Drive reported failed, extremely slow resilvering, system does not boot
Hi!
I have a system built in 2023 with a simple ZFS mirror pool of 2x14TB drives from Seagate. The pool is named rust. The two drives have serial numbers:
I do not think it is relevant, but the system also has 4 SSDs: one for boot, 2 in mirror for important data, and 1 for L2ARC of the rust pool.
Yesterday, I got a notification from TrueNAS that one of the drives failed:
New alerts:
  * Pool rust state is DEGRADED: One or more devices are faulted in response to persistent errors. Sufficient replicas exist for the pool to continue functioning in a degraded state.
The following devices are not healthy:
    * Disk ST14000NE0008-2JK101 ZHZ3Q546 is FAULTED
After one minute:
New alert:
  * Pool rust state is SUSPENDED: One or more devices are faulted in response to IO failures.
    * Disk ST14000NE0008-2JK101 ZHZ3Q546 is REMOVED
The following alert has been cleared:
At this point, just to be on the safe side in case it was a fluke, I got home and rebooted.
The system notified:
 * Pool rust state is ONLINE: One or more devices is currently being resilvered. The pool will continue to function, possibly in a degraded state.
These alerts have been cleared:
  * Snapshot Task For Dataset "rust/data" failed: cannot open 'rust/data': pool I/O is currently suspended usage: snapshot [-r] [-o property=value] ... @ ... For the property list, run: zfs set|get For the delegated permission list, run: zfs allow|unallow For further help on a command or topic, run: zfs help []..
I think at this point I rebooted again, and now I got this:
New alert:
  * Pool rust state is DEGRADED: One or more devices is currently being resilvered. The pool will continue to function, possibly in a degraded state.
    * Disk ST14000NE0008-2RX103 WAINR7DV is DEGRADED
NOTICE THAT THE DEGRADED DISK WAS NOW THE OTHER ONE, NOT ZHZ3Q546!!! Very worrying… what might be happening? Did both drives die at the same time? They were sourced from 2 different batches.
The system started resilvering. It was SLOW!!! Even logging in via SSH or web shell proved extremely difficult. Once I got in, the load average was very high, even thought the CPU was fine. The system seemed in I/O starvation. Resilvering seemed very slow, with values indicated by zfs pool status -v as low as 600KB/s, and estimated termnation in 2 weeks:
  pool: rust
 state: DEGRADED
status: One or more devices is currently being resilvered.  The pool will
action: Wait for the resilver to complete.
  scan: resilver in progress since Sun Sep 14 17:40:32 2025
        5.42T / 6.20T scanned, 6.57G / 869G issued at 644K/s
        6.55G resilvered, 0.76% done, no estimated completion time
        NAME                                      STATE     READ WRITE CKSUM
        rust                                      DEGRADED     0     0     0
          mirror-0                                DEGRADED     0     0     0
            74479132-8181-482e-82d0-1e823c43acb6  ONLINE       0     0     0  (resilvering)  <------ this is ZHZ3Q546
            57f25ff4-df8e-4958-b09e-8482aa339520  DEGRADED     0   475     0  too many errors  <------ this is WAINR7DV
        cache
          sdb1                                    ONLINE       0     0     0
errors: No known data errors
After that I powered off the system and removed the WAINR7DV drive, imported it in another system, where everything looked fine.
However, the TrueNAS system… is now in a reboot loop with no additional info I can find: https://youtube.com/shorts/szzX1YWKbTg?feature=share
I also ran a scrub on WAINR7DV to check everything, and it did not find any issue, nor did it generate any additional SMART errors.
What is the suggested course of action now? I would like to keep the system functional, even with a single drive in degraded state, while I source another drive. The data on this pool is not critical, but the rest of the system is, so I cannot afford to keep it offline.
Also, any idea about what happened and what mistakes I did in the recovery process? What should I have done?
Thanks in advance!
EDIT:
I trusted the first issue, instead of what the SMART values seemed to indicate (1 1 1) in command_timeout, and instead placed WAINR7DV back in the system. The system boots, in degraded state. I started a long SMART test. Will update.
I highly recommend that if not already done, backup your data.
For drive ZHZ3Q546:
Hardware_ECC_Recovered 0x001a 011 001 000 is bad. 011 is the current value, 001 is the worst, and 000 is the threshold (bad).
Same thing for the other drive Hardware_ECC_Recovered 0x001a 004 002 000 and these are not good values.
Otherwise I do not see any obvious drive issues.
You do know that you can have ZFS errors and not have related drive issues? Yes, very possible. An unstable system could and does cause this.
Once you have all your data backed up, I’d run the two major stability tests, MemTest86+ (5 full passes, or longer) and Prime95 (4 hours, or longer).
You could have a power supply issue, just sayin’, and yes it could be a drive failure but other than the Hardware ECC Correction values looking like crap right now (they can improve over time), I don’t see a drive failure.
Thank you for your contribution!
From what I read online, it is possible that Seagate’s meaning for those values is different. Is this something potentially reasonable?
I have ran a long CPU stress test without issues, and will leave the system running mprime tomorrow all day.
I also performed an extended SMART test on the one drive WAINR7DV that’s currently attached to the machine.
For more info, this is the output of smartctl -x -l farm /dev/sdc:
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.12.15-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Seagate IronWolf Pro
Device Model:     ST14000NE0008-2RX103
Serial Number:    WAINR7DV
LU WWN Device Id: 5 000c50 0c3324166
Firmware Version: SN03
User Capacity:    14,000,519,643,136 bytes [14.0 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database 7.3/5816
ATA Version is:   ACS-4 (minor revision not indicated)
SATA Version is:  SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Tue Sep 16 18:58:19 2025 CEST
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Disabled
ATA Security is:  Disabled, frozen [SEC2]
Write SCT (Get) Feature Control Command failed: scsi error unsupported field in scsi command
Wt Cache Reorder: Unknown (SCT Feature Control command failed)
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  567) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        (1291) minutes.
Conveyance self-test routine
SCT capabilities:              (0x70bd) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR--   076   064   044    -    41008508
  3 Spin_Up_Time            PO----   090   090   000    -    0
  4 Start_Stop_Count        -O--CK   088   088   020    -    12350
  5 Reallocated_Sector_Ct   PO--CK   100   100   010    -    0
  7 Seek_Error_Rate         POSR--   081   060   045    -    135826815
  9 Power_On_Hours          -O--CK   082   082   000    -    15973
 10 Spin_Retry_Count        PO--C-   100   100   097    -    0
 12 Power_Cycle_Count       -O--CK   100   100   020    -    990
 18 Head_Health             PO-R--   100   100   050    -    0
187 Reported_Uncorrect      -O--CK   100   100   000    -    0
188 Command_Timeout         -O--CK   100   099   000    -    1 1 1
190 Airflow_Temperature_Cel -O---K   071   048   040    -    29 (Min/Max 26/44)
192 Power-Off_Retract_Count -O--CK   100   100   000    -    967
193 Load_Cycle_Count        -O--CK   077   077   000    -    46083
194 Temperature_Celsius     -O---K   029   052   000    -    29 (0 16 0 0 0)
195 Hardware_ECC_Recovered  -O-RC-   008   002   000    -    41008508
197 Current_Pending_Sector  -O--C-   100   100   000    -    0
198 Offline_Uncorrectable   ----C-   100   100   000    -    0
199 UDMA_CRC_Error_Count    -OSRCK   200   200   000    -    0
200 Pressure_Limit          PO---K   100   100   001    -    0
240 Head_Flying_Hours       ------   100   253   000    -    2149h+26m+48.370s
241 Total_LBAs_Written      ------   100   253   000    -    33051560323
242 Total_LBAs_Read         ------   100   253   000    -    241503889791
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      5  Ext. Comprehensive SMART error log
0x04       GPL     R/O    256  Device Statistics log
0x04       SL      R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x08       GPL     R/O      2  Power Conditions log
0x09           SL  R/W      1  Selective self-test log
0x0a       GPL     R/W      8  Device Statistics Notification
0x0c       GPL     R/O   2048  Pending Defects log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x13       GPL     R/O      1  SATA NCQ Send and Receive log
0x15       GPL     R/W      1  Rebuild Assist log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x24       GPL     R/O    768  Current Device Internal Status Data log
0x2f       GPL     R/O      1  Set Sector Configuration
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa1       GPL,SL  VS      24  Device vendor specific log
0xa2       GPL     VS   16320  Device vendor specific log
0xa4       GPL,SL  VS     160  Device vendor specific log
0xa6       GPL     VS     192  Device vendor specific log
0xa8-0xa9  GPL,SL  VS     136  Device vendor specific log
0xab       GPL     VS       1  Device vendor specific log
0xad       GPL     VS      16  Device vendor specific log
0xbe-0xbf  GPL     VS   65535  Device vendor specific log
0xc1       GPL,SL  VS       8  Device vendor specific log
0xc3       GPL,SL  VS      32  Device vendor specific log
0xc9       GPL,SL  VS       8  Device vendor specific log
0xca       GPL,SL  VS      16  Device vendor specific log
0xd1       GPL     VS     336  Device vendor specific log
0xd2       GPL     VS   10000  Device vendor specific log
0xd4       GPL     VS    2048  Device vendor specific log
0xda       GPL,SL  VS       1  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Extended offline    Completed without error       00%     15971         -
# 2  Short offline       Completed without error       00%     15930         -
# 3  Short offline       Interrupted (host reset)      00%     15911         -
# 4  Short offline       Completed without error       00%     15887         -
# 5  Short offline       Completed without error       00%     15863         -
# 6  Short offline       Completed without error       00%     15839         -
# 7  Short offline       Completed without error       00%     15815         -
# 8  Short offline       Completed without error       00%     15791         -
# 9  Short offline       Completed without error       00%     15767         -
#10  Short offline       Completed without error       00%     15743         -
#11  Short offline       Completed without error       00%     15719         -
#12  Short offline       Completed without error       00%     15695         -
#13  Short offline       Completed without error       00%     15671         -
#14  Short offline       Completed without error       00%     15647         -
#15  Extended offline    Interrupted (host reset)      00%     15640         -
#16  Short offline       Completed without error       00%     15623         -
#17  Short offline       Completed without error       00%     15599         -
#18  Short offline       Completed without error       00%     15575         -
#19  Short offline       Completed without error       00%     15551         -
SCT Status Version:                  3
SCT Version (vendor specific):       522 (0x020a)
Device State:                        Active (0)
Current Temperature:                    29 Celsius
Power Cycle Min/Max Temperature:     26/44 Celsius
Lifetime    Min/Max Temperature:     16/52 Celsius
Under/Over Temperature Limit Count:   0/11
SMART Status:                        0xc24f (PASSED)
Vendor specific:
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:     2
Temperature Sampling Period:         3 minutes
Temperature Logging Interval:        59 minutes
Min/Max recommended Temperature:     10/40 Celsius
Min/Max Temperature Limit:            5/60 Celsius
Temperature History Size (Index):    128 (82)
Index    Estimated Time   Temperature Celsius
  83    2025-09-11 14:05     ?  -
  84    2025-09-11 15:04    43  ************************
  85    2025-09-11 16:03     ?  -
  86    2025-09-11 17:02    43  ************************
  87    2025-09-11 18:01     ?  -
  88    2025-09-11 19:00    43  ************************
  89    2025-09-11 19:59     ?  -
  90    2025-09-11 20:58    43  ************************
  91    2025-09-11 21:57     ?  -
  92    2025-09-11 22:56    43  ************************
  93    2025-09-11 23:55     ?  -
  94    2025-09-12 00:54    43  ************************
  95    2025-09-12 01:53     ?  -
  96    2025-09-12 02:52    43  ************************
  97    2025-09-12 03:51     ?  -
  98    2025-09-12 04:50    43  ************************
  99    2025-09-12 05:49     ?  -
 100    2025-09-12 06:48    43  ************************
 101    2025-09-12 07:47     ?  -
 102    2025-09-12 08:46    43  ************************
 103    2025-09-12 09:45     ?  -
 104    2025-09-12 10:44    43  ************************
 105    2025-09-12 11:43     ?  -
 106    2025-09-12 12:42    43  ************************
 107    2025-09-12 13:41     ?  -
 108    2025-09-12 14:40    43  ************************
 109    2025-09-12 15:39     ?  -
 110    2025-09-12 16:38    43  ************************
 111    2025-09-12 17:37     ?  -
 112    2025-09-12 18:36    43  ************************
 113    2025-09-12 19:35     ?  -
 114    2025-09-12 20:34    43  ************************
 115    2025-09-12 21:33     ?  -
 116    2025-09-12 22:32    43  ************************
 117    2025-09-12 23:31     ?  -
 118    2025-09-13 00:30    43  ************************
 119    2025-09-13 01:29     ?  -
 120    2025-09-13 02:28    43  ************************
 121    2025-09-13 03:27     ?  -
 122    2025-09-13 04:26    43  ************************
 123    2025-09-13 05:25     ?  -
 124    2025-09-13 06:24    43  ************************
 125    2025-09-13 07:23     ?  -
 126    2025-09-13 08:22    43  ************************
 127    2025-09-13 09:21     ?  -
   0    2025-09-13 10:20    43  ************************
   1    2025-09-13 11:19     ?  -
   2    2025-09-13 12:18    43  ************************
   3    2025-09-13 13:17     ?  -
   4    2025-09-13 14:16    43  ************************
   5    2025-09-13 15:15     ?  -
   6    2025-09-13 16:14    43  ************************
   7    2025-09-13 17:13     ?  -
   8    2025-09-13 18:12    43  ************************
   9    2025-09-13 19:11     ?  -
  10    2025-09-13 20:10    43  ************************
  11    2025-09-13 21:09     ?  -
  12    2025-09-13 22:08    43  ************************
  13    2025-09-13 23:07     ?  -
  14    2025-09-14 00:06    43  ************************
  15    2025-09-14 01:05     ?  -
  16    2025-09-14 02:04    43  ************************
  17    2025-09-14 03:03     ?  -
  18    2025-09-14 04:02    43  ************************
  19    2025-09-14 05:01     ?  -
  20    2025-09-14 06:00    43  ************************
  21    2025-09-14 06:59     ?  -
  22    2025-09-14 07:58    43  ************************
  23    2025-09-14 08:57     ?  -
  24    2025-09-14 09:56    43  ************************
  25    2025-09-14 10:55     ?  -
  26    2025-09-14 11:54    43  ************************
  27    2025-09-14 12:53    37  ******************
  28    2025-09-14 13:52    37  ******************
  29    2025-09-14 14:51     ?  -
  30    2025-09-14 15:50    35  ****************
  31    2025-09-14 16:49     ?  -
  32    2025-09-14 17:48    35  ****************
  33    2025-09-14 18:47     ?  -
  34    2025-09-14 19:46    35  ****************
  35    2025-09-14 20:45     ?  -
  36    2025-09-14 21:44    33  **************
  37    2025-09-14 22:43     ?  -
  38    2025-09-14 23:42    29  **********
  39    2025-09-15 00:41    47  ****************************
  40    2025-09-15 01:40    49  ******************************
  41    2025-09-15 02:39    50  *******************************
  42    2025-09-15 03:38    49  ******************************
  43    2025-09-15 04:37    49  ******************************
  44    2025-09-15 05:36    49  ******************************
  45    2025-09-15 06:35    50  *******************************
  46    2025-09-15 07:34    49  ******************************
  47    2025-09-15 08:33    48  *****************************
  48    2025-09-15 09:32    38  *******************
  49    2025-09-15 10:31    37  ******************
  50    2025-09-15 11:30    36  *****************
  51    2025-09-15 12:29    36  *****************
  52    2025-09-15 13:28    36  *****************
  53    2025-09-15 14:27    32  *************
  54    2025-09-15 15:26    31  ************
 ...    ..(  3 skipped).    ..  ************
  58    2025-09-15 19:22    31  ************
  59    2025-09-15 20:21    32  *************
  60    2025-09-15 21:20     ?  -
  61    2025-09-15 22:19    26  *******
  62    2025-09-15 23:18    43  ************************
 ...    ..(  5 skipped).    ..  ************************
  68    2025-09-16 05:12    43  ************************
  69    2025-09-16 06:11    42  ***********************
  70    2025-09-16 07:10    42  ***********************
  71    2025-09-16 08:09    42  ***********************
  72    2025-09-16 09:08    41  **********************
  73    2025-09-16 10:07    35  ****************
  74    2025-09-16 11:06    34  ***************
 ...    ..(  2 skipped).    ..  ***************
  77    2025-09-16 14:03    34  ***************
  78    2025-09-16 15:02    35  ****************
  79    2025-09-16 16:01    35  ****************
  80    2025-09-16 17:00    35  ****************
  81    2025-09-16 17:59    33  **************
  82    2025-09-16 18:58    30  ***********
SCT Error Recovery Control:
           Read:    100 (10.0 seconds)
          Write:    100 (10.0 seconds)
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4             990  ---  Lifetime Power-On Resets
0x01  0x010  4           15973  ---  Power-on Hours
0x01  0x018  6     33016549507  ---  Logical Sectors Written
0x01  0x020  6        50439183  ---  Number of Write Commands
0x01  0x028  6    238974111075  ---  Logical Sectors Read
0x01  0x030  6       218477294  ---  Number of Read Commands
0x01  0x038  6               -  ---  Date and Time TimeStamp
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4            7120  ---  Spindle Motor Power-on Hours
0x03  0x010  4            4047  ---  Head Flying Hours
0x03  0x018  4           46083  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4               0  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x03  0x038  4               0  ---  Number of Realloc. Candidate Logical Sectors
0x03  0x040  4             967  ---  Number of High Priority Unload Events
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4               1  ---  Resets Between Cmd Acceptance and Completion
0x04  0x018  4               0  -D-  Physical Element Status Changed
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              29  ---  Current Temperature
0x05  0x010  1              36  ---  Average Short Term Temperature
0x05  0x018  1              35  ---  Average Long Term Temperature
0x05  0x020  1              52  ---  Highest Temperature
0x05  0x028  1              16  ---  Lowest Temperature
0x05  0x030  1              42  ---  Highest Average Short Term Temperature
0x05  0x038  1              16  ---  Lowest Average Short Term Temperature
0x05  0x040  1              37  ---  Highest Average Long Term Temperature
0x05  0x048  1              19  ---  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              60  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               5  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4             166  ---  Number of Hardware Resets
0x06  0x010  4              54  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
0xff  =====  =               =  ===  == Vendor Specific Statistics (rev 1) ==
0xff  0x008  7               0  ---  Vendor Specific
0xff  0x010  7               0  ---  Vendor Specific
0xff  0x018  7               0  ---  Vendor Specific
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x000a  2            3  Device-to-host register FISes sent due to a COMRESET
0x0001  2            0  Command failed due to ICRC error
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
Seagate Field Access Reliability Metrics log (FARM) (GP Log 0xa6)
        FARM Log Page 0: Log Header
                FARM Log Version: 2.9
                Pages Supported: 6
                Log Size: 98304
                Page Size: 16384
                Heads Supported: 24
                Number of Copies: 0
                Reason for Frame Capture: 0
        FARM Log Page 1: Drive Information
                World Wide Name: 0x5000c500c3324166
                Device Interface: SATA
                Device Capacity in Sectors: 27344764928
                Physical Sector Size: 4096
                Logical Sector Size: 512
                Device Buffer Size: 268435456
                Number of Heads: 16
                Device Form Factor: 3.5 inches
                Firmware Rev: SN03
                ATA Security State (ID Word 128): 0x01629
                ATA Features Supported (ID Word 78): 0x0168cc
                ATA Features Enabled (ID Word 79): 0x000000000000004c
                Power on Hours: 25931
                Spindle Power on Hours: 7120
                Head Flight Hours: 4047
                Head Load Events: 46083
                Power Cycle Count: 1012
                Hardware Reset Count: 166
                Spin-up Time: 10 ms
                Time to ready of the last power cycle: 23725 ms
                Time drive is held in staggered spin: 0 ms
                Model Number:
                Drive Recording Type: UNKNOWN
                Max Number of Available Sectors for Reassignment: 0
                Assembly Date (YYWW):
                Depopulation Head Mask: 0
        FARM Log Page 2: Workload Statistics
                Total Number of Read Commands: 844515180
                Total Number of Write Commands: 259548815
                Total Number of Random Read Commands: 22533134
                Total Number of Random Write Commands: 205678923
                Total Number Of Other Commands: 8142569
                Logical Sectors Written: 234463650434
                Logical Sectors Read: 432516513096
                Number of dither events during current power cycle: 0
                Number of times dither was held off during random workloads: 0
                Number of times dither was held off during sequential workloads: 0
                Number of Read commands from 0-3.125% of LBA space for last 3 SMART Summary Frames: 0
                Number of Read commands from 3.125-25% of LBA space for last 3 SMART Summary Frames: 0
                Number of Read commands from 25-75% of LBA space for last 3 SMART Summary Frames: 0
                Number of Read commands from 75-100% of LBA space for last 3 SMART Summary Frames: 0
                Number of Write commands from 0-3.125% of LBA space for last 3 SMART Summary Frames: 0
                Number of Write commands from 3.125-25% of LBA space for last 3 SMART Summary Frames: 0
                Number of Write commands from 25-75% of LBA space for last 3 SMART Summary Frames: 0
                Number of Write commands from 75-100% of LBA space for last 3 SMART Summary Frames: 0
        FARM Log Page 3: Error Statistics
                Unrecoverable Read Errors: 0
                Unrecoverable Write Errors: 0
                Number of Reallocated Sectors: 0
                Number of Read Recovery Attempts: 0
                Number of Mechanical Start Failures: 0
                Number of Reallocated Candidate Sectors: 0
                Number of ASR Events: 54
                Number of Interface CRC Errors: 0
                Spin Retry Count: 0
                Spin Retry Count Normalized: 100
                Spin Retry Count Worst: 100
                Number of IOEDC Errors (Raw): 0
                CTO Count Total: 1
                CTO Count Over 5s: 1
                CTO Count Over 7.5s: 1
                Total Flash LED (Assert) Events: 0
                Index of the last Flash LED: 0
                Flash LED Event 0:
                        Event Information: 0x0000000000000000
                        Timestamp of Event 0 (hours): 0
                        Power Cycle Event 0: 0
                Flash LED Event 1:
                        Timestamp of Event 1 (hours): 0
                        Power Cycle Event 1: 0
                Flash LED Event 2:
                        Timestamp of Event 2 (hours): 0
                        Power Cycle Event 2: 0
                Flash LED Event 3:
                        Timestamp of Event 3 (hours): 0
                        Power Cycle Event 3: 0
                Flash LED Event 4:
                        Timestamp of Event 4 (hours): 0
                        Power Cycle Event 4: 0
                Flash LED Event 5:
                        Timestamp of Event 5 (hours): 0
                        Power Cycle Event 5: 0
                Flash LED Event 6:
                        Timestamp of Event 6 (hours): 0
                        Power Cycle Event 6: 0
                Flash LED Event 7:
                        Timestamp of Event 7 (hours): 0
                        Power Cycle Event 7: 0
                Uncorrectable errors: 0
                Cumulative Lifetime Unrecoverable Read errors due to ERC: 0
                Cum Lifetime Unrecoverable by head 0:
                        Cumulative Lifetime Unrecoverable Read Repeating: 0
                        Cumulative Lifetime Unrecoverable Read Unique: 0
                Cum Lifetime Unrecoverable by head 1:
                Cum Lifetime Unrecoverable by head 2:
                Cum Lifetime Unrecoverable by head 3:
                Cum Lifetime Unrecoverable by head 4:
                Cum Lifetime Unrecoverable by head 5:
                Cum Lifetime Unrecoverable by head 6:
                Cum Lifetime Unrecoverable by head 7:
                Cum Lifetime Unrecoverable by head 8:
                Cum Lifetime Unrecoverable by head 9:
                Cum Lifetime Unrecoverable by head 10:
                Cum Lifetime Unrecoverable by head 11:
                Cum Lifetime Unrecoverable by head 12:
                Cum Lifetime Unrecoverable by head 13:
                Cum Lifetime Unrecoverable by head 14:
                Cum Lifetime Unrecoverable by head 15:
        FARM Log Page 4: Environment Statistics
                Current Temperature (Celsius): 29
                Highest Temperature: 52
                Lowest Temperature: 16
                Average Short Term Temperature: 36
                Average Long Term Temperature: 35
                Highest Average Short Term Temperature: 42
                Lowest Average Short Term Temperature: 16
                Highest Average Long Term Temperature: 37
                Lowest Average Long Term Temperature: 19
                Time In Over Temperature (minutes): 0
                Time In Under Temperature (minutes): 0
                Specified Max Operating Temperature: 60
                Specified Min Operating Temperature: 5
                Current Relative Humidity: 0
                Current Motor Power: 2340
                Current 12 volts: 0.000
                Minimum 12 volts: 0.000
                Maximum 12 volts: 0.000
                Current 5 volts: 0.000
                Minimum 5 volts: 0.000
                Maximum 5 volts: 0.000
                12V Power Average: 0.000
                12V Power Minimum: 0.000
                12V Power Maximum: 0.000
                5V Power Average: 0.000
                5V Power Minimum: 0.000
                5V Power Maximum: 0.000
        FARM Log Page 5: Reliability Statistics
                Error Rate (SMART Attribute 1 Raw): 0x000000000271bd7c
                Error Rate (SMART Attribute 1 Normalized): 76
                Error Rate (SMART Attribute 1 Worst): 64
                Seek Error Rate (SMART Attr 7 Raw): 0x0000000008188db1
                Seek Error Rate (SMART Attr 7 Normalized): 81
                Seek Error Rate (SMART Attr 7 Worst): 60
                High Priority Unload Events: 967
                Helium Pressure Threshold Tripped: 0
                LBAs Corrected By Parity Sector: 0
                DVGA Skip Write Detect by Head 0: 0
                DVGA Skip Write Detect by Head 1: 0
                DVGA Skip Write Detect by Head 2: 0
                DVGA Skip Write Detect by Head 3: 0
                DVGA Skip Write Detect by Head 4: 0
                DVGA Skip Write Detect by Head 5: 0
                DVGA Skip Write Detect by Head 6: 0
                DVGA Skip Write Detect by Head 7: 0
                DVGA Skip Write Detect by Head 8: 0
                DVGA Skip Write Detect by Head 9: 0
                DVGA Skip Write Detect by Head 10: 0
                DVGA Skip Write Detect by Head 11: 0
                DVGA Skip Write Detect by Head 12: 0
                DVGA Skip Write Detect by Head 13: 0
                DVGA Skip Write Detect by Head 14: 0
                DVGA Skip Write Detect by Head 15: 0
                RVGA Skip Write Detect by Head 0: 0
                RVGA Skip Write Detect by Head 1: 0
                RVGA Skip Write Detect by Head 2: 0
                RVGA Skip Write Detect by Head 3: 0
                RVGA Skip Write Detect by Head 4: 0
                RVGA Skip Write Detect by Head 5: 0
                RVGA Skip Write Detect by Head 6: 0
                RVGA Skip Write Detect by Head 7: 0
                RVGA Skip Write Detect by Head 8: 0
                RVGA Skip Write Detect by Head 9: 0
                RVGA Skip Write Detect by Head 10: 0
                RVGA Skip Write Detect by Head 11: 0
                RVGA Skip Write Detect by Head 12: 0
                RVGA Skip Write Detect by Head 13: 0
                RVGA Skip Write Detect by Head 14: 0
                RVGA Skip Write Detect by Head 15: 0
                FVGA Skip Write Detect by Head 0: 0
                FVGA Skip Write Detect by Head 1: 0
                FVGA Skip Write Detect by Head 2: 0
                FVGA Skip Write Detect by Head 3: 0
                FVGA Skip Write Detect by Head 4: 0
                FVGA Skip Write Detect by Head 5: 0
                FVGA Skip Write Detect by Head 6: 0
                FVGA Skip Write Detect by Head 7: 0
                FVGA Skip Write Detect by Head 8: 0
                FVGA Skip Write Detect by Head 9: 0
                FVGA Skip Write Detect by Head 10: 0
                FVGA Skip Write Detect by Head 11: 0
                FVGA Skip Write Detect by Head 12: 0
                FVGA Skip Write Detect by Head 13: 0
                FVGA Skip Write Detect by Head 14: 0
                FVGA Skip Write Detect by Head 15: 0
                Skip Write Detect Threshold Exceeded by Head 0: 0
                Skip Write Detect Threshold Exceeded by Head 1: 0
                Skip Write Detect Threshold Exceeded by Head 2: 0
                Skip Write Detect Threshold Exceeded by Head 3: 0
                Skip Write Detect Threshold Exceeded by Head 4: 0
                Skip Write Detect Threshold Exceeded by Head 5: 0
                Skip Write Detect Threshold Exceeded by Head 6: 0
                Skip Write Detect Threshold Exceeded by Head 7: 0
                Skip Write Detect Threshold Exceeded by Head 8: 0
                Skip Write Detect Threshold Exceeded by Head 9: 0
                Skip Write Detect Threshold Exceeded by Head 10: 0
                Skip Write Detect Threshold Exceeded by Head 11: 0
                Skip Write Detect Threshold Exceeded by Head 12: 0
                Skip Write Detect Threshold Exceeded by Head 13: 0
                Skip Write Detect Threshold Exceeded by Head 14: 0
                Skip Write Detect Threshold Exceeded by Head 15: 0
                Write Power On (hrs) by Head 0: 4639
                Write Power On (hrs) by Head 1: 4522
                Write Power On (hrs) by Head 2: 4748
                Write Power On (hrs) by Head 3: 4365
                Write Power On (hrs) by Head 4: 4619
                Write Power On (hrs) by Head 5: 4504
                Write Power On (hrs) by Head 6: 4435
                Write Power On (hrs) by Head 7: 4344
                Write Power On (hrs) by Head 8: 4367
                Write Power On (hrs) by Head 9: 4557
                Write Power On (hrs) by Head 10: 4731
                Write Power On (hrs) by Head 11: 4449
                Write Power On (hrs) by Head 12: 4582
                Write Power On (hrs) by Head 13: 4354
                Write Power On (hrs) by Head 14: 4284
                Write Power On (hrs) by Head 15: 4482
                MR Head Resistance from Head 0: 0
                MR Head Resistance from Head 1: 0
                MR Head Resistance from Head 2: 0
                MR Head Resistance from Head 3: 0
                MR Head Resistance from Head 4: 0
                MR Head Resistance from Head 5: 0
                MR Head Resistance from Head 6: 0
                MR Head Resistance from Head 7: 0
                MR Head Resistance from Head 8: 0
                MR Head Resistance from Head 9: 0
                MR Head Resistance from Head 10: 0
                MR Head Resistance from Head 11: 0
                MR Head Resistance from Head 12: 0
                MR Head Resistance from Head 13: 0
                MR Head Resistance from Head 14: 0
                MR Head Resistance from Head 15: 0
                Second MR Head Resistance by Head 0: 0
                Second MR Head Resistance by Head 1: 0
                Second MR Head Resistance by Head 2: 0
                Second MR Head Resistance by Head 3: 0
                Second MR Head Resistance by Head 4: 0
                Second MR Head Resistance by Head 5: 0
                Second MR Head Resistance by Head 6: 0
                Second MR Head Resistance by Head 7: 0
                Second MR Head Resistance by Head 8: 0
                Second MR Head Resistance by Head 9: 0
                Second MR Head Resistance by Head 10: 0
                Second MR Head Resistance by Head 11: 0
                Second MR Head Resistance by Head 12: 0
                Second MR Head Resistance by Head 13: 0
                Second MR Head Resistance by Head 14: 0
                Second MR Head Resistance by Head 15: 0
                Number of Reallocated Sectors by Head 0: 0
                Number of Reallocated Sectors by Head 1: 0
                Number of Reallocated Sectors by Head 2: 0
                Number of Reallocated Sectors by Head 3: 0
                Number of Reallocated Sectors by Head 4: 0
                Number of Reallocated Sectors by Head 5: 0
                Number of Reallocated Sectors by Head 6: 0
                Number of Reallocated Sectors by Head 7: 0
                Number of Reallocated Sectors by Head 8: 0
                Number of Reallocated Sectors by Head 9: 0
                Number of Reallocated Sectors by Head 10: 0
                Number of Reallocated Sectors by Head 11: 0
                Number of Reallocated Sectors by Head 12: 0
                Number of Reallocated Sectors by Head 13: 0
                Number of Reallocated Sectors by Head 14: 0
                Number of Reallocated Sectors by Head 15: 0
                Number of Reallocation Candidate Sectors by Head 0: 0
                Number of Reallocation Candidate Sectors by Head 1: 0
                Number of Reallocation Candidate Sectors by Head 2: 0
                Number of Reallocation Candidate Sectors by Head 3: 0
                Number of Reallocation Candidate Sectors by Head 4: 0
                Number of Reallocation Candidate Sectors by Head 5: 0
                Number of Reallocation Candidate Sectors by Head 6: 0
                Number of Reallocation Candidate Sectors by Head 7: 0
                Number of Reallocation Candidate Sectors by Head 8: 0
                Number of Reallocation Candidate Sectors by Head 9: 0
                Number of Reallocation Candidate Sectors by Head 10: 0
                Number of Reallocation Candidate Sectors by Head 11: 0
                Number of Reallocation Candidate Sectors by Head 12: 0
                Number of Reallocation Candidate Sectors by Head 13: 0
                Number of Reallocation Candidate Sectors by Head 14: 0
                Number of Reallocation Candidate Sectors by Head 15: 0
I do not see anything particularly bad there?
The seagate raw read rate and seek error rates are not exactly what they seem. They are fine. It needs to get above “4,294,967,295” to register as one failure. They do things differently, that is all I will say.
The Hardware ECC Recovered value got better and these will change over time. I still do not like the “002” or “001” values, but nothing else had a notable issue.
The Long test looks good.
Thanks. I’m starting to think that the other drive is the one that failed. I will mprime, memtest and then do a long SMART test on the other drive, and see what’s what.
Thanks so far for your help!
Remember what I said, you don’t need to have a drive failure to have a corrupt pool. Prove it to yourself that a drive is in fact bad before replacing it. In my links is one for Drive Troubleshooting Flowcharts. Take a gander at that, it may be helpful.
