How to bring degraded disk online to run SMART check?
The regular alerts email my server sends me said that one of my disks is degraded the other day. I’m seeing online that I should run the SMART check on it and/or run a ZFS scrub, but the system “removed” it for safety reasons.
How can I bring it back to run the check? Just going to the degraded drive under Storage/Topology and clicking “Online” didn’t do anything. I’m hoping it can be saved, of course, given hardware prices lately.
If the disk didn’t suffer a critical failure & become undetectable by the system, then you don’t need it to be ‘online’ to run a smart test.
Confirm the assigned sda/b/c/d/whatever & run smartctl -t long /dev/sd(letterhere) in the shell, wait x hours (day(s)?) & review results.
More details about the system, the drives, how they are connected, etc etc, can provide additional advice on the forums.
Edit: if the drive is indeed no longer detected, then your options are to power down the system, check/reseat connections (consider moving to different available slots on motherboard/HBA if available) and hoping it becomes detected again. Be advised that rebooted the system may reassign the sda/b/c/etc naming at random & to always go off of the physical serial# when possible.
I rebooted the system and it began resilvering the drive automatically. I waited for that to finish, but now it says there are 3 checksum errors on the drive when I run zpool status and look at the pool in question:
pool: Main
state: ONLINE
status: One or more devices has experienced an unrecoverable error.  An
attempt was made to correct the error.  Applications are unaffected.
see:
scan: resilvered 10.6G in 00:07:34 with 0 errors on Fri Oct 30 23:22:18 2026
    NAME                                      STATE     READ WRITE CKSUM
    Main                                      ONLINE       0     0     0
      mirror-0                                ONLINE       0     0     0
        28fd2d2e-74af-48da-bf1c-b3eff8cb7f1f  ONLINE       0     0     3
        b8555a06-a34c-4349-a4e1-dae25673a6e3  ONLINE       0     0     0
errors: No known data errors
If resilvering didn’t get rid of all the errors, is that the final verdict on this drive?
Could have been redundant meta data errors as no files seem to be impacted. You have some options now; you can zpool clear & then zpool scrub Main to see if the chksum errors were repaired during the resilver & if they’ll still be present after a scrub.
…Or, instead of that, if this is already a suspect disk, you then you can run a smart -long test on it first (don’t do both at once unless you love waiting needlessly).
As an aside; what kind of drive is it & how is it connected to the motherboard?
*use sudo as needed for the commands, I generally assume root access.
I’ll get right on running the scrub again, since this is my first time the disk has given me any trouble.
It’s an 8 TB internal Western Digital Red, connected via SATA.
Is the disk a CMR and not a SMR type? Check the model number as you only mentioned WD Red and some of the line were SMR and not fit for use with ZFS / TrueNAS. I don’t remember what sizes were possible with SMR type.
Also to confirm; connected via sata directly to the motherboard, yeah? No kind of adaptors, right?
Supposedly it’ll be CMR by default, at least according to this Redditor. The drives are:
  • sda: WDC WD80EFAX-68KNBN0 (the one that’s been okay)
  • sdb: WDC WD80EFZX-68UW8N0 (the one with errors)
I think so. This is the output of readlink for both disks:
root@truenas[~]# readlink -f /sys/block/sda
/sys/devices/pci0000:00/0000:00:17.0/ata2/host1/target1:0:0/1:0:0:0/block/sda
root@truenas[~]# readlink -f /sys/block/sdb
/sys/devices/pci0000:00/0000:00:17.0/ata1/host0/target0:0:0/0:0:0:0/block/sdb
The scrub finished overnight and nothing’s showing any errors now. So, unless another error happens in the near future, this was most likely some kind of randomly occurring metadata glitch, and the drive is probably fine for now?
Possible, did you happen to run a smartctl -t long /dev/sd**DRIVELETTERHERE** (use sudo as needed) on the drives yet & look at the results.
Then you’d use smartctl -a /dev/sd# - if you can provide those then maybe we can have a better chance at guessing why the drive dropped & if there are any obvious issues on it.
Sorry they took a while, but here are the smartctl results for the (potentially) problem drive:
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
was completed without error.
been run.
data collection:                (  101) seconds.
capabilities:                    (0x5b) SMART execute Offline immediate.
command.
Self-test supported.
power-saving mode.
Short self-test routine
Extended self-test routine
recommended polling time:        (1125) minutes.
SCT capabilities:              (0x003d) SCT Status supported.
SCT Data Table supported.
Does that mean everything is good for now?
We need the full output of sudo smartctl -x /dev/sdX (or -a) to know. The above is just the header.
Sorry, I must have made a typo, since it looks like I ran it with -c instead -a.
Unfortunately, the drive in question has been flagged as degraded again, after supposedly being all fixed up. :anxious_face_with_sweat:
I’m not sure how I would do this; the drive in question has been unmounted by the system and doesn’t appear in the output of lsblk. How can I run smartctl -a on it under these circumstances?
If not in lsblk then I’d take a look at output of dmesg and see if anything related to crc failures, drive speed negotiation, or fucking anything at all of note.
Afterwards I’d power down, reseat connectors, swap sata cable &/or port if available, and boot up. Afterwards if detected then I’d check output of smartctl
There are a good chunk of lines in the output of dmesg that are in red. Here’s everything from the first red message to the latest:
dmesg -T
[Wed Nov  4 20:00:17 2026] ata2.00: exception Emask 0x10 SAct 0x30000 SErr 0x10000 action 0xe frozen
[Wed Nov  4 20:00:17 2026] ata2.00: irq_stat 0x00400000, PHY RDY changed
[Wed Nov  4 20:00:17 2026] ata2: SError: { PHYRdyChg }
[Wed Nov  4 20:00:17 2026] ata2.00: failed command: READ FPDMA QUEUED
[Wed Nov  4 20:00:17 2026] ata2.00: cmd 60/08:80:78:00:33/00:00:fc:00:00/40 tag 16 ncq dma 4096 in res 40/00:00:00:4f:c2/00:00:00:00:00/00 Emask 0x10 (ATA bus error)
[Wed Nov  4 20:00:17 2026] ata2.00: status: { DRDY }
[Wed Nov  4 20:00:17 2026] ata2.00: cmd 60/08:88:10:d3:36/00:00:fc:00:00/40 tag 17 ncq dma 4096 in res 40/00:01:01:4f:c2/00:00:00:00:00/00 Emask 0x10 (ATA bus error)
[Wed Nov  4 20:00:17 2026] ata2: hard resetting link
[Wed Nov  4 20:00:18 2026] ata2: SATA link down (SStatus 4 SControl 300)
[Wed Nov  4 20:00:23 2026] ata2: hard resetting link
[Wed Nov  4 20:00:23 2026] ata2: SATA link down (SStatus 4 SControl 300)
[Wed Nov  4 20:00:23 2026] ata2: limiting SATA link speed to <unknown>
[Wed Nov  4 20:00:28 2026] ata2: hard resetting link
[Wed Nov  4 20:00:29 2026] ata2: SATA link down (SStatus 4 SControl 3F0)
[Wed Nov  4 20:00:29 2026] ata2.00: disable device
[Wed Nov  4 20:00:29 2026] sd 1:0:0:0: [sda] tag#16 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=11s
[Wed Nov  4 20:00:29 2026] sd 1:0:0:0: [sda] tag#16 Sense Key : Illegal Request [current]
[Wed Nov  4 20:00:29 2026] sd 1:0:0:0: [sda] tag#16 Add. Sense: Unaligned write command
[Wed Nov  4 20:00:29 2026] sd 1:0:0:0: [sda] tag#16 CDB: Read(16) 88 00 00 00 00 00 fc 33 00 78 00 00 00 08 00 00
[Wed Nov  4 20:00:29 2026] I/O error, dev sda, sector 4231200888 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[Wed Nov  4 20:00:29 2026] zio pool=Main vdev=/dev/disk/by-partuuid/28fd2d2e-74af-48da-bf1c-b3eff8cb7f1f error=5 type=1 offset=2166373806080 size=4096 flags=3145856
[Wed Nov  4 20:00:29 2026] sd 1:0:0:0: [sda] tag#17 FAILED Result: hostbyte=DID_OK driverbyte=DRIVER_OK cmd_age=11s
[Wed Nov  4 20:00:29 2026] sd 1:0:0:0: [sda] tag#17 Sense Key : Illegal Request [current]
[Wed Nov  4 20:00:29 2026] sd 1:0:0:0: [sda] tag#17 Add. Sense: Unaligned write command
[Wed Nov  4 20:00:29 2026] sd 1:0:0:0: [sda] tag#17 CDB: Read(16) 88 00 00 00 00 00 fc 36 d3 10 00 00 00 08 00 00
[Wed Nov  4 20:00:29 2026] I/O error, dev sda, sector 4231451408 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[Wed Nov  4 20:00:29 2026] zio pool=Main vdev=/dev/disk/by-partuuid/28fd2d2e-74af-48da-bf1c-b3eff8cb7f1f error=5 type=1 offset=2166502072320 size=4096 flags=3145856
[Wed Nov  4 20:00:29 2026] ata2: EH complete
[Wed Nov  4 20:00:29 2026] sd 1:0:0:0: rejecting I/O to offline device
[Wed Nov  4 20:00:29 2026] I/O error, dev sda, sector 0 op 0x1:(WRITE) flags 0x800 phys_seg 0 prio class 0
[Wed Nov  4 20:00:29 2026] zio pool=Main vdev=/dev/disk/by-partuuid/28fd2d2e-74af-48da-bf1c-b3eff8cb7f1f error=5 type=5 offset=0 size=0 flags=2098304
[Wed Nov  4 20:00:29 2026] I/O error, dev sda, sector 2576 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[Wed Nov  4 20:00:29 2026] I/O error, dev sda, sector 3164816880 op 0x1:(WRITE) flags 0x0 phys_seg 2 prio class 0
[Wed Nov  4 20:00:29 2026] zio pool=Main vdev=/dev/disk/by-partuuid/28fd2d2e-74af-48da-bf1c-b3eff8cb7f1f error=5 type=1 offset=270336 size=8192 flags=1245377
[Wed Nov  4 20:00:29 2026] zio pool=Main vdev=/dev/disk/by-partuuid/28fd2d2e-74af-48da-bf1c-b3eff8cb7f1f error=5 type=2 offset=1620385193984 size=8192 flags=3145856
[Wed Nov  4 20:00:29 2026] ata2.00: detaching (SCSI 1:0:0:0)
[Wed Nov  4 20:00:29 2026] I/O error, dev sda, sector 15623859216 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
[Wed Nov  4 20:00:29 2026] zio pool=Main vdev=/dev/disk/by-partuuid/28fd2d2e-74af-48da-bf1c-b3eff8cb7f1f error=5 type=1 offset=7999414870016 size=8192 flags=1245377
[Wed Nov  4 20:00:29 2026] device offline error, dev sda, sector 15623859728 op 0x0:(READ) flags 0x0 phys_seg 1 prio class 0
I tried swapping the two disks’ SATA connections, and now I can see them both, but the Topology section of the Storage Dashboard says the one that’s been having trouble has one checksum error. Here are its full smartctl -x logs:
root@truenas\[\~\]# smartctl -x /dev/sda
smartctl 7.4 2023-08-01 r5530 [x86_64-linux-6.12.15-production+truenas] (local build)
Copyright (C) 2002-23, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Western Digital Red Plus
Device Model:     WDC WD80EFAX-68KNBN0
Serial Number:    VAJ3P30L
LU WWN Device Id: 5 000cca 099dddb51
Firmware Version: 81.00A81
User Capacity:    8,001,563,222,016 bytes [8.00 TB]
Rotation Rate:    5400 rpm
Form Factor:      3.5 inches
Device is:        In smartctl database 7.3/6293
ATA Version is:   ACS-2, ATA8-ACS T13/1699-D revision 4
SATA Version is:  SATA 3.2, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Nov  5 20:53:02 2026 EST
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Disabled
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, frozen [SEC2]
Wt Cache Reorder: Enabled
Offline data collection status:  (0x84) Offline data collection activity
                                        was suspended by an interrupting command from host.
                                        been run.
data collection:                (   87) seconds.
                                        command.
                                        power-saving mode.
recommended polling time:        ( 869) minutes.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     PO-R--   100   100   016    -    0
  2 Throughput_Performance  --S---   130   130   054    -    100
  3 Spin_Up_Time            POS---   151   151   024    -    538 (Average 540)
  4 Start_Stop_Count        -O--C-   098   098   000    -    11974
  5 Reallocated_Sector_Ct   PO--CK   100   100   005    -    0
  7 Seek_Error_Rate         -O-R--   100   100   067    -    0
  8 Seek_Time_Performance   --S---   128   128   020    -    18
  9 Power_On_Hours          -O--C-   091   091   000    -    64010
 10 Spin_Retry_Count        -O--C-   100   100   060    -    0
 12 Power_Cycle_Count       -O--CK   100   100   000    -    81
192 Power-Off_Retract_Count -O--CK   089   089   000    -    13931
193 Load_Cycle_Count        -O--C-   089   089   000    -    13931
194 Temperature_Celsius     -O----   151   151   000    -    43 (Min/Max 19/56)
196 Reallocated_Event_Count -O--CK   100   100   000    -    0
197 Current_Pending_Sector  -O---K   100   100   000    -    0
198 Offline_Uncorrectable   ---R--   100   100   000    -    0
199 UDMA_CRC_Error_Count    -O-R--   200   200   000    -    0
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      1  Comprehensive SMART error log
0x03       GPL     R/O      1  Ext. Comprehensive SMART error log
0x04       GPL     R/O    256  Device Statistics log
0x04       SL      R/O    255  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x08       GPL     R/O      2  Power Conditions log
0x09           SL  R/W      1  Selective self-test log
0x0c       GPL     R/O   5501  Pending Defects log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x12       GPL     R/O      1  SATA NCQ Non-Data log
0x13       GPL     R/O      1  SATA NCQ Send and Receive log
0x15       GPL     R/W      1  Rebuild Assist log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x24       GPL     R/O    256  Current Device Internal Status Data log
0x25       GPL     R/O    256  Saved Device Internal Status Data log
0x2f       GPL     R/O      1  Set Sector Configuration
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (1 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
# 1  Extended offline    Completed without error       00%     63960         -
# 2  Extended offline    Completed without error       00%     63861         -
# 3  Extended offline    Completed without error       00%     51750         -
# 4  Extended offline    Completed without error       00%     51030         -
# 5  Extended offline    Completed without error       00%     50288         -
# 6  Extended offline    Completed without error       00%     49615         -
# 7  Extended offline    Completed without error       00%     48872         -
# 8  Extended offline    Completed without error       00%     48128         -
# 9  Extended offline    Completed without error       00%     47408         -
#10  Extended offline    Completed without error       00%     46663         -
#11  Extended offline    Completed without error       00%     45943         -
#12  Extended offline    Completed without error       00%     45202         -
#13  Extended offline    Completed without error       00%     44455         -
#14  Extended offline    Completed without error       00%     43735         -
#15  Extended offline    Completed without error       00%     42993         -
#16  Extended offline    Completed without error       00%     42271         -
#17  Extended offline    Completed without error       00%     41529         -
#18  Extended offline    Completed without error       00%     40839         -
#19  Extended offline    Completed without error       00%     40095         -
SCT Status Version:                  3
SCT Version (vendor specific):       256 (0x0100)
Device State:                        SMART Off-line Data Collection executing in background (4)
Current Temperature:                    43 Celsius
Power Cycle Min/Max Temperature:     41/43 Celsius
Lifetime    Min/Max Temperature:     19/56 Celsius
Under/Over Temperature Limit Count:   0/0
SCT Temperature History Version:     2
Temperature Sampling Period:         1 minute
Temperature Logging Interval:        1 minute
Min/Max recommended Temperature:      0/65 Celsius
Min/Max Temperature Limit:           -40/70 Celsius
Temperature History Size (Index):    128 (21)
Index    Estimated Time   Temperature Celsius
  22    2026-11-05 18:46    47  ****************************
 ...    ..(  7 skipped).    ..  ****************************
  30    2026-11-05 18:54    47  ****************************
  31    2026-11-05 18:55    48  *****************************
  32    2026-11-05 18:56    47  ****************************
 ...    ..(  6 skipped).    ..  ****************************
  39    2026-11-05 19:03    47  ****************************
  40    2026-11-05 19:04    48  *****************************
  41    2026-11-05 19:05    48  *****************************
  42    2026-11-05 19:06    47  ****************************
  43    2026-11-05 19:07    47  ****************************
  44    2026-11-05 19:08    48  *****************************
 ...    ..( 98 skipped).    ..  *****************************
  15    2026-11-05 20:47    48  *****************************
  16    2026-11-05 20:48    41  **********************
  17    2026-11-05 20:49    42  ***********************
 ...    ..(  2 skipped).    ..  ***********************
  20    2026-11-05 20:52    42  ***********************
  21    2026-11-05 20:53    47  ****************************
SCT Error Recovery Control:
           Read:     70 (7.0 seconds)
          Write:     70 (7.0 seconds)
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4              81  ---  Lifetime Power-On Resets
0x01  0x010  4           64010  ---  Power-on Hours
0x01  0x018  6    218531238858  ---  Logical Sectors Written
0x01  0x020  6      1538747292  ---  Number of Write Commands
0x01  0x028  6    476136028168  ---  Logical Sectors Read
0x01  0x030  6      2548117877  ---  Number of Read Commands
0x01  0x038  6    230436656500  ---  Date and Time TimeStamp
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4           58819  ---  Spindle Motor Power-on Hours
0x03  0x010  4           58819  ---  Head Flying Hours
0x03  0x018  4           13931  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4               8  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4               1  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              43  ---  Current Temperature
0x05  0x010  1              47  N--  Average Short Term Temperature
0x05  0x018  1              45  N--  Average Long Term Temperature
0x05  0x020  1              56  ---  Highest Temperature
0x05  0x028  1              19  ---  Lowest Temperature
0x05  0x030  1              54  N--  Highest Average Short Term Temperature
0x05  0x038  1              25  N--  Lowest Average Short Term Temperature
0x05  0x040  1              51  N--  Highest Average Long Term Temperature
0x05  0x048  1              25  N--  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              65  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               0  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4             377  ---  Number of Hardware Resets
0x06  0x010  4              62  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
0xff  =====  =               =  ===  == Vendor Specific Statistics (rev 1) ==
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x0001  2            0  Command failed due to ICRC error
0x0002  2            0  R_ERR response for data FIS
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0005  2            0  R_ERR response for non-data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
0x0008  2            0  Device-to-host non-data FIS retries
0x0009  2            2  Transition from drive PhyRdy to drive PhyNRdy
0x000a  2            2  Device-to-host register FISes sent due to a COMRESET
0x000b  2            0  CRC errors within host-to-device FIS
0x000d  2            0  Non-CRC errors within host-to-device FIS
I ran dmesg again after the reboot, but nothing looks suspsicious. There’s this error:
[Thu Nov  5 20:49:28 2026\] Error: Driver 'pcspkr' is already registered, aborting...
But iiuc it doesn’t have to do with my issue.
I’d argue that is either the sata data cable or the port. Small chance power issue - unlikely, but never hurts to reseat connect I guess. Smart looking pretty clean, but given the drives age, I’ll also add small chance of being the drive itself.
I think I asked before, but I can’t find the answer; how is this drive connected to the motherboard? Is it directly to an available sata port? Is it through an HBA? Or something less kosher?
Any chance on additional hardware details; motherboard, hba, psu, etc?
Is this not the correct information to tell?
It’s a prebuilt mini-PC (this one, to be specific; sorry I can’t find a direct link to the seller’s page, since they had ended production shortly before I bought mine), so I don’t know the exact layout of its hardware and I’m reluctant to take it apart to check. If that info above doesn’t specify a direct or indirect connection, is there any command I can run from the terminal to find out, or do I have to take it apart?
Naw that makes 100% more sense. I took a look at some photos posted online & it seems to have a daughter board that takes the sata connections… so basically swapping the drives around was the best next step. If issues persist I’m not sure what would be best to recommend as this looks like a pain in the ass to troubleshoot given the form factor:
Well… that sucks, haha. And here I thought a year ago it’d be so much easier than building my own NAS. :weary_face: So it sounds like there are a few possibilities:
  1. The drive itself is shot and needs to be replaced, which as I understand TrueNAS makes fairly easy to do.
  2. Something is wrong with the SATA connectors and/or something else internal to the system, in which case, I guess I need a new NAS? Maybe I can harvest parts from this one.
Is that correct? I can also try running some tests on the drive from my PC, if that’d be helpful for diagnosing the issue. If so, should I run a ZFS scrub before SMART testing it from there?
Incidentally, if it does need to be replaced, I made this post asking how I might configure qBittorrent for less wear on the disk, and whether that’s necessary at all. I already marked a solution, but just thought I’d cross-reference it here in case anyone else finds it helpful down the line.
This platform might be completely unsuitable for TrueNAS, if the SATA ports are hosted off a port expander daughterboard. Can you post the output of dmesg -TH | grep ahci and lsscsi -v?
