Issues with web UI address binding (CE 25.10.0.1)
I’m setting up networking on the new machine with Goldeye and I’m trying to configure the management web address binding (System→General Settings→GUI). Noticing a couple things:
  1. The drop-down box where we should select one or more recent IPv4 addresses to bind does not include addresses leased from DHCP. I had to change my config to a static IP in order to make it available here. As I’m using static leases on my firewall I’d prefer to keep DHCP enabled, but this isn’t a huge issue for IPv4.
  2. I use SLAAC on my network and have IPv6 auto-configuration enabled (I think TrueNAS is using EUI-64 stable addresses by default) and those are not listed in the drop-down. It’s stuck on ‘::’ as the only option here which I think is a bigger issue.
Are there known issues / limitations? Anyone have a work-around?
Thanks!
