Sorry about that. Yes it was an error for a while back. It was a daily issue back then. So the log had 1000s of those. I just grabbed one at random from my grep. Here is the more recent one.
[2026/07/16 15:19:55] (ERROR) aiohttp.server.log_exception():481 - Error handling request from 127.0.0.1 @cee:{“TNLOG”: {“exception”: “Traceback (most recent call last):\n File \”/usr/lib/python3/dist-packages/aiohttp/web_protocol.py\“, line 510, in _handle_request\n resp = await request_handler(request)\n ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n File \”/usr/lib/python3/dist-packages/aiohttp/web_app.py\“, line 569, in _handle\n return await handler(request)\n ^^^^^^^^^^^^^^^^^^^^^^\n File \”/usr/lib/python3/dist-packages/aiohttp/web_middlewares.py\“, line 117, in impl\n return await handler(request)\n ^^^^^^^^^^^^^^^^^^^^^^\n File \”/usr/lib/python3/dist-packages/aiohttp/web_middlewares.py\“, line 105, in impl\n return await handler(request)\n ^^^^^^^^^^^^^^^^^^^^^^\n File \”/usr/lib/python3/dist-packages/aiohttp/web_urldispatcher.py\“, line 212, in handler_wrapper\n result = await result\n ^^^^^^^^^^^^\n File \”/usr/lib/python3/dist-packages/middlewared/api/base/server/ws_handler/base.py\“, line 25, in _call_\n origin = await self.get_origin(request)\n ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n File \”/usr/lib/python3/dist-packages/middlewared/api/base/server/ws_handler/base.py\“, line 40, in get_origin\n return await self.middleware.run_in_thread(ConnectionOrigin.create, request)\n ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n File \”/usr/lib/python3/dist-packages/middlewared/main.py\“, line 670, in run_in_thread\n return await self.run_in_executor(io_thread_pool_executor, method, *args, **kwargs)\n ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n File \”/usr/lib/python3/dist-packages/middlewared/main.py\“, line 667, in run_in_executor\n return await loop.run_in_executor(pool, functools.partial(method, *args, **kwargs))\n ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n File \”/usr/lib/python3.11/concurrent/futures/thread.py\“, line 58, in run\n result = self.fn(*self.args, **self.kwargs)\n ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n File \”/usr/lib/python3/dist-packages/middlewared/utils/origin.py\“, line 66, in create\n fam, la, lp, ra, rp, ssl = get_tcp_ip_info(sock, request)\n ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^\n File \”/usr/lib/python3/dist-packages/middlewared/utils/origin.py\“, line 212, in get_tcp_ip_info\n with DiagSocket() as ds:\n ^^^^^^^^^^^^\n File \”/usr/lib/python3/dist-packages/pyroute2/netlink/diag/_init_.py\“, line 330, in _init_\n super(DiagSocket, self)._init_(NETLINK_SOCK_DIAG)\n File \”/usr/lib/python3/dist-packages/pyroute2/netlink/nlsocket.py\“, line 844, in _init_\n self._ctrl_read, self._ctrl_write = os.pipe()\n ^^^^^^^^^\nOSError: [Errno 24] Too many open files”, “type”: “PYTHON_EXCEPTION”, “time”: “2026-07-16 19:19:55.496594”}}
