I have installed 2 x 1 TB NVMe SSDs in my Truenas scale system. The purpose it to speed up access to plex. I understand that the reason it is so sluggish is because it is accessing the config files on an NFS drive. However, in asking chatgpt, it is suggesting I make a mirror special VDEV that would then be used to speed lots of things up in addtion to plex. I just found out there is also something called a SLOG which I know nothing about. Anyway I appreciate any suggestions on how to go about using these drives most effectively. Thanks.
Just make a mirror pool/vdev from the two nvme and save your plex metadata to it.
Don’t forget to map the transcode directory to rust or RAM.
You don’t need any special vdevs.
ChatGPT is (literally) an idiot.
@Jorsher has it right. Create an apps-pool on the mirrored 1TB MVMe drives, install Plex on it. Store your Plex metadata in a dataset on this pool. Set your transcode to another dedicated dataset on this pool too.
SLOG is, exclusively, for sync writes. No help with reading.
And synchronous writes are a performance killer - if you are doing them you should eliminate them except where absolutely necessary (e.g. virtual disks, zVols, iSCSI, transactional database files).
