24.10 ,draid2
draid2:14d:17c:1s-0
There is a disk that is not used.
When a disk is removed,
how to automatically resilveredit without manual replacement
(google translate)
Please list your language. Somebody may speak and write it.
Try searching the documents section for ‘Hot Spare’. Make sure you are looking at 24.10 version
Running 24.10 is risky, it’s not even an alpha.
There’s not a lot of information to go on here, but I think you’re misunderstanding how the distributed hot spare works in a dDRAID VDEV. There is no single disk that is not being used and can be removed.
I’d suggest reading the ZFS dRAID Primer | TrueNAS Documentation Hub.
