Hi guys,
After many year lying dormant, I’ve managed to install TrueNAS Core onto my old HP Datavault X510/Mediaserver EX495.
It’s running just fine on 2GB RAM believe it or not.
however,
if I leave it running overnight and then try to log into the dashboard in the morning, it won’t connect. I enter username and password and it just hangs.
I can access files on PLEX and using SAMBA, just can’t connect to the dashboard.
A slight complication is that these boxes were headless, so no video connection to access the BIOS.
Any ideas? Or do I simply power down every night?
Thanks in advance
Your system is most likely memory starved. there’s a reason why 8gb is the bare miminum required without running services like plex on it. My guess would be that the system kills of processes to free memory and therefore kills off part of the webui.
