32  *************
 461    2025-09-12 05:49    31  ************
 462    2025-09-12 05:50    31  ************
 463    2025-09-12 05:51    31  ************
 464    2025-09-12 05:52    32  *************
 ...    ..(109 skipped).    ..  *************
  96    2025-09-12 07:42    32  *************
  97    2025-09-12 07:43    33  **************
 ...    ..(154 skipped).    ..  **************
 252    2025-09-12 10:18    33  **************
 253    2025-09-12 10:19    32  *************
 254    2025-09-12 10:20    33  **************
 ...    ..( 16 skipped).    ..  **************
 271    2025-09-12 10:37    33  **************
0x01  0x010  4             564  ---  Power-on Hours
0x01  0x018  6    225686261249  ---  Logical Sectors Written
0x01  0x020  6       440793480  ---  Number of Write Commands
0x01  0x028  6    195318572380  ---  Logical Sectors Read
0x01  0x030  6       381486565  ---  Number of Read Commands
0x01  0x038  6      2030400000  ---  Date and Time TimeStamp
0x03  0x008  4             564  ---  Spindle Motor Power-on Hours
0x03  0x010  4             525  ---  Head Flying Hours
0x04  0x010  4              52  ---  Resets Between Cmd Acceptance and Completion
0x05  0x008  1              33  ---  Current Temperature
0x05  0x010  1              32  N--  Average Short Term Temperature
0x05  0x020  1              35  ---  Highest Temperature
0x06  0x008  4             378  ---  Number of Hardware Resets
0x06  0x010  4              91  ---  Number of ASR Events
                                ||__ D supports DSN
No Defects Logged
+ Finished burn-in of /dev/sdd : Fri Sep 12 10:37:43 UTC 2025
So you have MAMR drives. Interesting. I need to read up on these to find out more on what the value really means 27 MAMR_Health_Monitor PO---K 100 100 030 - 2397 to us people in the real world. i’m sure all is fine, your values are 100 with a lower threshold (when shit hits the fan) of 30.
sda looks fine to me at first glance. They all look good but I just cruised through the files. It is a lot to read.
I will be very curious how well those drives work for you. They are CMR drives, a good thing. Flux Control Microwave Assisted Magnetic Recording (FC-MAMR™) technology as well, so it’s fairly a new thing. If you place a hot dog next to it, you should be able to warm it up :slight_smile:
Thank you for the quick answer.
I can not say, that I even understand have of all of that.
The drives were a recommendation I got.
It is nice to hear that you too think that all drives are fine.
I tried to get some more Infos out of chatgpt, when I understand everything correctly while the drives are fine the hba is maybe not. But that would be really strange, every single part is brand new.
Would be great to see what you say, when you had some more time to look at the files. Great to have people here that are skilled and spend time to help others in free time.
In looking at the data a bit more here is my conclusion:
  1. It takes a minimum of just over 28 hours to run a SMART Long test. That is a considerable amount of time and you should be aware of this. My recommendation for SMART testing is a Daily Short test on all drives. This will provide you a quick check to see if something really bad is happening. And depending on how you will be using your system, while I typically suggest a weekly SMART Long test, I’d say do one drive a day, never all drives at the same time.
  2. Why neer all at the same time, good question and here is the answer: Your drives have a very specific operating temperature range.
The Min/Max recommended Temperature:     10/40 Celsius
I have never seen a drive with a recommended upper temperature of 40C before. It could be due to being a MAMR drive and it works better at a cooler temperature. That may be difficult to maintain depending on where your drives reside. The upper maximum limit is normal, but no one wants to hit that limit, or even come close. If you run a SMART Long test on all the drives at the same time, depending on your hardware layout and cooling, you could exceed the recommended limits easily.
Your drives are running cool, at least for the testing you have completed.
  1. You had a few errors at under 50 hours of drive time. These are quite possibly from accidental power drops, data cable issues, HBA issues, all things that may have occurred during your initial build. I would not put much credibility in those.
I tried to look up more information about the MAMR SMART data meaning, I could not locate anything. There are three values you can look at for some peace of mind: VALUE, WORST, THRESH. VALUE is the current value for the given parameter. WORST is the absolute worst value ever recorded for this parameter. THRESH is the number where the drive has failed. So a THRESH value of 000 means that 100 is good and 000 is bad. THRESH of 030 and WORST is 100, this means that 100 is a good number, 030 and below is bad. Sounds obvious right.
Where this helps is for other values as well. Using the VALUE, WORST, and THRESH, you can determine if a value of 100 or 000 is good or bad. You will see this more on SSD with respect to Wear Level or Percentage Used. Wear Level typically starts at a value of 100 and counts down, whereas Percentage Used starts at 0 and counts up.
Again, sounds obvious but many people don’t see this and react without understanding what they are reading. Sorry if I just made things more compilated.
Summary: All looks good, Keep your drives cool.
Some CRC errors - like Joe said, CRC errors are commonly cabling related. Reseat connections, try different ports, etc. Would also be a good idea to check that your HBA is on latest IT firmware available & maybe even slap a fan on it (or at least pointing directly at it).
Thanks for saying something.
I may have seen them but forgot to mention them. If the value remains at 1200 on drive Z4X0A0D9F4MJ and does not increment then no action is required. If the value increments then as @Fleshmauler said, generally cable related but could be an HBA or something. Hopefully the value is no longer incrementing. Unfortunately we are unable to clear those errors, they live with the drive forever. It is kind of crazy since I have never seen a CRC error that was caused by the drive itself, but it must happen sometimes.
Thanks for the detailed answer. I try to give some feedback to your points.
  1. The drives we are talking about are all passed to the truenas vm and will only be used there. If there is a way to automate a daily short test in truenas I will do that. Regarding the Long SMART test once a week a down time (I think there is a downtime right?) of 25-28h is to long for my case since I am not the only one depending on the system. The drives are installed in the Fractale Design Define 7 XL in server/nas configuration in the front with fans in every spot.
  2. With all the fans running and the server running in the basement here in cold Europe I think that should be fine.
  3. It took me close to 4 days to get the HBA working, including some reseeding, 2 proxmox installs and some “hard” resets, it is possible this caused some of this. Now everything is up and running fine so far. My question here would be how I can check that value in the future again, without shutting the truenas vm down and “putting” the drives to my ubuntu vm were I let this tests run.
All in all I am happy that everything looks fine so far. Thanks again for your time and noob friendly way of your answers.
I have some fun getting the HBA work that right :slight_smile: The firmware was updated to the latest version and there is quiet good airflow over it I think.
Danger, warning, danger; are you passing through the drives or the HBA? Do you have the HBA blacklisted from the hypervisor?
Had some fun in the past where people would use proxmox which understands zfs & tries to take control of drives passed through to Truenas causing unrecoverable data loss
