GPU not showing up
I recently built a NAS using an old 1150 MB and 4 core processor. It is primarily for storage and plex. I have everything running good with the exception of my GPU not showing in isolate GPU devices. I system is TrueNas Scale 24.10.1, with a RTX 2060 GPU. I get signal out when plugged into the card, but do not see an option in plex. I am a newbie to Linux, but proficient with Windows. Is there an app I can run to enable the GPU? Also what would be some other uses for my NAS? Is Jellyfin better than Plex?
Did you install the NVidia drivers? I found an old post here that might still be applicable: Enabling Nvidia GPU in existing Docker app - #2 by ABain
Such general judgements are usually in the eye of the beholder and different folks will come to different conclusions, based on their needs and preferences.
I suggest following the information on the apps settings & drivers found in the section linked above.
I did install drivers when I built the NAS, but that was it. However after looking at plex options it shows the GPU. The isolate GPU still does not show it.
