Hi, I upgraded to 25.10, and I decided to go back as I have no dedicated GPU, just a single integrated graphics which I was using for the VM in 25.04.2.6.
After the upgrade I followed the migrating VM’s instructions and renamed the .block from data/.ix-virt/*.block to data/vm/*.block.
Now, If I want to downgrade, should I rename this back again for my VM’s to work as it is?
