Erreur affichage appli TrueNas
bonjour,
je sandro je vie ds le sud, et je viens d’installer trueneas sur mon nouveau serveur DIY. Rayzen 5 5700g 32GO DDR4 carte mère gygabit B550m aorus elite.
il s’agit de ma 1er expérience avec truenas.
je voudrais y installer home Assistent et jellyfine ou à défaut plex sauf que j’ai un message :
  File "/usr/lib/python3/dist-packages/middlewared/plugins/catalog/git_utils.py", line 34, in pull_clone_repository
    clone_repository(repository_uri, destination, branch, depth)
  File "/usr/lib/python3/dist-packages/middlewared/utils/git.py", line 25, in clone_repository
    raise CallError(
middlewared.service_exception.CallError: [EFAULT] Failed to clone 'https://github.com/truenas/apps' repository at '/var/run/middleware/ix-apps/catalogs' destination: Cloning into '/var/run/middleware/ix-...
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 515, in run
    await self.future
  File "/usr/lib/python3/dist-packages/middlewared/job.py", line 560, in __run_body
    rv = await self.method(*args)
  File "/usr/lib/python3/dist-packages/middlewared/api/base/decorator.py", line 93, in wrapped
    result = await func(*args)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/catalog/sync.py", line 27, in sync
    await self.middleware.call(
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 1005, in call
    return await self._call(
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 731, in _call
  File "/usr/lib/python3/dist-packages/middlewared/main.py", line 624, in run_in_executor
  File "/usr/lib/python3.11/concurrent/futures/thread.py", line 58, in run
  File "/usr/lib/python3/dist-packages/middlewared/plugins/catalog/sync.py", line 55, in update_git_repository
    return pull_clone_repository(repository, location, branch)
  File "/usr/lib/python3/dist-packages/middlewared/plugins/catalog/git_utils.py", line 36, in pull_clone_repository
    raise CallError(f'Failed to clone {repository_uri!r} repository at {destination!r} destination: {e}')
middlewared.service_exception.CallError: [EFAULT] Failed to clone 'https://github.com/truenas/apps' repository at '/var/run/middleware/ix-apps/catalogs' destination: [EFAULT] Failed to clone 'https://github.com/truenas/apps' repository at '/var/run/middleware/ix-apps/catalogs' destination: Cloning into '/var/run/middleware/ix-...
une piste pour corriger les erreurs commise.
merci
je dérange encore j’ai redémarré le système et ça fonctionne.
merci
