My first NAS build and Lenovo 430-16i (9400-16i) : does Crossflashing is really supported?
Hi everyone,
I’m building my first TrueNas server:
  • Jonsbo N6
  • ASUS B550M TUF PLUS WIFI II
  • RYZEN 5750G PRO (with GPU and ECC)
  • 64GB DDR4 RAM Kingston (with ECC)
  • 450W SFX Bequiet PSU 80+ gold
  • 2TB SSD lexar 790NM
  • 8x ironwolf pro 4TB (Max seq 214 MB/sec)
Now i need to choose an HBA controller.
My motherboard has 3 pci express 3.0 slot: 16x, 4x, 1x.
Now:
  • LSI 9300 series I’ve excluded for power consumption issue.
  • 9211 series been working at pci 2.0 4x in my movo could be working too much on the edge…moreover that from “art of server test” the real bandwidth of that controller even if plugged in 8x slot is 1700MB/s that is more or less my theoretical maximum with 8HDD…and I would like to have a bit of room…
  • Choice is between 9500-8i and 9400-16i. 9400-16i I would prefer for cost and number of connections: but the only one I find is Lenovo 430-16i. And now I arrive to the point.
Reading here in this user post :
http://forums.truenas.com/t/lenovo-430-16i-flash-and-cache-logging-issue
seems the user did a legit Crossflashing by using the UEFI interface as it should be, of the Lenovo 430 16i.
Why he get those cache log errors?
Looking here:
(Lenovo 430 gist GitHub - sorry I couldn’t include links)
No one is mentioning such issues…maybe they just didn’t noticed ?
My worry is that if Crossflashing doesn’t work in proper way , it means there are some hardware differences on the board…
what you can suggest ? Does the Lenovo be the best choice or better spend more on the 9500 ?
Thanks a lot in advance,
HS
I suspect that it is too late because you already have the components… but the best choice would have been a motherboard with 8 SATA ports and no HBA. (Keeping your DDR4 ECC UDIMM: AsRock Rack E3C246D4U2-2T and Core i3-9100 or Xeon 2100/2200.)
450 W feels a bit short for 8 HDDs.
2 TB is way too large for a boot drive.
Thanks for the reply!
Is not too late because I bought everything on Amazon and pack still not arrived, I can easily send back.
I don’t understand: it’s written everywhere in every guide to NOT use motherboard SATA ports, and buy instead HBA….now is changed ?
HD is maximum 8W per HD. Even considering 10W is 80W HDDs. 65W CPU. Consider other 50W between motherboard ram and fans. We’re less than 200W. And exactly in the sweet spot of PSU pfc factor. How 450W psu is not enough ?
I3 9100 doesn’t have ram ECC and Xeon 2100 is not easy to find here.
I’ve also 1TB new ssd, I’ll use this for OS.
Thanks a lot for the possible clarification
HS
Where ?
The i3 9100 does support ECC. And you will never reach 1700MB/s anyway. Also your chosen motherboard has only 2.5G ethernet and its a wonky realtek chip.
The motherboard @etorix recommendet is a much better choice.
Written literally everywhere, to buy HBA cards for TrueNAS.
Maybe I’m blind but from intel ark website I didn’t saw the ecc support for i3 9100.
Anyway: the original question about the Lenovo 430-16i, what do you think ?
A dedicated HBA is required if you virtualize truenas in proxmox or esxi, not if you use it bare metal
I would go for a LSI 9400-8i. If you are adamant in building a server with a gaming motherboard.
I can change mobo, do you have any suggestions for AM4 socket micro atx server mobo?
I can switch to X570D4U
Thats a solid board. If you need transcoding, i would check how plex/jellyfin/emby works with AMD first.
I’ve a proxmox application server with intel cpu and latest arc iGPU. I just need a pure smb filesharing server with the maximum protection on the data ( raid Z3)
One last question: the X570D4U has a gbit Ethernet intel: does TrueNAS handle them in link aggregation to be able to maximise to 2gbit/sec ?
You can set up lagg in truenas, but your switch/router also has to support it.
Also remember that link aggregation doesn’t add (as an example) 2 * 1Gb link together to make 2Gb). Its still 2 seperate 1 Gb links. Each client will use one of the links. So a client will still be limited to 1Gb. A second client may or may not use the same link but is still limited to 1Gb. You cannot really control which client uses which link
Link aggregation only really works to increase available server bandwidth with a large number of clients. It does however provide some redundancy if one link fails.
In the case I keep using the gaming motherboard (maybe with and intel 2.5gbit pci express) …which problem you think it could create ? Important for me is to not have any data loss on the ZFS pool…I’m trying to have the biggest reliability on my data
No, it’s not.
As has been mentioned HBA is recommended if you want to virtualise TrueNAS.
HBAs are also recommended if you don’t have enough ports and you need to get some form of expansion card. In this case HBA are recommended over SATA cards.
In other words, if you are not virtualising TrueNAS and you have enough motherboard ports for the drives you want to use, there’s no reason to use an HBA. In fact, doing so needlessly complicates the setup by adding one more thing that needs to be configured (and that can fail) not to mention the additional cooling need/power usage.
In that case I would recommend ECC RAM as one layer of protection. Also, if this system will be your fileserver, where you store your files, it’s not really a backup. While ZFS is a good choice when it comes to data integrity, it’s not magic. Sometimes unexpected things happen that can result in total pool loss, for example external factors or straight up user error.
To protect against that the recommendation is to have multiple copies of your data. A single system that holds all your data does not fulfil that role by itself.
Given the above seems to be too much unreliable trueNAS.
I’m start to think to send everything back and buy a QNAP ZFS.
The fact that a Realtek lan could causa data corruption up to require an ECC Memory… is scary as hell!
TCP/IP layer that could cause data corruption… is pretty unbelievable given any hardware nic you want….
ZFS can only work with the data it is given.
Using consumer hardware has its caveats. One is crappy realtek NIC chips. These gaming boards are not built for 24/7 operation and heavy i/o through the NIC.
You dont want wifi and RGB on a NAS either.
The Synology/QNAP ZFS systems also dont use gaming components.
I’m sorry, what?
Nevermind.
A prebuilt QNAP seems to be a sensible choice given your situation.
Mind you, that does not change the second half of my previous post, the bit about the NAS not being a backup all by itself.
Consider for a moment what would happen if you accidentally delete all your files because you were tired and messed up? Or if you get caught on the network cable going to the server, tripping and pulling the entire NAS from 5 feet up straight into the floor? Or your basement suddenly got flooded for whatever reason. Don’t keep a single copy of data you can’t afford to lose.
I’m not a newbie on NAS. I’ve already implemented a 3 2 1 backup strategy:
Ive an old ASUSTOR NAS now With snapshot activated everyday.
Backup up everything on a QNAP 2 slot nas in raid 1 every week
Backup to Google cloud storage every week.
I just wanted to replace the asustor NAS with something more reliable and future proof.
But I understand from your comments that is too much pain….
IMHO they are pointing you in the direction to avoid pain :smile:
