The basic process to rename a ZFS pool is to export it from the GUI, import it in the CLI with the new name, then export it again, and re-import it in the GUI.
I find I normally want to do this after creating a new pool (with perhaps a different set of disks/layout), replicating my old pool to the new pool, and then I want to rename the new pool to the same as the old pool, and then all the shares work correctly, and its fairly transparent. Mostly.
(tested with TrueNAS CORE 12U8-1. Works with all versions, including SCALE, see Original Post)
So, firstly, you need to export your pool that you want to rename from the GUI. Note its name.
Before you do that, if your system-dataset is on the pool, its a good idea to move it back to a different pool, or perhaps the boot pool.
System → System Dataset, then select the pool you want to host it, and save.
Once that’s done,
Storage → Pools, the click the cog to the right of the pool you want to rename and choose “Export/Disconnect”
DO NOT TICK “Destroy data on this pool?”
It is up to you if you delete the shares, etc, or have to re-configure them when you re-import the pool.
TICK “Confirm Export/Disconnect” then click EXPORT/DISCONNECT
Once that is finished fire up a terminal and import the pool into the CLI with the new name.
zpool import original_name new_name
(replace original_name and new_name, respectively)
You can check your handy work with zpool status new_name
Then export the pool again
zpool export new_name
Then import it again in the GUI
Pools → Add, import existing
Job Done.
You may need to reconfigure your shares etc.
