How-To? Memory upgrade Ugreen DXP2800-C754
Hi
I have here
Crucial CT32G48C40S5 1 x 32GB, 4800 MHz, DDR5-RAM, SO-DIMM
How-To make memory upgrade? The first time I do stuff like this. Is there a Youtube video?
The small metal brackets you see at the top and bottom have to be pushed to the sides gently, then the sodimm will pop up slightly like a nvme drive and then you can remove it from the socket.
This video is in german and for another ugreen model but the process should be the same, you can skip to minute 2:45
