Instances disappeared after 25.04.2.1 upgrade (solved)
So this has been a journey wrought with problems with 25.x.x releases. I have 2 zpools named hdd and ssd. I had several virtual machines running on 24.10.x on my ssd pool. Then upgraded to 25.04.1 to find them gone but disks were still available in the dataset. With transition to incus and them being on a bad ssd pool that didn’t perform well due to cheap crappy SSDs, I decided to delete them all and remove the ssd pool. I then recreated them in Instances on hdd pool and had everything working a lot better until I upgraded to 25.04.2.1. Now everything is showing up in virtual machines tab again but I can’t start them as I get an error about ssd pool missing.
File “/usr/lib/python3/dist-packages/middlewared/api/base/server/ws_handler/rpc.py”, line 323, in process_method_call
result = await method.call(app, params)
File “/usr/lib/python3/dist-packages/middlewared/api/base/server/method.py”, line 52, in call
result = await self.middleware.call_with_audit(self.name, self.serviceobj, methodobj, params, app)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 911, in call_with_audit
result = await self._call(method, serviceobj, methodobj, params, app=app,
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 720, in _call
File “/usr/lib/python3/dist-packages/middlewared/api/base/decorator.py”, line 93, in wrapped
result = await func(*args)
File “/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_lifecycle.py”, line 57, in start
await self.middleware.run_in_thread(self._start, vm[‘name’])
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 627, in run_in_thread
return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs)
File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 624, in run_in_executor
File “/usr/lib/python3.11/concurrent/futures/thread.py”, line 58, in run
File “/usr/lib/python3/dist-packages/middlewared/plugins/vm/vm_supervisor.py”, line 68, in _start
self.vms[vm_name].start(vm_data=self._vm_from_name(vm_name))
File “/usr/lib/python3/dist-packages/middlewared/plugins/vm/supervisor/supervisor.py”, line 162, in start
raise CallError(
middlewared.service_exception.CallError: [EFAULT] VM will not start as DISK Device: /dev/zvol/ssd/virtual_machines/chef360-sdwxu6 device(s) are not available.
new update containers showed error and after going to configuration and resaving the configuration to only use my hdd pool all my incus vm’s showed up under containers and booted up.
So found this to be weird. Under virtual machines all my old VM’s from 24.10.x reappeared but were unable to start due to pool missing. My incus instances have the same names so there was a little confusion. Still
Ah, so is “Containers” the new “Instances” that everybody talks about then?
yes, Incus VM instances prior to update 25.04.2 now show up under containers.
