how to install automatic ripping machine?
As far as i have seen they don’t provide a compose file, so you’d have to either use the truenas gui option for a custom app and add all the options from the docker run command manually, write your own compose file from the docker run command, use a online-converter to create a compose file from the docker run command or file a github request so that it get’s added as an official app.
I made a custom app and keep Crashed.
If you’ve already tried it and it crashed it would be good to post the error and log messages. Right now you’ve given us the equivalent of “my car broke down how to fix”.
I’m new to truenas
it is stopped running
now getting Hmmm… can’t reach this page
192.168.50.45 refused to connect.
how do I get the logs?
I’m at work right now and don’t have access to my truenas, but there should be an option on the right side to display the logs of the app.
tcp://0.0.0.0:12339:8080
tcp://:::12339:8080
2025-05-07 08:18:35.971521+00:00*** Running /etc/my_init.d/10_syslog-ng.init…
2025-05-07 08:18:36.037598+00:00May 7 08:18:36 7dbb0db057ce syslog-ng[13]: syslog-ng starting up; version=‘3.35.1’
2025-05-07 08:18:37.018413+00:00*** Running /etc/my_init.d/arm_user_files_setup.sh…
2025-05-07 08:18:37.020492+00:00Updating arm group id 1000 to default (1000)…
2025-05-07 08:18:37.054372+00:00usermod: no changes
2025-05-07 08:18:37.054753+00:00Updating arm group id 1000 to default (1000)…
2025-05-07 08:18:37.074569+00:00Adding arm user to ‘render’ group
2025-05-07 08:18:38.734307+00:00Checking ownership of /home/arm
2025-05-07 08:18:38.734350+00:00---------------------------------------------
2025-05-07 08:18:38.734367+00:00[ERROR]: ARM does not have permissions to /home/arm using 1000:1000
2025-05-07 08:18:38.734376+00:00Check your user permissions and restart ARM. Folder permissions–> 0:0
2025-05-07 08:18:38.734384+00:00---------------------------------------------
2025-05-07 08:18:38.734491+00:00*** /etc/my_init.d/arm_user_files_setup.sh failed with status 1
2025-05-07 08:18:38.734510+00:002025-05-07T08:18:38.734510765Z
2025-05-07 08:18:38.734522+00:00*** Killing all processes…
2025-05-07 08:18:38.734730+00:00May 7 08:18:38 7dbb0db057ce syslog-ng[13]: syslog-ng shutting down; version=‘3.35.1’
2025-05-07 08:18:44.236339+00:00*** Running /etc/my_init.d/10_syslog-ng.init…
2025-05-07 08:18:44.258975+00:00May 7 08:18:44 7dbb0db057ce syslog-ng[12]: syslog-ng starting up; version=‘3.35.1’
2025-05-07 08:18:45.256574+00:00*** Running /etc/my_init.d/arm_user_files_setup.sh…
2025-05-07 08:18:45.258841+00:00Updating arm group id 1000 to default (1000)…
2025-05-07 08:18:45.261519+00:00usermod: no changes
2025-05-07 08:18:45.261769+00:00Updating arm group id 1000 to default (1000)…
2025-05-07 08:18:45.267143+00:00Adding arm user to ‘render’ group
2025-05-07 08:18:45.291710+00:00Checking ownership of /home/arm
2025-05-07 08:18:45.291749+00:00---------------------------------------------
2025-05-07 08:18:45.291759+00:00[ERROR]: ARM does not have permissions to /home/arm using 1000:1000
2025-05-07 08:18:45.291785+00:00Check your user permissions and restart ARM. Folder permissions–> 0:0
2025-05-07 08:18:45.291794+00:00---------------------------------------------
2025-05-07 08:18:45.292003+00:00*** /etc/my_init.d/arm_user_files_setup.sh failed with status 1
2025-05-07 08:18:45.292026+00:002025-05-07T08:18:45.292026826Z
2025-05-07 08:18:45.292037+00:00*** Killing all processes…
2025-05-07 08:18:45.292409+00:00May 7 08:18:45 7dbb0db057ce syslog-ng[12]: syslog-ng shutting down; version=‘3.35.1’
2025-05-07 08:18:49.288608+00:00*** Running /etc/my_init.d/10_syslog-ng.init…
2025-05-07 08:18:49.311604+00:00May 7 08:18:49 7dbb0db057ce syslog-ng[12]: syslog-ng starting up; version=‘3.35.1’
2025-05-07 08:18:50.309217+00:00*** Running /etc/my_init.d/arm_user_files_setup.sh…
2025-05-07 08:18:50.311789+00:00Updating arm group id 1000 to default (1000)…
2025-05-07 08:18:50.314556+00:00usermod: no changes
2025-05-07 08:18:50.314747+00:00Updating arm group id 1000 to default (1000)…
2025-05-07 08:18:50.321004+00:00Adding arm user to ‘render’ group
2025-05-07 08:18:50.342498+00:00Checking ownership of /home/arm
2025-05-07 08:18:50.342534+00:00---------------------------------------------
2025-05-07 08:18:50.342543+00:00[ERROR]: ARM does not have permissions to /home/arm using 1000:1000
2025-05-07 08:18:50.342551+00:00Check your user permissions and restart ARM. Folder permissions–> 0:0
2025-05-07 08:18:50.342571+00:00---------------------------------------------
2025-05-07 08:18:50.342701+00:00*** /etc/my_init.d/arm_user_files_setup.sh failed with status 1
2025-05-07 08:18:50.342731+00:002025-05-07T08:18:50.342731978Z
2025-05-07 08:18:50.342776+00:00*** Killing all processes…
2025-05-07 08:18:50.342972+00:00May 7 08:18:50 7dbb0db057ce syslog-ng[12]: syslog-ng shutting down; version=‘3.35.1’
2025-05-07 08:18:54.420816+00:00*** Running /etc/my_init.d/10_syslog-ng.init…
2025-05-07 08:18:54.445461+00:00May 7 08:18:54 7dbb0db057ce syslog-ng[12]: syslog-ng starting up; version=‘3.35.1’
2025-05-07 08:18:55.441931+00:00*** Running /etc/my_init.d/arm_user_files_setup.sh…
2025-05-07 08:18:55.444318+00:00Updating arm group id 1000 to default (1000)…
2025-05-07 08:18:55.446953+00:00usermod: no changes
2025-05-07 08:18:55.447186+00:00Updating arm group id 1000 to default (1000)…
2025-05-07 08:18:55.453012+00:00Adding arm user to ‘render’ group
2025-05-07 08:18:55.475732+00:00Checking ownership of /home/arm
2025-05-07 08:18:55.475775+00:00---------------------------------------------
2025-05-07 08:18:55.475803+00:00[ERROR]: ARM does not have permissions to /home/arm using 1000:1000
2025-05-07 08:18:55.475811+00:00Check your user permissions and restart ARM. Folder permissions–> 0:0
2025-05-07 08:18:55.475819+00:00---------------------------------------------
2025-05-07 08:18:55.475980+00:00*** /etc/my_init.d/arm_user_files_setup.sh failed with status 1
2025-05-07 08:18:55.476015+00:002025-05-07T08:18:55.476015865Z
2025-05-07 08:18:55.476042+00:00*** Killing all processes…
2025-05-07 08:18:55.476447+00:00May 7 08:18:55 7dbb0db057ce syslog-ng[12]: syslog-ng shutting down; version=‘3.35.1’
2025-05-07 08:18:59.521397+00:00*** Running /etc/my_init.d/10_syslog-ng.init…
2025-05-07 08:18:59.544543+00:00May 7 08:18:59 7dbb0db057ce syslog-ng[12]: syslog-ng starting up; version=‘3.35.1’
2025-05-07 08:19:00.541040+00:00*** Running /etc/my_init.d/arm_user_files_setup.sh…
2025-05-07 08:19:00.543306+00:00Updating arm group id 1000 to default (1000)…
2025-05-07 08:19:00.545852+00:00usermod: no changes
2025-05-07 08:19:00.546083+00:00Updating arm group id 1000 to default (1000)…
2025-05-07 08:19:00.553322+00:00Adding arm user to ‘render’ group
2025-05-07 08:19:00.578850+00:00Checking ownership of /home/arm
2025-05-07 08:19:00.578893+00:00---------------------------------------------
2025-05-07 08:19:00.578905+00:00[ERROR]: ARM does not have permissions to /home/arm using 1000:1000
2025-05-07 08:19:00.578930+00:00Check your user permissions and restart ARM. Folder permissions–> 0:0
2025-05-07 08:19:00.578942+00:00---------------------------------------------
2025-05-07 08:19:00.579035+00:00*** /etc/my_init.d/arm_user_files_setup.sh failed with status 1
2025-05-07 08:19:00.579057+00:002025-05-07T08:19:00.579057336Z
2025-05-07 08:19:00.579077+00:00*** Killing all processes…
2025-05-07 08:19:00.579507+00:00May 7 08:19:00 7dbb0db057ce syslog-ng[12]: syslog-ng shutting down; version=‘3.35.1’
2025-05-07 08:19:04.625918+00:00*** Running /etc/my_init.d/10_syslog-ng.init…
2025-05-07 08:19:04.648218+00:00May 7 08:19:04 7dbb0db057ce syslog-ng[12]: syslog-ng starting up; version=‘3.35.1’
2025-05-07 08:19:05.645451+00:00*** Running /etc/my_init.d/arm_user_files_setup.sh…
2025-05-07 08:19:05.647892+00:00Updating arm group id 1000 to default (1000)…
2025-05-07 08:19:05.650488+00:00usermod: no changes
2025-05-07 08:19:05.650738+00:00Updating arm group id 1000 to default (1000)…
2025-05-07 08:19:05.656263+00:00Adding arm user to ‘render’ group
2025-05-07 08:19:05.676896+00:00Checking ownership of /home/arm
2025-05-07 08:19:05.676934+00:00---------------------------------------------
2025-05-07 08:19:05.676943+00:00[ERROR]: ARM does not have permissions to /home/arm using 1000:1000
2025-05-07 08:19:05.676951+00:00Check your user permissions and restart ARM. Folder permissions–> 0:0
2025-05-07 08:19:05.677042+00:00---------------------------------------------
2025-05-07 08:19:05.677091+00:00*** /etc/my_init.d/arm_user_files_setup.sh failed with status 1
2025-05-07 08:19:05.677107+00:002025-05-07T08:19:05.677107082Z
2025-05-07 08:19:05.677140+00:00*** Killing all processes…
2025-05-07 08:19:05.677381+00:00May 7 08:19:05 7dbb0db057ce syslog-ng[12]: syslog-ng shutting down; version=‘3.35.1’
It seems the container tries to set permissions and fails to do so
So take look at the dataset permissions you’re trying to use and add UID and GUID 1000 to the permissions.
how do I do that?
I got the new ver working but dose not see my dvd drives.
I can not find a way to add the dvd drives.
Did you ever find a solution to adding DVD Drives? I thought I did it correctly with the CDROM devices but I dont see them in the WebUI
