MacOS SMB Problems
we are having very weird and specific problems with MacOS Users and their integration in the MacOS keychain for easier access.
Very important kontext is, that this already worked, but now it does not anymore. What we did is move the ProxMox VM to a new machine, disable the share on the old machine, then sync the pools and lastly enable the share again on the new Server. Now only the Mac Users are having problems. The ACLs seem to be fucked up. They can see, open, edit folders and files that were there before the transfer. But if they now create a folder or file, all other users cant access these files and even tho they access the smb share via the provided ACL compliant user data, the file permissions do not seem to apply. We already tried to reset all permissions recursively and reset all the user and group permissions before, but nothing changed.
Can no one help here?
If anone finds this…
No solution was ever found and no help was provided. We just moved everything to an omv instance via rsync and ended up using this instead. Works flawless ever since.
