Hardware troubleshooting asssitance
Hello - hopefully i’m posting in the correct forum to ask a question regarding my TrueNAS build and some issues i’ve started seeing about two weeks ago. This build has been running fine for about a year without issues.
I’ll start with the hardware specs.
TrueNAS version = 25.10.4 - Goldeye
mobo = B650D4U-2L2T/BCM
CPU = AMD Ryzen 9600X
Memory = 4X crucial Pro 48GB (memtest pass)
HBA = currently HBA 9400-16i, FW 24.00.00.00
PSU = Thermaltake Toughpower GT 750W
Case = Rosewill RSV=4000U-SK, modified with 2x Rosewill 4 bay 3.5 hot swap bays
VDEVS = HDD Pool, 7x seagate iron wolf 4TB, 1x 8TB(it’s all I could find) configured in RAIDZ2, SSD Pool, 8x Intel DC3520 1.6TB, configured in RAIDZ2. These 16 drives are connected to the HBA.
now on to the issue
Over the last two weeks I’ve been receiving random uncorrectable errors on random drives, only in my HDD pool. i’ve confirmed the drives are in separate hot-swap enclosers. checking smart status it shows the drive is healthy and fine, manually running scrub task are not reporting the drives as having issues.
I’ve replaced the following
SFF-8643 SATA cables on both hot-swap bays
HBA, was using the alliexpress version of the 9305, replaced that recently with the 9400-16i.
At this point i’m wondering if it’s the powersupply failing but i don’t want to keep spending money without knowing, and i understand it’s hard to know for sure, but i’m thinking that’s the next logical piece to replace. according to the BMC controller on the motherboard 12V is reading 12.1V.
Not sure what other info i should post here, but here’s the output of one of the drives smart check that truenas is currently reporting (from the GUI) read/write, and checksum errors.
root@grm-nas[/home/truenas_admin]# smartctl -a /dev/sdq
Device Model: ST4000NT001-3M2101
Serial Number: WX11TXN6
LU WWN Device Id: 5 000c50 0eb3ce326
Firmware Version: EN01
User Capacity: 4,000,787,030,016 bytes [4.00 TB]
Rotation Rate: 7200 rpm
Form Factor: 3.5 inches
Device is: Not in smartctl database 7.3/5528
ATA Version is: ACS-4 (minor revision not indicated)
SATA Version is: SATA 3.3, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is: Sun Jul 5 20:32:41 2026 CDT
SMART support is: Enabled
General SMART Values:
Offline data collection status: (0x82) Offline data collection activity
was completed without error.
been run.
data collection: ( 567) seconds.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time: ( 357) minutes.
Conveyance self-test routine
SCT capabilities: (0x50bd) SCT Status supported.
SCT Data Table supported.
1 Raw_Read_Error_Rate 0x000f 075 064 044 Pre-fail Always - 34333040
3 Spin_Up_Time 0x0003 098 092 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 100 100 020 Old_age Always - 264
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 072 060 045 Pre-fail Always - 14676596
9 Power_On_Hours 0x0032 093 093 000 Old_age Always - 6366
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 266
18 Unknown_Attribute 0x000b 100 100 050 Pre-fail Always - 0
187 Reported_Uncorrect 0x0032 100 100 000 Old_age Always - 0
188 Command_Timeout 0x0032 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 067 064 000 Old_age Always - 33 (Min/Max 29/33)
192 Power-Off_Retract_Count 0x0032 100 100 000 Old_age Always - 255
193 Load_Cycle_Count 0x0032 094 094 000 Old_age Always - 13309
194 Temperature_Celsius 0x0022 033 040 000 Old_age Always - 33 (0 22 0 0 0)
197 Current_Pending_Sector 0x0012 100 100 000 Old_age Always - 0
198 Offline_Uncorrectable 0x0010 100 100 000 Old_age Offline - 0
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 100 000 Old_age Offline - 266 (120 78 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 10466722304
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 19377363155
SMART Error Log Version: 1
No Errors Logged
1 Extended offline Interrupted (host reset) 00% 6318 -
2 Short offline Completed without error 00% 6318 -
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
The above only provides legacy SMART information - try ‘smartctl -x’ for more
