hello,
I have a big problem with truenas scale.
While copying files to the truenas after few seconds copying speed drops
to the drastic level. Like on the picture
Is about every files I try to copy not only when there is a lot of small but the big one.
Hi, it looks a bit like the one I just posted, except that it seems to occur more quickly for you and that the numbers are even worse, but you have half the ram and ethernet speed even if not relatd. It might be the same base issue.
Ah yes, depends on which SSD’s, but some can quickly degrade in write sequential speed after a few Gigs. That’s seemingly what you are hitting there if it works fine with a rotational disk, so not my issue at all in the end.
Not necessarily, I have some SSD’s (entry level like PNY for example…) which have the same behaviour although health is fine like 90+% reported by HD Sentinel.
