Intel x520 does not work in SCALE 24.04.2
I want to upgrade my home networking to something faster than 1GbE. Bought some switches (4x2.5GbE + 2x10GbE), Intel x520 cards, fiber cables and SFP+ modules.
TrueNAS 24.04.2 sees the card:
lspci -vvv
02:00.0 Ethernet controller [0200]: Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection [8086:10fb] (rev 01)
        Subsystem: Hewlett-Packard Company Ethernet 10Gb 2-port 560SFP+ Adapter [103c:17d3]
        Control: I/O+ Mem+ BusMaster+ SpecCycle- MemWINV- VGASnoop- ParErr- Stepping- SERR- FastB2B- DisINTx+
        Status: Cap+ 66MHz- UDF- FastB2B- ParErr- DEVSEL=fast >TAbort- <TAbort- <MAbort- >SERR- <PERR- INTx-
        Latency: 0, Cache Line Size: 64 bytes
        Interrupt: pin B routed to IRQ 18
        IOMMU group: 1
        Region 0: Memory at f7200000 (32-bit, non-prefetchable) [size=1M]
        Region 2: I/O ports at d020 [size=32]
        Region 3: Memory at f7404000 (32-bit, non-prefetchable) [size=16K]
        Expansion ROM at f7380000 [disabled] [size=512K]
        Capabilities: [40] Power Management version 3
                Flags: PMEClk- DSI+ D1- D2- AuxCurrent=0mA PME(D0+,D1-,D2-,D3hot+,D3cold+)
                Status: D0 NoSoftRst- PME-Enable- DSel=0 DScale=1 PME-
        Capabilities: [50] MSI: Enable- Count=1/1 Maskable+ 64bit+
                Address: 0000000000000000  Data: 0000
                Masking: 00000000  Pending: 00000000
        Capabilities: [70] MSI-X: Enable+ Count=64 Masked-
                Vector table: BAR=3 offset=00000000
                PBA: BAR=3 offset=00002000
        Capabilities: [a0] Express (v2) Endpoint, MSI 00
                DevCap: MaxPayload 512 bytes, PhantFunc 0, Latency L0s <512ns, L1 <64us
                        ExtTag- AttnBtn- AttnInd- PwrInd- RBE+ FLReset+ SlotPowerLimit 0W
                DevCtl: CorrErr+ NonFatalErr+ FatalErr+ UnsupReq+
                        RlxdOrd- ExtTag- PhantFunc- AuxPwr- NoSnoop+ FLReset-
                        MaxPayload 128 bytes, MaxReadReq 512 bytes
                DevSta: CorrErr+ NonFatalErr- FatalErr- UnsupReq+ AuxPwr+ TransPend-
                LnkCap: Port #1, Speed 5GT/s, Width x8, ASPM L0s, Exit Latency L0s unlimited
                        ClockPM- Surprise- LLActRep- BwNot- ASPMOptComp-
                LnkCtl: ASPM Disabled; RCB 64 bytes, Disabled- CommClk+
                        ExtSynch- ClockPM- AutWidDis- BWInt- AutBWInt-
                LnkSta: Speed 5GT/s, Width x8
                        TrErr- Train- SlotClk+ DLActive- BWMgmt- ABWMgmt-
                DevCap2: Completion Timeout: Range ABCD, TimeoutDis+ NROPrPrP- LTR-
                         10BitTagComp- 10BitTagReq- OBFF Not Supported, ExtFmt- EETLPPrefix-
                         EmergencyPowerReduction Not Supported, EmergencyPowerReductionInit-
                         FRS- TPHComp- ExtTPHComp-
                         AtomicOpsCap: 32bit- 64bit- 128bitCAS-
                DevCtl2: Completion Timeout: 50us to 50ms, TimeoutDis- LTR- 10BitTagReq- OBFF Disabled,
                         AtomicOpsCtl: ReqEn-
                LnkCtl2: Target Link Speed: 5GT/s, EnterCompliance- SpeedDis-
                         Transmit Margin: Normal Operating Range, EnterModifiedCompliance- ComplianceSOS-
                         Compliance Preset/De-emphasis: -6dB de-emphasis, 0dB preshoot
                LnkSta2: Current De-emphasis Level: -3.5dB, EqualizationComplete- EqualizationPhase1-
                         EqualizationPhase2- EqualizationPhase3- LinkEqualizationRequest-
                         Retimer- 2Retimers- CrosslinkRes: unsupported
        Capabilities: [e0] Vital Product Data
                Product Name: HP Ethernet 10Gb 2-port 560SFP+ Adapter\x00
                Read-only fields:
                        [PN] Part number: 665247-001
                        [EC] Engineering changes: D-5514
                        [SN] Serial number: MYI54903P0
                        [V0] Vendor specific: 11W/8W PCIeG2x8 2p 10Gb SFP+ Intel 82599
                        [V2] Vendor specific: 5549
                        [V4] Vendor specific: 00110A6C8AB4
                        [V5] Vendor specific: 0D
                        [RV] Reserved: checksum good, 0 byte(s) reserved
                Read/write fields:
                        [V1] Vendor specific: 5.9.22
                        [V3] Vendor specific: 3.0.80
                        [V6] Vendor specific: 2.3.98
                        [YA] Asset tag: N/A
                        [YB] System specific: xxxxxxxxxxxxxxxx
                        [YC] System specific: xxxxxxxxxxxxxxxx
                End
        Capabilities: [100 v1] Advanced Error Reporting
                UESta:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UEMsk:  DLP- SDES- TLP- FCP- CmpltTO- CmpltAbrt- UnxCmplt- RxOF- MalfTLP- ECRC- UnsupReq- ACSViol-
                UESvrt: DLP+ SDES- TLP- FCP+ CmpltTO- CmpltAbrt- UnxCmplt- RxOF+ MalfTLP+ ECRC- UnsupReq- ACSViol-
                CESta:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
                CEMsk:  RxErr- BadTLP- BadDLLP- Rollover- Timeout- AdvNonFatalErr+
                AERCap: First Error Pointer: 00, ECRCGenCap+ ECRCGenEn- ECRCChkCap+ ECRCChkEn-
                        MultHdrRecCap- MultHdrRecEn- TLPPfxPres- HdrLogCap-
                HeaderLog: 00000000 00000000 00000000 00000000
        Capabilities: [140 v1] Device Serial Number 00-00-00-ff-ff-00-00-00
        Capabilities: [150 v1] Alternative Routing-ID Interpretation (ARI)
                ARICap: MFVC- ACS-, Next Function: 1
                ARICtl: MFVC- ACS-, Function Group: 0
        Capabilities: [160 v1] Single Root I/O Virtualization (SR-IOV)
                IOVCap: Migration- 10BitTagReq- Interrupt Message Number: 000
                IOVCtl: Enable- Migration- Interrupt- MSE- ARIHierarchy- 10BitTagReq-
                IOVSta: Migration-
                Initial VFs: 64, Total VFs: 64, Number of VFs: 0, Function Dependency Link: 00
                VF offset: 384, stride: 2, Device ID: 10ed
                Supported Page Size: 00000553, System Page Size: 00000001
                Region 0: Memory at 0000000c00000000 (64-bit, prefetchable)
                Region 3: Memory at 0000000c00100000 (64-bit, prefetchable)
                VF Migration: offset: 00000000, BIR: 0
        Kernel driver in use: ixgbe
        Kernel modules: ixgbe
02:00.1 Ethernet controller [0200]: Intel Corporation 82599ES 10-Gigabit SFI/SFP+ Network Connection [8086:10fb] (rev 01)
        Interrupt: pin A routed to IRQ 17
        IOMMU group: 1
        Region 0: Memory at f7100000 (32-bit, non-prefetchable) [size=1M]
        Region 2: I/O ports at d000 [size=32]
        Region 3: Memory at f7400000 (32-bit, non-prefetchable) [size=16K]
        Expansion ROM at f7300000 [disabled] [size=512K]
                LnkSta2: Current De-emphasis Level: -6dB, EqualizationComplete- EqualizationPhase1-
                Read-only fields:
                Read/write fields:
                        [YA] Asset tag: N/A
                End
                ARICap: MFVC- ACS-, Next Function: 0
                IOVSta: Migration-
                Initial VFs: 64, Total VFs: 64, Number of VFs: 0, Function Dependency Link: 01
                Region 0: Memory at 0000000c00200000 (64-bit, prefetchable)
                Region 3: Memory at 0000000c00300000 (64-bit, prefetchable)
Kernel module is loaded as expected:
dmesg | grep ixgbe
root@lumpek[~]# dmesg|grep ixgbe
[    0.000000] Command line: BOOT_IMAGE=/ROOT/24.04.2@/boot/vmlinuz-6.6.32-production+truenas root=ZFS=boot-pool/ROOT/24.04.2 ro libata.allow_tpm=1 amd_iommu=on iommu=pt kvm_amd.npt=1 kvm_amd.avic=1 intel_iommu=on zfsforce=1 nvme_core.multipath=N ixgbe.allow_unsupported_sfp=1
[    0.018012] Kernel command line: BOOT_IMAGE=/ROOT/24.04.2@/boot/vmlinuz-6.6.32-production+truenas root=ZFS=boot-pool/ROOT/24.04.2 ro libata.allow_tpm=1 amd_iommu=on iommu=pt kvm_amd.npt=1 kvm_amd.avic=1 intel_iommu=on zfsforce=1 nvme_core.multipath=N ixgbe.allow_unsupported_sfp=1
[    1.473678] ixgbe: Intel(R) 10 Gigabit PCI Express Network Driver
[    1.473680] ixgbe: Copyright (c) 1999-2016 Intel Corporation.
[    2.024220] ixgbe 0000:02:00.0: Multiqueue Enabled: Rx Queue count = 4, Tx Queue count = 4 XDP Queue count = 0
[    2.038535] ixgbe 0000:02:00.0: 32.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x8 link)
[    2.046118] ixgbe 0000:02:00.0: MAC: 2, PHY: 19, SFP+: 6, PBA No: G43260-013
[    2.053326] ixgbe 0000:02:00.0: 00:11:0a:xx:xx:xx
[    2.061370] ixgbe 0000:02:00.0: Intel(R) 10 Gigabit Network Connection
[    3.292039] ixgbe 0000:02:00.1: Multiqueue Enabled: Rx Queue count = 4, Tx Queue count = 4 XDP Queue count = 0
[    3.311519] ixgbe 0000:02:00.1: 32.000 Gb/s available PCIe bandwidth (5.0 GT/s PCIe x8 link)
[    3.317963] ixgbe 0000:02:00.1: MAC: 2, PHY: 1, PBA No: G43260-013
[    3.324074] ixgbe 0000:02:00.1: 00:11:0a:xx:xx:xx
[    3.331017] ixgbe 0000:02:00.1: Intel(R) 10 Gigabit Network Connection
[   10.865026] ixgbe 0000:02:00.0 enp2s0f0: renamed from eth2
[   11.041138] ixgbe 0000:02:00.1 enp2s0f1: renamed from eth3
But card does not work. Even with “ixgbe.allow_unsupported_sfp=1” kernel argument (which was not needed under Debian or Fedora).
I wonder where the problem is as card with the same SFP+ module and cable works fine when system boots into Debian with 6.10 or Fedora 39 with 6.5.2 kernels.
Any ideas?
Nevermind. Turned out that card needs to be enabled in TrueNAS settings to progress further…
Silly me.
Hello, I’m new to Truenas so learning. I have the same network card and can’t get it to work. I searched “enable network cards in Truenas” and the like but no useful results. Can you point me to how to enable this card please? Thanks.
Do you have any other NICs?
Screenshot of Networking page would help from GUI
Browse some other threads and do the Tutorial by the Bot to get your forum trust level up and post images and links
TrueNAS-Bot
Type this in a new reply and send to bring up the tutorial, if you haven’t done it already.
@TrueNAS-Bot start tutorial
Hello, thanks for replying. I have other NICs, all of which work. I ran up a Windows server 2012 just to check and the X520 works fine. I even tried it in an even older HP microserver gen 7 N54L and it worked there under Truenas Community edition without having to set anything. Truenas has the drivers, the card works in two other machines. The conclusion I have come to, having explored the settings using the Truenas CLI is that the HP server is blocking the adapter somehow. Not a Truenas issue so suggest close this discussion.
I have the same issue. with a dual X520 SFP+ Nic.
How did you enable the sfp+ port on scale.
Do I need to put Scale in Dev mode and install updated Nic Drivers.
I’m stuck using core 13.3 because of this issue.
