Can't offline a disk
Ok, so how do you run a smart test or can’t it be done now
From the cli
smartctl -t long /dev/sdX
Where X is your driveletter
Thanks, I was just going to ask that
It is seemingly running now
smartctl -a /dev/sdX
Will show you the results.
My TrueNAS gui doesn’t stay open for very long and when I checked I was logged out. Logging in again took me to the shell, but no actions or anything were showing How do I stay logged in while the test is running
Just check back on it later. It takes a while depending on the drive size. It will keep running the test in the background on the system.
Ok, but after it has finished where do I find the results of the smart test.
Also via cli or install the scrutiny app for a webui
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.12.33-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Western Digital Purple (Pro)
Device Model:     WDC WD10PURZ-85U8XY0
Serial Number:    WD-WCC4JFDM719T
LU WWN Device Id: 5 0014ee 215b9b049
Firmware Version: 01.01A01
User Capacity:    1,000,204,886,016 bytes [1.00 TB]
Rotation Rate:    5400 rpm
Device is:        In smartctl database 7.3/5528
ATA Version is:   ACS-2 (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Mon Feb 16 09:08:58 2026 GMT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
Self-test execution status:      ( 249) Self-test routine in progress...
                                        90% of test remaining.
data collection:                (13980) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        ( 159) minutes.
Conveyance self-test routine
recommended polling time:        (   5) minutes.
SCT capabilities:              (0x303d) SCT Status supported.
                                        SCT Data Table supported.
  1 Raw_Read_Error_Rate     0x002f   200   200   051    Pre-fail  Always       -       0
  3 Spin_Up_Time            0x0027   136   134   021    Pre-fail  Always       -       4183
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       69
  5 Reallocated_Sector_Ct   0x0033   200   200   140    Pre-fail  Always       -       0
  7 Seek_Error_Rate         0x002e   200   200   000    Old_age   Always       -       0
  9 Power_On_Hours          0x0032   069   069   000    Old_age   Always       -       22706
 10 Spin_Retry_Count        0x0032   100   253   000    Old_age   Always       -       0
 11 Calibration_Retry_Count 0x0032   100   253   000    Old_age   Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       67
192 Power-Off_Retract_Count 0x0032   200   200   000    Old_age   Always       -       61
193 Load_Cycle_Count        0x0032   200   200   000    Old_age   Always       -       7
194 Temperature_Celsius     0x0022   113   099   000    Old_age   Always       -       30
196 Reallocated_Event_Count 0x0032   200   200   000    Old_age   Always       -       0
197 Current_Pending_Sector  0x0032   200   200   000    Old_age   Always       -       0
198 Offline_Uncorrectable   0x0030   100   253   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       646
200 Multi_Zone_Error_Rate   0x0008   200   200   000    Old_age   Offline      -       0
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%     22697         -
# 2  Extended offline    Completed without error       00%     22696         -
# 3  Short offline       Completed without error       00%     22673         -
# 4  Short offline       Completed without error       00%     22649         -
# 5  Short offline       Completed without error       00%     22625         -
# 6  Short offline       Completed without error       00%     22602         -
# 7  Short offline       Completed without error       00%     22578         -
# 8  Short offline       Completed without error       00%     22554         -
# 9  Short offline       Completed without error       00%     22530         -
#10  Short offline       Completed without error       00%     22506         -
#11  Short offline       Completed without error       00%     22482         -
#12  Short offline       Completed without error       00%     22458         -
#13  Short offline       Completed without error       00%     22434         -
#14  Short offline       Completed without error       00%     22410         -
#15  Short offline       Completed without error       00%     22386         -
#16  Short offline       Completed without error       00%     22362         -
#17  Short offline       Completed without error       00%     22338         -
#18  Short offline       Completed without error       00%     22314         -
#19  Short offline       Completed without error       00%     22290         -
#20  Short offline       Completed without error       00%     22266         -
#21  Short offline       Completed without error       00%     22242         -
The above only provides legacy SMART information - try 'smartctl -x' for more
it is still running…
This tells you how long tests take (assuming an otherwise inactive drive), and smartctl -t returned with the estimated time of completion. Next time, write this down and come back some time later.
root@freenas[~]# smartctl -a /dev/sdg
Local Time is:    Mon Feb 16 16:09:57 2026 GMT
                                        was never started.
                                        been run.
                                        command.
                                        power-saving mode.
  9 Power_On_Hours          0x0032   069   069   000    Old_age   Always       -       22713
No Errors Logged
# 1  Extended offline    Completed without error       00%     22708         -
# 2  Short offline       Completed without error       00%     22697         -
# 3  Extended offline    Completed without error       00%     22696         -
# 4  Short offline       Completed without error       00%     22673         -
# 5  Short offline       Completed without error       00%     22649         -
# 6  Short offline       Completed without error       00%     22625         -
# 7  Short offline       Completed without error       00%     22602         -
# 8  Short offline       Completed without error       00%     22578         -
# 9  Short offline       Completed without error       00%     22554         -
#10  Short offline       Completed without error       00%     22530         -
#11  Short offline       Completed without error       00%     22506         -
#12  Short offline       Completed without error       00%     22482         -
#13  Short offline       Completed without error       00%     22458         -
#14  Short offline       Completed without error       00%     22434         -
#15  Short offline       Completed without error       00%     22410         -
#16  Short offline       Completed without error       00%     22386         -
#17  Short offline       Completed without error       00%     22362         -
#18  Short offline       Completed without error       00%     22338         -
#19  Short offline       Completed without error       00%     22314         -
#20  Short offline       Completed without error       00%     22290         -
#21  Short offline       Completed without error       00%     22266         -
I started the test at about 10 am, and it now about 4pm in the UK
ZFS Info:
Read Errors:
310
Write Errors:
0
Checksum Errors:
284
Because the disc is degraded and there so many errors, I want to remove it, format it and use for something else.
As TrueNAS won’t let me offline or replace it, can I just disconnect it, as that seems to be the only way I can think of.
Thanks
That amounts to destroying the pool, which may be acceptable if the content is only CCTV records.
:headstone:
Yes I thought as much but is there a better way
That error usually appears when the pool has no redundancy left. Since your pool only has two disks and one is already failing, TrueNAS won’t let you offline it because there isn’t a valid replica to keep the data safe.
Before removing anything, make sure you back up any important footage. After that, you can shut the system down and replace the failing drive, then use the replace/resilver option to rebuild the pool. If the pool was created without mirroring, you may need to recreate it after swapping the disk.
Ok thanks, but I removed the disk then used the 2Tb disc for the same pool. I then created the datasets as I had before.
The data isn’t or wasn’t important, as it is just local footage around my property
