So in the meantime I was able to do a readonly import after switching off all disks and powering them step by step during truenas is running.
zpool import -o readonly=on
worked fine pool was imported healty…
But a restarted system with readwrite was a fault again.
4x ST8000NM0055-1RM. These are CMR drives.
Currently they are connected to an LSI SAS2008 in IT Mode via sas/sata breakout cable. Same issue at a SATA Controller (internal or 10Gtek PCIe SATA X4 Card 6 Port)
Mainboard ASUS PRIME X370-PRO wit 32 GB ECC RAM
AMD Ryzen 5 PRO 4650G
Truenas core
TrueNAS-13.0-U6.2
% zpool import
pool: zpool3-1
state: ONLINE
status: Some supported features are not enabled on the pool.
(Note that they may be intentionally disabled if the
'compatibility' property is set.)
action: The pool can be imported using its name or numeric identifier, though
some features will not be available without an explicit 'zpool upgrade'.
zpool3-1 ONLINE
raidz1-0 ONLINE
gpt/ZA1JJNSN ONLINE
gpt/ZA1JL7QY ONLINE
gpt/ZA1JQNSJ ONLINE
gpt/ZA1JRB05 ONLINE
I would say I stop here my investigation and recreate the the Pool out of my backups.
But its a pity that there is no deeper analysis possible.
Is there a need to get the drives running like for the smartctl longterm test ?
