Kubernetes service not running error
I fresh installed Scale 22.12.4.2. With everything set up I try to load apps. I am able to find apps to load. When I try to install, say Plex, I get;
Error: [EFAULT] Kubernetes service is not running.
Error: Traceback (most recent call last): File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 427, in run await self.future File “/usr/lib/python3/dist-packages/middlewared/job.py”, line 465, in __run_body rv = await self.method(*([self] + args)) File “/usr/lib/python3/dist-packages/middlewared/schema.py”, line 1247, in nf res = await f(*args, **kwargs) File “/usr/lib/python3/dist-packages/middlewared/schema.py”, line 1379, in nf return await func(*args, **kwargs) File “/usr/lib/python3/dist-packages/middlewared/plugins/chart_releases_linux/chart_release.py”, line 397, in do_create await self.middleware.call(‘kubernetes.validate_k8s_setup’) File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1368, in call return await self._call( File “/usr/lib/python3/dist-packages/middlewared/main.py”, line 1317, in _call return await methodobj(*prepared_call.args) File “/usr/lib/python3/dist-packages/middlewared/plugins/kubernetes_linux/update.py”, line 513, in validate_k8s_setup raise CallError(error) middlewared.service_exception.CallError: [EFAULT] Kubernetes service is not running.
How do I get around this?
This version is three years old–why?
iX discarded the Kubernetes-based apps ecosystem with the release of 24.10 over a year ago, and I don’t expect their apps catalogs are available, much less viable, any more. Recommend upgrading to 25.04 for the current apps system.
Why do you use such an old version of scale?
Kubernetes is deprecated, guess the catalogue is not available anymore.
I will update straight away! Thank you
Intalling 25.04.6 would be faster then updating through each major vertion to get to the current stable version…
