Formattazione impossibile hd
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 515, in run
await self.future
File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 560, in _run_body
rv = await self.method(*args)
File “/usr/lib/python3/dist-packages/middlewared/service/crud_service.py”, line 287, in nf
rv = await func(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 48, in nf
res = await f(*args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/schema/processor.py”, line 174, in nf
File "/usr/lib/python3/dist-packages/middlewared/plugins/pool
/pool.py", line 582, in do_create
await self.middleware.call(‘pool.format_disks’, job, disks, 0, 30)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1005, in call
return await self._call(
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 720, in call
/format_disks.py", line 36, in format_disks
devname = await self.middleware.call(‘disk.gptid_from_part_type’, disk, zfs_part_type)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 731, in call
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 624, in run_in_executor
File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
File "/usr/lib/python3/dist-packages/middlewared/plugins/disk
/disk_info.py", line 173, in gptid_from_part_type
raise CallError(f’Partition type {part_type} not found on {disk}')
middlewared.service_exception.CallError: [EFAULT] Partition type 6a898cc3-1dd2-11b2-99a6-080020736631 not found on sda
You should provide more info as possible to get good help, how explained here, otherwise will be hard understand something about your issue.
(questa è una sezione internazionale, se scrivi in italiano ti capiamo in pochi :smile: però hai fatto bene a postare qui, la sezione italiana è poco/per niente bazzicata. Se hai problemi con l’inglese aiutati con un traduttore :smile: )
