Issues setting up acme.sh
Can you share your script? I am also with EasyDNS and am struggling with this.
Here’s my internal docs, suitably redacted. Some steps are not strictly necessary, just part of our general policy/preferences.
Certificates
Create ZFS dataset
Create a ZFS DataSet named acme to host the installation of acme.sh and our custom script.
In DataSets, click “Add DataSet”, populate with:
  • Parent Path: MyPool
  • Name: acme
  • Dataset Preset: generic
Under ‘advanced options’, change ‘Compression Level’ to ‘ZSTD-3’.
After creation, back in DataSets, select the acme dataset then click “Edit” in the ‘Permissions’ section. Change the owner and group from root to admin and enable the two ‘apply’ checkboxes. No need for recursive since the dataset is empty.
Create custom ACME DNS-authenticator shell script
Download latest acme.sh release from https://github.com/acmesh-official/acme.sh/releases
cd /mnt/MyPool/acme
curl -L -O https://github.com/acmesh-official/acme.sh/archive/refs/tags/3.1.3.tar.gz
tar -xvzf 3.1.3.tar.gz
mv acme.sh-3.1.3/ acme.sh
We don’t want to invoke acme.sh --install as we ordinarily would, because we won’t be invoking acme.sh directly, nor use its cron jobs. Our custom script will instead source it and use some of its functions.
Next create our own script:
touch /mnt/MyPool/acme/acme-shell-auth.sh
chmod 700 /mnt/MyPool/acme/acme-shell-auth.sh
with contents (except add real EASYDNS_Key value!):
#!/bin/bash
### VARIABLES
# Logfile
SCRIPT_DIR=$( cd -- "$( dirname -- "${BASH_SOURCE[0]}" )" &> /dev/null && pwd )
LOGFILE="${SCRIPT_DIR}/acme-shell-auth.log"
# Source acmesh scripts
export USER_AGENT='acme.sh-truenas'
export ACME_FOLDER="${SCRIPT_DIR}/acme.sh" # Change this path to reflect your environment
export ACME_DNSAPI="${ACME_FOLDER}/dnsapi"
export PROVIDER="dns_easydns" # Find provider script in 'dnsapi' folder (without .sh extension)
source "${ACME_FOLDER}/acme.sh" > /dev/null 2>&1
source "${ACME_DNSAPI}/${PROVIDER}.sh" > /dev/null 2>&1
# DNS API authentication. See details for your provider https://github.com/acmesh-official/acme.sh/wiki/dnsapi
export EASYDNS_Key="apiXXXXXXXXXXXXXXXXX"
export EASYDNS_Token="token-my-domain"
### FUNCTIONS
_log_output() {
        echo `date "+[%a %b %d %H:%M:%S %Z %Y]"`" $1" >> ${LOGFILE}
### MAIN
_log_output "INFO Script started with params: $1 $2 $3 $4"
# File/folder validation
if [ ! -d "${ACME_FOLDER}" ]; then
        _log_output "ERROR Invalid acme folder: ${ACME_FOLDER}"
        return 1
fi
if [ ! -f "${LOGFILE}" ]; then
        touch "${LOGFILE}"
        chmod 500 "${LOGFILE}"
fi
# Main
if [ "${1}" == "set" ]; then
        ${PROVIDER}_add "${3}" "${4}" >> ${LOGFILE} 2>/dev/null
elif [ "${1}" == "unset" ]; then
        ${PROVIDER}_rm "${3}" "${4}" >> ${LOGFILE} 2>/dev/null
fi
_log_output "INFO Script finished."
Note that the above script sources acme.sh and acme.sh/dnsapi/dns_easydns.sh then directly invokes functions (dns_easydns_add and dns_easydns_rm) from the latter. This is because all TrueNAS needs from our script is to add (then remove) TXT records from public DNS, it does the rest.
Add custom ACME DNS-authenticator
In Credentials > Certificates > ACME DNS-Authenticators, click “Add”.
Populate with:
  • Name: acme-easydns
  • Authenticator: shell
  • Script: /mnt/MyPool/acme/acme-shell-auth.sh
  • User: truenas_admin
  • Timeout: empty (will default to 60)
  • Delay: empty (will default to 60)
Create certificate signing request (CSR)
General instructions: https://www.truenas.com/docs/scale/scaletutorials/credentials/certificates/addcsrsscale/
In Credentials > Certificates > Certificate Signing Requests, click “Add”.
Populate with:
Create actual certificate
In Credentials > Certificates > Certificate Signing Requests, click the wrench icon.
Populate with:
  • Identifier: MyDomain-Cert
  • Term of service: checked
  • ACME Server Directory URI: Let’s Encrypt Production
  • Domains: click popups and choose acme-easydns
Make sure the firewall allows outgoing connection to EasyDNS and Let’s Encrypt.
Apply certificate
In System > General Settings > GUI, edit the settings and change GUI SSL Certificate to MyDomain-Cert.
References
This was figured out mostly from:
https://forums.truenas.com/t/issues-setting-up-acme-sh/47869/5
https://www.truenas.com/community/threads/howto-acme-dns-authenticator-shell-script-using-acmesh-project.107252/
https://www.youtube.com/watch?v=TJ5fDiDRcbU&t=99s
