I’ve had to upgrade my hardware due to a recent failure.
I tested booting on the new motherboard successfully after initial replacement, but I’ve also replaced my GT610 with an Arc A310. The GT610 required the motherboard to be in CSM mode, the new card can work in UEFI.
After swapping to the new card and booting I get an error that it can’t load the kernel (/root/25.04.2.6/boot/vmlinuz-6.12.15-production+truenas has invalid signature).
Could this be related to Secureboot (I think I ended up doing a BIOS reset after the first test when working on another problem) or due to TrueNAS being installed in CSM mode?
Would installing over the current version from a fresh ISO be worthwhile? Can I import a 25.04.2 into a 25.10 install or would I be best matching versions and completing the version update I was planning pre-hardware death.
Thanks in advance for any advice you can offer.
