Hi, Thank you for the response. The VM is operational now.
I added an RTX 3060 Ti to my NAS and isolated the GPU in the system settings of truenas, and when I passed the GPU to the VM, I got the below error and the VM doesn’t even showup in the Virtual machines menu.
XML error: Hostdev already exists in the domain configuration
Error Name: EFAULT
Error Code: 14
Reason: [EFAULT] Unable to define domain for mediaserver2024: XML error: Hostdev already exists in the domain configuration
Error Class: CallError
Trace: Traceback (most recent call last):
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 45, in _check_add_domain
self._add(self._vm_from_name(vm_name)['id'])
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 16, in _add
self._add_with_vm_data(vm)
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 19, in _add_with_vm_data
self.vms[vm['name']] = VMSupervisor(vm, self.middleware)
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py", line 30, in __init__
self.update_domain()
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py", line 66, in update_domain
self.__define_domain()
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py", line 99, in __define_domain
if not self.LIBVIRT_CONNECTION.defineXML(vm_xml):
File "/usr/lib/python3/dist-packages/libvirt.py", line 4495, in defineXML
raise libvirtError('virDomainDefineXML() failed')
libvirt.libvirtError: XML error: Hostdev already exists in the domain configuration
File "/usr/lib/python3/dist-packages/middlewared/api/base/server/ws_handler/rpc.py", line 361, in process_method_call
result = await method.call(app, id_, params)
File "/usr/lib/python3/dist-packages/middlewared/api/base/server/method.py", line 57, in call
result = await self.middleware.call_with_audit(self.name, self.serviceobj, methodobj, params, app,
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 956, in call_with_audit
result = await self._call(method, serviceobj, methodobj, params, app=app,
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 773, in _call
File "/usr/lib/python3/dist-packages/middlewared/api/base/decorator.py", line 108, in wrapped
result = await func(*args)
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_lifecycle.py", line 57, in start
await self.middleware.run_in_thread(self._start, vm['name'])
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 670, in run_in_thread
return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs)
File "/usr/lib/python3/dist-packages/middlewared/main.py", line 667, in run_in_executor
File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 67, in _start
self._check_add_domain(vm_name)
File "/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py", line 47, in _check_add_domain
raise CallError(f'Unable to define domain for {vm_name}: {e}')
middlewared.service_exception.CallError: [EFAULT] Unable to define domain for mediaserver2024: XML error: Hostdev already exists in the domain configuration
Can I know how do I proceed from here.
