Random Fan Spinups and Inconsistent Boots
I have been having several issues with my Truenas. Symptoms include 1. Truenas fans will spin up very loud every once in a while and UI becomes inaccessible, 2. Only way to get back to UI is to reboot physical server, 3. Recently, it takes several boots to get the Truenas to start working again
I have done tons of digging and can’t seem to find a solution. I don’t believe the physical drive is the issue, as it passes SMART checks with no errors
Below are a few excerpts from the Truenas logs:
/var/log/messages
Jul 17 23:26:05 truenas         (da6:mpr0:0:20:0): READ(6). CDB: 08 08 47 af 04 00 length 2048 SMID 818 Command timeout on target 20(0x0010), 60000 set, 60.243632720 elapsed
Jul 17 23:26:05 truenas mpr0: At enclosure level 1, slot 12, connector name (    )
Jul 17 23:26:05 truenas mpr0: Sending abort to target 20 for SMID 818
Jul 17 23:26:05 truenas         (da6:mpr0:0:20:0): READ(6). CDB: 08 08 47 af 04 00 length 2048 SMID 818 Aborting command 0xfffffe00e4556170
Jul 17 23:26:08 truenas mpr0: Controller reported scsi ioc terminated tgt 20 SMID 2034 loginfo 31130000
Jul 17 23:26:08 truenas mpr0: Finished abort recovery for target 20
Jul 17 23:26:08 truenas (da6:mpr0:0:20:0): SYNCHRONIZE CACHE(10). CDB: 35 00 00 00 00 00 00 00 00 00
Jul 17 23:26:08 truenas (da6:mpr0:0:20:0): CAM status: CCB request completed with an error
Jul 17 23:26:08 truenas (da6:mpr0:0:20:0): Retrying command, 0 more tries remain
Jul 17 23:26:08 truenas (da6:mpr0:0:20:0): READ(6). CDB: 08 08 47 af 04 00
Jul 17 23:26:08 truenas (da6:mpr0:0:20:0): CAM status: Command timeout
Jul 17 23:26:08 truenas (da6:mpr0:0:20:0): Retrying command, 3 more tries remain
Jul 17 23:26:13 truenas mpr0: mprsas_prepare_remove: Sending reset for target ID 20
Jul 17 23:26:13 truenas da6 at mpr0 bus 0 scbus0 target 20 lun 0
Jul 17 23:26:13 truenas da6: <ATA Samsung SSD 870 4214>  s/n CE47404B113017462311 detached
Jul 17 23:26:13 truenas mpr0: Controller reported scsi ioc terminated tgt 20 SMID 1460 loginfo 31130000 departing
Jul 17 23:26:13 truenas mpr0: Controller reported scsi ioc terminated tgt 20 SMID 752 loginfo 31130000 departing
Jul 17 23:26:13 truenas mpr0: No pending commands: starting remove_device
Jul 17 23:26:13 truenas mpr0: clearing target 20 handle 0x0010
Jul 17 23:26:13 truenas mpr0: At enclosure level 1, slot 12, connector name (    )
Jul 17 23:26:13 truenas Solaris: WARNING: Pool 'boot-pool' has encountered an uncorrectable I/O failure and has been suspended.
Jul 17 23:27:12 truenas Solaris[3930]: Last message 'WARNING: Pool 'boot-' repeated 1 times, suppressed by syslog-ng on truenas
Jul 17 23:30:29 truenas xptioctl: pass driver is not in the kernel
Jul 17 23:30:29 truenas xptioctl: put "device pass" in your kernel config file
Jul 17 23:35:29 truenas xptioctl: pass driver is not in the kernel
Jul 17 23:35:29 truenas xptioctl: put "device pass" in your kernel config file
results of a smartctl
smartctl 7.2 2021-09-14 r5236 [FreeBSD 13.1-RELEASE-p9 amd64] (local build)
Device Model:     Samsung SSD 870 EVO 250G
Serial Number:    CE47404B113017462311
LU WWN Device Id: 0 000000 000000000
Firmware Version: ZD0R4214
User Capacity:    250,059,350,016 bytes [250 GB]
Sector Size:      512 bytes logical/physical
Rotation Rate:    Solid State Device
Form Factor:      2.5 inches
TRIM Command:     Available, deterministic
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-3, ATA8-ACS T13/1699-D revision 6
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri Jul 18 10:48:29 2025 EDT
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00) Offline data collection activity
                                        was never started.
                                        been run.
data collection:                (    1) seconds.
capabilities:                    (0x59) SMART execute Offline immediate.
                                        No Auto Offline data collection support.
                                        command.
                                        Self-test supported.
SMART capabilities:            (0x0002) Does not save SMART data before
                                        entering power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
  1 Raw_Read_Error_Rate     0x002f   100   100   050    Pre-fail  Always       -       0
  5 Reallocated_Sector_Ct   0x0033   100   100   010    Pre-fail  Always       -       0
  9 Power_On_Hours          0x0032   100   100   000    Old_age   Always       -       11352
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       59
161 Unknown_Attribute       0x0032   100   100   050    Old_age   Always       -       1
162 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       102
163 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       3000
164 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
166 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       122
167 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
168 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
169 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       98
171 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
172 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       0
174 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       42
175 Program_Fail_Count_Chip 0x0032   100   100   000    Old_age   Always       -       0
181 Program_Fail_Cnt_Total  0x0022   100   100   000    Old_age   Always       -       15332868
187 Reported_Uncorrect      0x0032   100   100   000    Old_age   Always       -       0
194 Temperature_Celsius     0x0022   100   100   000    Old_age   Always       -       40
195 Hardware_ECC_Recovered  0x003a   100   100   000    Old_age   Always       -       90178691
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       0
199 UDMA_CRC_Error_Count    0x0032   100   100   000    Old_age   Always       -       0
206 Unknown_SSD_Attribute   0x0032   100   100   000    Old_age   Always       -       0
207 Unknown_SSD_Attribute   0x0032   100   100   000    Old_age   Always       -       1
232 Available_Reservd_Space 0x0032   100   100   000    Old_age   Always       -       97
241 Total_LBAs_Written      0x0032   100   100   000    Old_age   Always       -       23
242 Total_LBAs_Read         0x0032   100   100   000    Old_age   Always       -       742
249 Unknown_Attribute       0x0032   100   100   000    Old_age   Always       -       41
250 Read_Error_Retry_Rate   0x0032   100   100   000    Old_age   Always       -       34
SMART Error Log Version: 1
No Errors Logged
# 1  Short offline       Completed without error       00%     11337         -
# 2  Short offline       Completed without error       00%     11169         -
# 3  Extended offline    Completed without error       00%     11073         -
# 4  Short offline       Completed without error       00%     11001         -
# 5  Short offline       Completed without error       00%     10918         -
# 6  Extended offline    Completed without error       00%     10822         -
# 7  Short offline       Completed without error       00%     10750         -
# 8  Short offline       Completed without error       00%     10582         -
# 9  Extended offline    Completed without error       00%     10486         -
#10  Short offline       Completed without error       00%     10414         -
#11  Short offline       Completed without error       00%     10413         -
#12  Short offline       Completed without error       00%     10389         -
#13  Short offline       Completed without error       00%     10365         -
#14  Short offline       Completed without error       00%      9134         -
#15  Short offline       Completed without error       00%      9110         -
#16  Short offline       Completed without error       00%      9086         -
#17  Short offline       Completed without error       00%      9062         -
#18  Short offline       Completed without error       00%      9038         -
#19  Short offline       Completed without error       00%      9014         -
#20  Short offline       Completed without error       00%      8990         -
#21  Short offline       Completed without error       00%      8966         -
SMART Selective self-test log data structure revision number 0
Note: revision number not 1 implies that no selective self-test has ever been run
Perhaps try swapping cable on the EVO. Looks like the controller is aborting a call and the system is taking precaution.
A little more HW detail would be good. See the link below.
Sure. Hardware specs are as follows:
Dell R730xd
8x 16GB Ram sticks
6x Seagate 8BG HDD
1x Samsung 250GB SSD (Boot Drive)
Running TrueNAS Core
Another symptom I started noticing was that every time I try to scrub the boot-pool, the web gui and SSH both stop working.
These errors in addition to the log you provided suggests an issue with your boot device.
Do you have a replacement you could swap in?
Don’t forget to always have a current backup of your TrueNAS configuration file. And be very careful if you reinstall TrueNAS on a new drive while keeping the data storage drives in the system. It’s easy to make a mistake and install the OS to the data drives instead, thereby wiping your data.
Ordered one, and it’s on the way. I guess I’m confused why it would have some errors like that and still say that the SMART test passed.
