Close to fixing /mnt/mnt problem but not quite
I’m sure some people are aware of the problem where when you import an existing pool, truenas prefixes another /mnt on your mounpoint causing /mnt/mnt/yourpoolname
I followed the intstructions from the other posts to manually set my mountpoint to /yourpoolname
and that does make things appear normally BUT I noticed that the original datasets don’t appear in the Truenas interface where I would expect them.
New datasets do appear though. How come?
  • I only see newly created datasets in the Dataset tab of truenas
  • smb shares section in the shares tab shows my two existing datasets with paths /mnt/zpool1/OSM images and /mnt/zpool1/other respectively. and they work
They do appear correctly in smb share menu and work?
truenas_admin@truenas[~]$ zfs list
NAME                                                         USED  AVAIL  REFER  MOUNTPOINT
boot-pool                                                   3.06G   141G    96K  none
boot-pool/.system                                           2.89M   141G   120K  legacy
boot-pool/.system/configs-ae32c386e13840b2bf9c0083275e7941    96K   141G    96K  legacy
boot-pool/.system/cores                                       96K  1024M    96K  legacy
boot-pool/.system/netdata-ae32c386e13840b2bf9c0083275e7941  2.11M   141G  2.11M  legacy
boot-pool/.system/nfs                                        112K   141G   112K  legacy
boot-pool/.system/samba4                                     288K   141G   288K  legacy
boot-pool/.system/vm                                          96K   141G    96K  legacy
boot-pool/ROOT                                              3.04G   141G    96K  none
boot-pool/ROOT/25.10.1                                      3.04G   141G   104M  legacy
boot-pool/ROOT/25.10.1/audit                                1.69M   141G  1.69M  /audit
boot-pool/ROOT/25.10.1/conf                                 7.54M   141G  7.54M  /conf
boot-pool/ROOT/25.10.1/data                                  288K   141G   288K  /data
boot-pool/ROOT/25.10.1/etc                                  7.45M   141G  6.48M  /etc
boot-pool/ROOT/25.10.1/home                                  108K   141G   108K  /home
boot-pool/ROOT/25.10.1/mnt                                   112K   141G   112K  /mnt
boot-pool/ROOT/25.10.1/opt                                  4.65M   141G  4.65M  /opt
boot-pool/ROOT/25.10.1/root                                  140K   141G   140K  /root
boot-pool/ROOT/25.10.1/usr                                  2.88G   141G  2.88G  /usr
boot-pool/ROOT/25.10.1/var                                  43.7M   141G  4.37M  /var
boot-pool/ROOT/25.10.1/var/ca-certificates                    96K   141G    96K  /var/local/ca-certificates
boot-pool/ROOT/25.10.1/var/lib                              28.5M   141G  28.1M  /var/lib
boot-pool/ROOT/25.10.1/var/lib/incus                          96K   141G    96K  /var/lib/incus
boot-pool/ROOT/25.10.1/var/log                              10.6M   141G  1.74M  /var/log
boot-pool/ROOT/25.10.1/var/log/journal                      8.87M   141G  8.87M  /var/log/journal
boot-pool/grub                                              9.02M   141G  9.02M  legacy
zpool1                                                      32.7T  70.6T  32.7T  /mnt/zpool1
zpool1/Panoramax-OSMBE                                       205K  70.6T   205K  /mnt/zpool1/Panoramax-OSMBE
zpool2_less-critical                                        1.18M  64.2T   162K  /mnt/zpool2_less-critical
truenas_admin@truenas[~]$ sudo zfs get -t filesystem -r mountpoint zpool1
[sudo] password for truenas_admin:
NAME                    PROPERTY    VALUE                        SOURCE
zpool1                  mountpoint  /mnt/zpool1                  local
zpool1/Panoramax-OSMBE  mountpoint  /mnt/zpool1/Panoramax-OSMBE  inherited from zpool1
I do see that I can ‘upgrade’ the zfs on my pool but not sure if that’s the solution to this problem or not.
hey,
just fyi, if you use code-blocks like the following it will be easier to read your pastes.
NAME…
just to make things more clear here:
... <SNIP>
you should be able to see the difference with newly created datasets from the commands you used. Your post only has one child-dataset listed (zpool1/Panoramax-OSMBE) so that’s hard to differentiate.
i will make a guess here and say that these paths are “real” paths and no datasets at all.
you can verify it in the shell easily with something like this
df -h /mnt/zpool1/OSM
# which will return something like this if i'm correct in that assumption
Filesystem           Size  Used Avail Use% Mounted on
zpool1  11T   99G   11T   1% /mnt/zpool1
Otherwise please provide a full report of
  • zfs list -o name,mountpoint -r zpool1 zpool2_less-critical
    or/and
  • zfs get -d3 -t filesystem mountpoint zpool1 zpool2_less-critical
As an example how it usually looks
root@nas-01 /mnt/p0-25-8z2/temporaer # zfs get mountpoint -t filesystem -d 2 p0-25-8z2/pve
p0-25-8z2/pve              mountpoint  /mnt/p0-25-8z2/pve              default
p0-25-8z2/pve/iscsi        mountpoint  /mnt/p0-25-8z2/pve/iscsi        default
p0-25-8z2/pve/nfs          mountpoint  /mnt/p0-25-8z2/pve/nfs          default
p0-25-8z2/pve/nfs/disks    mountpoint  /mnt/p0-25-8z2/pve/nfs/disks    default
p0-25-8z2/pve/nfs/iso      mountpoint  /mnt/p0-25-8z2/pve/nfs/iso      default
Notice the difference in the SOURCE tab
my bad for the formatting. I selected all the text and used the code block formatting button but I guess it applied wrong? I’ll use markdown formatting then (EDIT: upped trust level, now I fixed my original post)
df -h "/mnt/zpool1/OSM images"
zpool1          104T   33T   71T  32% /mnt/zpool1
NAME                    MOUNTPOINT
zpool1                  /mnt/zpool1
zpool1/Panoramax-OSMBE  /mnt/zpool1/Panoramax-OSMBE
zpool2_less-critical    /mnt/zpool2_less-critical
zpool2_less-critical    mountpoint  /mnt/zpool2_less-critical    default
It’s weird, they were datasets on my original truenas install…
well, i can’t tell you how you arrived at this but i’m guessing this was already happening on the other system where that pool is originaly from.
I would recommend just (r)syncing/copying the data to another pool if you have enough space left or to another system, recreate the pool and then start fresh.
It can be done manually but i think this will be the easier and cleaner way.
Just to make this thread as solved, I’ll be just be doing this. Starting fresh (have some spare hdd’s to copy data to). thx
