Bonding doesn't work
Hello All,
I try to create a bonding on my system everything is OK on the switch (Aruba 1830) the trunk is up and the 2 interfaces are active and on the system everything is OK about network configuration too.
On my system I’ve 4 interfaces, one is used in a VLAN, there are identical.
I tried 2 modes LACP and LOADBALANCE but none work.
I checked my BIOS configuration everything is OK, secure boot is disabled.
Below log of the system :
root@truenas[~]# cat /proc/net/bonding/bond1
Ethernet Channel Bonding Driver: v6.12.33-production+truenas
Bonding Mode: load balancing (xor)
Transmit Hash Policy: layer2 (0)
MII Status: up
MII Polling Interval (ms): 0
Up Delay (ms): 0
Down Delay (ms): 0
Peer Notification Delay (ms): 0
Slave Interface: enp3s0
MII Status: up
Speed: 1000 Mbps
Duplex: full
Link Failure Count: 0
Permanent HW addr: a8:b8:e0:06:23:5e
Slave queue ID: 0
Slave Interface: enp4s0
MII Status: up
Speed: 1000 Mbps
Duplex: full
Permanent HW addr: a8:b8:e0:06:23:5f
Slave queue ID: 0
Log of /var/log/messages :
Nov 10 10:58:34 truenas kernel: bond1: (slave enp3s0): Enslaving as an active interface with an up link
Nov 10 10:58:34 truenas kernel: bond1: (slave enp4s0): Enslaving as an active interface with an up link
Nov 10 10:58:37 truenas kernel: igc 0000:02:00.0 enp2s0: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX/TX
Nov 10 10:58:37 truenas kernel: igc 0000:04:00.0 enp4s0: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
Nov 10 10:58:41 truenas kernel: igc 0000:03:00.0 enp3s0: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
root@truenas[~]# ifconfig -a
bond1: flags=5187<UP,BROADCAST,RUNNING,MASTER,MULTICAST> mtu 1500
inet X.X.X.X netmask 255.255.255.0 broadcast X.X.X.X
inet6 fe80::aab8:e0ff:fe06:235e prefixlen 64 scopeid 0x20
ether a8:b8:e0:06:23:5e txqueuelen 1000 (Ethernet)
RX packets 36 bytes 13110 (12.8 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 83 bytes 17696 (17.2 KiB)
TX errors 0 dropped 6 overruns 0 carrier 0 collisions 0
enp2s0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet6 fe80::aab8:e0ff:fe06:235d prefixlen 64 scopeid 0x20
ether a8:b8:e0:06:23:5d txqueuelen 1000 (Ethernet)
RX packets 1377 bytes 211937 (206.9 KiB)
TX packets 1122 bytes 196652 (192.0 KiB)
TX errors 0 dropped 1 overruns 0 carrier 0 collisions 0
device memory 0x83700000-837fffff
enp3s0: flags=6211<UP,BROADCAST,RUNNING,SLAVE,MULTICAST> mtu 1500
RX packets 0 bytes 0 (0.0 B)
TX packets 7 bytes 4882 (4.7 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device memory 0x82d00000-82dfffff
enp4s0: flags=6211<UP,BROADCAST,RUNNING,SLAVE,MULTICAST> mtu 1500
TX packets 76 bytes 12814 (12.5 KiB)
device memory 0x82300000-823fffff
enp5s0: flags=4098<BROADCAST,MULTICAST> mtu 1500
ether a8:b8:e0:06:23:60 txqueuelen 1000 (Ethernet)
TX packets 0 bytes 0 (0.0 B)
device memory 0x81900000-819fffff
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1000 (Local Loopback)
RX packets 1127 bytes 171617 (167.5 KiB)
TX packets 1127 bytes 171617 (167.5 KiB)
Thank you in advance for your help.
smokyrun
I don’t know LACP / Bonding that well, however, routing could be a problem. Some people are unaware that multiple network interfaces in the same sub-net won’t necessarily route as they expect.
You don’t list the IPv4 addresses of your “enp2s0” and “bond1” interfaces. But, if they are in the same sub-net, outbound traffic will likely only use the lower numbered address and it’s interface.
Now if both “enp2s0” and “bond1” are on different IPv4 sub-nets, then I don’t know what could be wrong.
Thank you for your reply, the interfaces enp2s0 and bond1 are in two different subnet, I don’t think that is a routing problem because if I remove the bond1 and configure a single interface with the same address than the bond1 everything works fine.
I know well bonding configuration, I can’t see what could be wrong, the configuration on the switch is OK, I rebooted both switch and the server but the problem persist.
As ether-channel is a software configuration the problem seems does’nt come from to the network devices.
In my experience bonding only works reliably if both ends speak LACP. That’s what I run everywhere including TrueNAS and it’s working as intended.
Why did you pick “xor”? Doesn’t the switch support LACP?
Yes the switch LACP and STATIC mode, on my screenshot I configured the TRUNK in STATIC mode with LOADBALANCE algorithm I tried the LACP mode but with the same issue.
This configuration is working perfectly well with a Mikrotik switch running RouterOS at the other end.
/interface bonding
add comment="TrueNAS CE" lacp-rate=1sec min-links=1 mode=802.3ad name=bonding1 slaves=ether21,ether22 transmit-hash-policy=layer-2-and-3
I have four 1 Gbps ports, one is configured for my iDrac, and the other three are bonded to a HP 2530-8G-PoEP Switch (J9774A) also Aruba with no issues.
I am on Truenas version 25.04.2.4.
Thank you for your replies, I add the same parameter as beside but I can’t access to the bond interface :
root@truenas[~]# cat /proc/net/bonding/bond0
Bonding Mode: IEEE 802.3ad Dynamic link aggregation
Transmit Hash Policy: layer2+3 (2)
MII Status: up
MII Polling Interval (ms): 100
Up Delay (ms): 0
Down Delay (ms): 0
802.3ad info
LACP active: on
LACP rate: fast
Min links: 0
Aggregator selection policy (ad_select): stable
System priority: 65535
System MAC address: a8:b8:e0:06:23:5e
Active Aggregator Info:
Aggregator ID: 1
Number of ports: 2
Actor Key: 9
Partner Key: 1000
Partner Mac Address: 34:c5:15:cd:ca:40
MII Status: up
Speed: 1000 Mbps
Duplex: full
Slave queue ID: 0
Aggregator ID: 1
Actor Churn State: none
Partner Churn State: none
Actor Churned Count: 0
Partner Churned Count: 0
details actor lacp pdu:
system priority: 65535
system mac address: a8:b8:e0:06:23:5e
port key: 9
port priority: 255
port number: 1
port state: 63
details partner lacp pdu:
system priority: 1
system mac address: 34:c5:15:cd:ca:40
oper key: 1000
port priority: 1
port number: 1
port state: 61
MII Status: up
Speed: 1000 Mbps
Duplex: full
Slave queue ID: 0
Aggregator ID: 1
port key: 9
port priority: 255
port number: 2
port state: 63
system priority: 1
oper key: 1000
port priority: 1
port number: 2
port state: 61
root@truenas[~]# tail /var/log/messages
Nov 10 21:05:11 truenas kernel: bond1 (unregistering): (slave enp4s0): Releasing backup interface
Nov 10 21:05:11 truenas kernel: bond1 (unregistering): Released all slaves
Nov 10 21:06:30 truenas kernel: bond0: (slave enp3s0): Enslaving as a backup interface with a down link
Nov 10 21:06:30 truenas kernel: bond0: (slave enp4s0): Enslaving as a backup interface with a down link
Nov 10 21:06:33 truenas kernel: igc 0000:03:00.0 enp3s0: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
Nov 10 21:06:33 truenas kernel: bond0: (slave enp3s0): link status definitely up, 1000 Mbps full duplex
Nov 10 21:06:33 truenas kernel: bond0: Warning: No 802.3ad response from the link partner for any adapters in the bond
Nov 10 21:06:33 truenas kernel: bond0: active interface up!
Nov 10 21:06:37 truenas kernel: igc 0000:04:00.0 enp4s0: NIC Link is Up 1000 Mbps Full Duplex, Flow Control: RX
Nov 10 21:06:37 truenas kernel: bond0: (slave enp4s0): link status definitely up, 1000 Mbps full duplex
On the messages log I have this message “truenas kernel: bond0: Warning: No 802.3ad response from the link partner for any adapters in the bond
The configuration is OK and very easy on the Aruba switch.
My Truenas version is : 25.10.0 - Goldeye
Hello All,
Everything works fine now, the problem come from about an incorrect configuration on the switch, I created a new VLAN (2) I added the 2 ports in this VLAN but the Trunk configuration stayed in VLAN 1.
Thank you for your replies and your help, now everything works as I want :grinning_face:
smokyrun
