CallError iocage activate ZPOOL Please Help
Please help. My pool that I was using for Plex Plugin is showing degraded so created a new pool to back it up to. Now when I go into the jails tab or the plugin tab I get the following error.
eport_problem CallError
[EFAULT] Error occurred getting activated pool: Plex Plugin Plex Plugin Backup You have 2 poolsmarked active for iocage usage. Run “iocage activate ZPOOL” on the preferred pool.
When I try to run the command iocage activate I get the following error.
Error: Got unexpected extra arguments (Plugin Backup ZPOOL)
root@truenas[~]# root@truenas[~]# iocage activate Plex Plugin Backup ZPOOL
Usage: iocage activate [OPTIONS] ZPOOL
Try ‘iocage activate --help’ for help.
I cannot stop the jail even with the force command. Plex is working currently but I can not update. I’m stuc
I am running TrueNas-13.0-U6.2
Intel Core I5-8400 @2.80GHz
32 GB DDR 4 Ram
Truenas is installed on SSD
Both the original plex jail and the duplicate are on seperate SSD’s
Main SSD Died so when restarted errors went away. New issues in new post. Please delete this post.
