Children dataset consume too much data
why the children dataset consume so much data, how could I delete that?
Dataset Name
Used / Available
Encryption
Roles
NAS
969.07 GiB / 1023.9 MiB
Unencrypted
ix-applications
4.26 GiB / 2.57 TiB
Unencrypted
NAS
865.62 GiB / 2.57 TiB
Unencrypted
Sigh. :pensive:
You might be want to post screenshots or photos of the GUI window. If you are running CLI or command line interface commands, you can post it back using preformatted text (</> or Ctrl+e) on the reply box or text window.
What applications do you have and where are you storing their data? You need to give us as much info as possilble. We can only go off what is provided and can’t see what you see on the system.
i cannot import the media
ix-applications for tailscale and immich
my smb share used to be 3.5tb but now is 2.5
Immich is probably storing it’s data in ix-applications and not in an outside dataset. Check your Immich configuration.
You will have to use the command line (CLI) to look through those folders and see what is taking up disk space. You might have some luck browsing the forums for ‘Immich’ and any disk space related posts.
@Kevin_Wong
I think we can all appreciate that English is probably not your main language, but you are really not giving us the information we need to help you. Can you please open a command shell and run the following commands, and then copy and paste the responses from each command into its own </> box here:
  • lsblk -bo NAME,LABEL,MAJ:MIN,TRAN,ROTA,ZONED,VENDOR,MODEL,SERIAL,PARTUUID,START,SIZE,PARTTYPENAME
  • /sbin/zpool status -vLtsc lsblk,serial,smartx,smart
  • sudo zpool import
  • /sbin/zpool list -v
  • /sbin/zfs list
where is the shell in immich or just click the shell in menu of truenas?
TrueNAS shell.
truenas_admin@truenas[~]$ lsblk -bo NAME,LABEL,MAJ:MIN,TRAN,ROTA,ZONED,VENDOR,MODEL,SERIAL,PARTUUID,START,SIZE,PARTTYPENAME
NAME        LABEL     MAJ:MIN TRAN   ROTA ZONED VENDOR   MODEL              SERIAL        PARTUUID                                START          SIZE PARTTYPENAME
sda                     8:0   sata      1 none  ATA      ST4000VN008-2DR166 Z9LNNEXE                                                    4000787030016
└─sda1      NAS         8:1             1 none                                            99ad68ee-5241-4152-aceb-eadcfbc4bd23     4096 4000784056832 Solaris /usr & Apple ZFS
sdb                     8:16  sata      1 none  ATA      ST4000VN008-2DR166 Z9LNNFVO                                                    4000787030016
└─sdb1      NAS         8:17            1 none                                            ba0e22b7-62a3-4cca-945b-ad6855684409     4096 4000784056832 Solaris /usr & Apple ZFS
nvme0n1               259:0   nvme      0 none           KINGBANK KP230     LJ6232R012265                                                120034123776
├─nvme0n1p1           259:1   nvme      0 none                                            55c33583-f4db-11ee-8b26-00e269671c74       40     272629760 EFI System
├─nvme0n1p2 boot-pool 259:2   nvme      0 none                                            55c6d2b7-f4db-11ee-8b26-00e269671c74 34086952  102575898624 FreeBSD ZFS
└─nvme0n1p3           259:3   nvme      0 none                                            55c55efe-f4db-11ee-8b26-00e269671c74   532520   17179869184 FreeBSD swap
truenas_admin@truenas[~]$ sudo zpool import
[sudo] password for truenas_admin:
no pools available to import
truenas_admin@truenas[~]$ /sbin/zpool list -v
NAME                                       SIZE  ALLOC   FREE  CKPOINT  EXPANDSZ   FRAG    CAP  DEDUP    HEALTH  ALTROOT
NAS                                       3.62T   822G  2.82T        -         -     8%    22%  1.00x    ONLINE  /mnt
  mirror-0                                3.62T   822G  2.82T        -         -     8%  22.1%      -    ONLINE
    99ad68ee-5241-4152-aceb-eadcfbc4bd23  3.64T      -      -        -         -      -      -      -    ONLINE
    ba0e22b7-62a3-4cca-945b-ad6855684409  3.64T      -      -        -         -      -      -      -    ONLINE
boot-pool                                 95.5G  6.51G  89.0G        -       16G    29%     6%  1.00x    ONLINE  -
  nvme0n1p2                               95.5G  6.51G  89.0G        -       16G    29%  6.81%      -    ONLINE
truenas_admin@truenas[~]$ /sbin/zfs list
NAME                                                         USED  AVAIL  REFER  MOUNTPOINT
NAS                                                          822G  2.71T   104K  /mnt/NAS
NAS/NAS                                                      782G  2.71T   782G  /mnt/NAS/NAS
NAS/ix-apps                                                 40.3G  2.71T   112K  /mnt/.ix-apps
NAS/ix-apps/app_configs                                     7.95M  2.71T  7.95M  /mnt/.ix-apps/app_configs
NAS/ix-apps/app_mounts                                       149M  2.71T    96K  /mnt/.ix-apps/app_mounts
NAS/ix-apps/app_mounts/immich                                149M  2.71T    96K  /mnt/.ix-apps/app_mounts/immich
NAS/ix-apps/app_mounts/immich/data                          14.8M  2.71T  14.8M  /mnt/.ix-apps/app_mounts/immich/data
NAS/ix-apps/app_mounts/immich/postgres_data                  134M  2.71T   134M  /mnt/.ix-apps/app_mounts/immich/postgres_data
NAS/ix-apps/app_mounts/tailscale                             300K  2.71T    96K  /mnt/.ix-apps/app_mounts/tailscale
NAS/ix-apps/app_mounts/tailscale/state                       204K  2.71T   136K  /mnt/.ix-apps/app_mounts/tailscale/state
NAS/ix-apps/docker                                          40.0G  2.71T  40.0G  /mnt/.ix-apps/docker
NAS/ix-apps/truenas_catalog                                  190M  2.71T   190M  /mnt/.ix-apps/truenas_catalog
boot-pool                                                   6.51G  86.0G    24K  none
boot-pool/.system                                           1.56G  86.0G  1.55G  legacy
boot-pool/.system/configs-ae32c386e13840b2bf9c0083275e7941    24K  86.0G    24K  legacy
boot-pool/.system/cores                                       24K  1024M    24K  legacy
boot-pool/.system/netdata-ae32c386e13840b2bf9c0083275e7941  11.5M  86.0G  11.5M  legacy
boot-pool/.system/nfs                                         28K  86.0G    28K  legacy
boot-pool/.system/samba4                                      78K  86.0G    78K  legacy
boot-pool/ROOT                                              4.85G  86.0G    24K  none
boot-pool/ROOT/24.10.0                                      2.37G  86.0G   165M  legacy
boot-pool/ROOT/24.10.0/conf                                 6.50M  86.0G  6.50M  /conf
boot-pool/ROOT/24.10.0/data                                 7.50M  86.0G  7.50M  /data
boot-pool/ROOT/24.10.0/etc                                  3.60M  86.0G  3.20M  /etc
boot-pool/ROOT/24.10.0/home                                   31K  86.0G    31K  /home
boot-pool/ROOT/24.10.0/usr                                  1.80G  86.0G  1.80G  /usr
boot-pool/ROOT/24.10.0/var                                   393M  86.0G  18.5M  /var
boot-pool/ROOT/24.10.0/var/ca-certificates                    24K  86.0G    24K  /var/local/ca-certificates
boot-pool/ROOT/24.10.0/var/log                               374M  86.0G   371M  /var/log
boot-pool/ROOT/24.10.0/var/log/journal                      3.75M  86.0G  3.75M  /var/log/journal
boot-pool/ROOT/25.04.1-2                                    2.48G  86.0G   173M  legacy
boot-pool/ROOT/25.04.1-2/audit                              1.18M  86.0G  1.18M  /audit
boot-pool/ROOT/25.04.1-2/conf                               6.70M  86.0G  6.70M  /conf
boot-pool/ROOT/25.04.1-2/data                               7.49M  86.0G  7.49M  /data
boot-pool/ROOT/25.04.1-2/etc                                3.47M  86.0G  3.06M  /etc
boot-pool/ROOT/25.04.1-2/home                               31.5K  86.0G  31.5K  /home
boot-pool/ROOT/25.04.1-2/mnt                                  25K  86.0G    25K  /mnt
boot-pool/ROOT/25.04.1-2/opt                                  24K  86.0G    24K  /opt
boot-pool/ROOT/25.04.1-2/root                                127K  86.0G   127K  /root
boot-pool/ROOT/25.04.1-2/usr                                2.27G  86.0G  2.27G  /usr
boot-pool/ROOT/25.04.1-2/var                                28.8M  86.0G  3.91M  /var
boot-pool/ROOT/25.04.1-2/var/ca-certificates                  24K  86.0G    24K  /var/local/ca-certificates
boot-pool/ROOT/25.04.1-2/var/lib                            15.3M  86.0G  15.2M  /var/lib
boot-pool/ROOT/25.04.1-2/var/lib/incus                        24K  86.0G    24K  /var/lib/incus
boot-pool/ROOT/25.04.1-2/var/log                            9.20M  86.0G  2.91M  /var/log
boot-pool/ROOT/25.04.1-2/var/log/journal                    6.29M  86.0G  6.29M  /var/log/journal
boot-pool/grub                                              1.91M  86.0G  1.91M  legacy
truenas_admin@truenas[~]$ /sbin/zpool status -vLtsc lsblk,serial,smartx,smart
  pool: NAS
 state: ONLINE
  scan: scrub repaired 0B in 01:29:00 with 0 errors on Sun Jun 15 01:29:02 2025
        NAME        STATE     READ WRITE CKSUM  SLOW    size  vendor               model         serial  hours_on  pwr_cyc  health  realloc  rep_ucor  cmd_to  temp  pend_sec  off_ucor  ata_err  nvme_err
        NAS         ONLINE       0     0     0     -
          mirror-0  ONLINE       0     0     0     -
            sda1    ONLINE       0     0     0     0    3.6T     ATA  ST4000VN008-2DR166       Z9LNNEXE     10105       18  PASSED        0         0       0    36         0         0        -         -  (trim unsupported)
            sdb1    ONLINE       0     0     0     0    3.6T     ATA  ST4000VN008-2DR166       Z9LNNFVO     10105       17  PASSED        0         0       0    36         0         0        -         -  (trim unsupported)
errors: No known data errors
  pool: boot-pool
 state: ONLINE
status: One or more features are enabled on the pool despite not being
        requested by the 'compatibility' property.
action: Consider setting 'compatibility' to an appropriate value, or
        adding needed features to the relevant file in
        /etc/zfs/compatibility.d or /usr/share/zfs/compatibility.d.
  scan: scrub repaired 0B in 00:00:57 with 0 errors on Tue Jun 24 03:45:59 2025
        boot-pool    ONLINE       0     0     0     -
          nvme0n1p2  ONLINE       0     0     0     0  111.8G       -      KINGBANK KP230  LJ6232R012265     17622      268  PASSED        -         -       -    42         -         -        -         0  (untrimmed)
Can you do a screenshot of the GUI where you think there is a problem with ‘Children’? Try to do almost the entire TrueNAS GUI so we can see what sections, windows and data you are looking at.
I am guessing your root pool is called NAS and you have a child dataset named NAS and that is what you think is the problem?
so i solve the problem by deled dataset and make a new one I have backuped the data thank you for solving my truenas problem
Anytime. It was a pleasure.
TL;DR summary
I think that this is simply a misunderstanding of what “available space” means - it means free space available for more data and NOT total space, so I don’t think that there is any technical problem, and so backing everything up and destroying / recreating the pool will not do anything.
Analysis
The pool consists of a mirror of 2x 4TB Ironwolf HDDs - converting this to TiB by deducting 9% means there will be c. 3.64TiB of useable space in the pool - that’s the total space in the pool - and this is what the zpool list shows.
The NAS/NAS dataset has 732GiB of data in it - but you also need to add to this the space used by the hidden TrueNAS ix-apps dataset (as shown by the zfs list command) which is using 40.3GiB. Total used is thus 822GiB or 0.822TiB and deducting this from 3.64TiB leaves you c. 2.82TiB and this is exactly what is shown in the zpool list. Yes - this is different from the 2.71TiB shown as being free in the zfs list and UI, however that can be accounted for by e.g. zfs list only estimating the amount of data that can be stored (whereas zpool list shows the accurate count of blocks that are free) and I am guessing that it is estimating e.g. metadata overheads.
So, I don’t think that there is any technical problem to be resolved.
P.S.
Lol. Literally all you did was sigh at the very beginning of the thread!!! :rofl:
See here.
