My truenas 25.04.1 will restart after a while
My TrueNAS 25.04.1 keeps rebooting after a while. The logs only show systemd shutting down normally. Here are the logs. Does anyone know why?
root@truenas[~]# cat /var/log/messages | grep -B 20 ‘systemd-shutdow’
Jul 2 21:51:23 truenas kernel: sd 0:0:12:0: [sdj] Attached SCSI disk
Jul 2 21:51:28 truenas netdata[2199442]: CONFIG: cannot load cloud config ‘/var/lib/netdata/cloud.d/cloud.conf’. Running with internal defaults.
Jul 2 21:56:37 truenas syslog-ng[3191]: syslog-ng shutting down; version=‘3.38.1’
Jul 2 22:00:48 truenas syslog-ng[3178]: syslog-ng starting up; version=‘3.38.1’
Jul 2 21:56:37 truenas kernel: br-81e97f04fd46: port 1(vethb2317b1) entered disabled state
Jul 2 21:56:37 truenas kernel: veth9747288: renamed from eth0
Jul 2 21:56:37 truenas kernel: vethb2317b1 (unregistering): left allmulticast mode
Jul 2 21:56:37 truenas kernel: vethb2317b1 (unregistering): left promiscuous mode
Jul 2 21:56:43 truenas kernel: kauditd_printk_skb: 7 callbacks suppressed
Jul 2 21:56:43 truenas kernel: audit: type=1305 audit(1751464603.494:2515): op=set audit_pid=0 old=3072 auid=4294967295 ses=4294967295 subj=unconfined res=1
Jul 2 21:56:43 truenas kernel: audit: type=1305 audit(1751464603.506:2516): op=remove_rule dir=“/data/” key=“escalation” list=4 res=1
Jul 2 21:56:44 truenas kernel: audit: type=1334 audit(1751464604.214:2517): prog-id=134 op=UNLOAD
Jul 2 21:56:44 truenas kernel: audit: type=1334 audit(1751464604.214:2518): prog-id=133 op=UNLOAD
Jul 2 21:56:44 truenas kernel: audit: type=1334 audit(1751464604.222:2519): prog-id=138 op=UNLOAD
Jul 2 21:56:44 truenas kernel: audit: type=1334 audit(1751464604.222:2520): prog-id=137 op=UNLOAD
Jul 2 21:56:44 truenas kernel: audit: type=1334 audit(1751464604.222:2521): prog-id=136 op=UNLOAD
Jul 2 21:56:44 truenas kernel: audit: type=1334 audit(1751464604.222:2522): prog-id=141 op=UNLOAD
Jul 2 21:56:44 truenas kernel: audit: type=1334 audit(1751464604.222:2523): prog-id=140 op=UNLOAD
Jul 2 21:56:58 truenas systemd-journald[756]: Received SIGTERM from PID 1 (systemd-shutdow).
Jul 10 22:30:13 truenas kernel: [771208]: scst_rx_mgmt_fn:7008:TM fn UNREG_SESS_TM/10 (mcmd 000000002f4cf466)
Jul 10 22:30:13 truenas kernel: [771208]: scst_rx_mgmt_fn:7012:sess=00000000c967aecf, tag_set 0, tag 0, lun_set 0, lun=0, cmd_sn_set 0, cmd_sn 0, priv 0000000000000000
Jul 10 22:30:13 truenas kernel: [771208]: scst_post_rx_mgmt_cmd:6933:Adding mgmt cmd 000000002f4cf466 to active mgmt cmd list
Jul 10 22:30:13 truenas kernel: [3691]: scst_tm_thread:6819:Deleting mgmt cmd 000000002f4cf466 from active cmd list
Jul 10 22:30:13 truenas kernel: [3691]: scst_abort_all_nexus_loss_sess:6167:Nexus loss or UNREG SESS for sess 00000000c967aecf (mcmd 000000002f4cf466)
Jul 10 22:30:13 truenas kernel: [3691]: scst_mgmt_cmd_send_done:6673:TM fn 10 (mcmd 000000002f4cf466) finished, status 0
Jul 10 22:30:13 truenas kernel: [771208]: scst_suspend_activity:871:suspend_count 0
Jul 10 22:30:13 truenas kernel: [771208]: scst_susp_wait:827:wait_event() returned 0
Jul 10 22:30:13 truenas kernel: [771208]: __scst_resume_activity:969:suspend_count 0 left
Jul 10 22:30:17 truenas kernel: kauditd_printk_skb: 7 callbacks suppressed
Jul 10 22:30:17 truenas kernel: audit: type=1305 audit(1752157817.959:950): op=set audit_pid=0 old=3285 auid=4294967295 ses=4294967295 subj=unconfined res=1
Jul 10 22:30:18 truenas kernel: audit: type=1305 audit(1752157817.995:951): op=remove_rule dir=“/data/” key=“escalation” list=4 res=1
Jul 10 22:31:43 truenas kernel: audit: type=1334 audit(1752157903.111:952): prog-id=38 op=UNLOAD
Jul 10 22:31:43 truenas kernel: audit: type=1334 audit(1752157903.111:953): prog-id=37 op=UNLOAD
Jul 10 22:31:43 truenas kernel: audit: type=1334 audit(1752157903.115:954): prog-id=33 op=UNLOAD
Jul 10 22:31:43 truenas kernel: audit: type=1334 audit(1752157903.115:955): prog-id=32 op=UNLOAD
Jul 10 22:31:43 truenas kernel: audit: type=1334 audit(1752157903.115:956): prog-id=31 op=UNLOAD
Jul 10 22:31:43 truenas kernel: audit: type=1334 audit(1752157903.119:957): prog-id=36 op=UNLOAD
Jul 10 22:31:43 truenas kernel: audit: type=1334 audit(1752157903.119:958): prog-id=35 op=UNLOAD
Jul 10 22:32:13 truenas systemd-journald[767]: Received SIGTERM from PID 1 (systemd-shutdow).
Jul 18 13:02:25 truenas kernel: [1371196]: scst_unregister_session:7551:Unregistering session 0000000040173184 (wait 1)
Jul 18 13:02:25 truenas kernel: [1371196]: scst_rx_mgmt_fn:7008:TM fn UNREG_SESS_TM/10 (mcmd 0000000049b4c81a)
Jul 18 13:02:25 truenas kernel: [1371196]: scst_rx_mgmt_fn:7012:sess=0000000040173184, tag_set 0, tag 0, lun_set 0, lun=0, cmd_sn_set 0, cmd_sn 0, priv 0000000000000000
Jul 18 13:02:25 truenas kernel: [1371196]: scst_post_rx_mgmt_cmd:6933:Adding mgmt cmd 0000000049b4c81a to active mgmt cmd list
Jul 18 13:02:25 truenas kernel: [3496]: scst_tm_thread:6819:Deleting mgmt cmd 0000000049b4c81a from active cmd list
Jul 18 13:02:25 truenas kernel: [3496]: scst_abort_all_nexus_loss_sess:6167:Nexus loss or UNREG SESS for sess 0000000040173184 (mcmd 0000000049b4c81a)
Jul 18 13:02:25 truenas kernel: [3496]: scst_mgmt_cmd_send_done:6673:TM fn 10 (mcmd 0000000049b4c81a) finished, status 0
Jul 18 13:02:25 truenas kernel: [1371196]: scst_suspend_activity:871:suspend_count 0
Jul 18 13:02:25 truenas kernel: [1371196]: scst_susp_wait:827:wait_event() returned 0
Jul 18 13:02:25 truenas kernel: [1371196]: __scst_resume_activity:969:suspend_count 0 left
Jul 18 13:02:30 truenas kernel: audit: type=1305 audit(1752814950.109:1412): op=set audit_pid=0 old=3112 auid=4294967295 ses=4294967295 subj=unconfined res=1
Jul 18 13:02:30 truenas kernel: audit: type=1305 audit(1752814950.149:1413): op=remove_rule dir=“/data/” key=“escalation” list=4 res=1
Jul 18 13:02:31 truenas kernel: audit: type=1334 audit(1752814951.304:1414): prog-id=32 op=UNLOAD
Jul 18 13:02:31 truenas kernel: audit: type=1334 audit(1752814951.304:1415): prog-id=31 op=UNLOAD
Jul 18 13:02:31 truenas kernel: audit: type=1334 audit(1752814951.308:1416): prog-id=36 op=UNLOAD
Jul 18 13:02:31 truenas kernel: audit: type=1334 audit(1752814951.308:1417): prog-id=35 op=UNLOAD
Jul 18 13:02:31 truenas kernel: audit: type=1334 audit(1752814951.312:1418): prog-id=39 op=UNLOAD
Jul 18 13:02:31 truenas kernel: audit: type=1334 audit(1752814951.312:1419): prog-id=38 op=UNLOAD
Jul 18 13:02:31 truenas kernel: audit: type=1334 audit(1752814951.312:1420): prog-id=37 op=UNLOAD
Jul 18 13:02:31 truenas systemd-journald[767]: Received SIGTERM from PID 1 (systemd-shutdow).
My disks have warnings, but that shouldn’t cause a reboot, right?
2025 Jul 24 15:36:32 truenas Device: /dev/sdg, SMART Failure: Data channel impending failure general hard drive failure
Please post logs and such as Preformtted Text </> on toolbar or Ctrl+e. It’s easier to read.
Please post a detailed hardware listing, OS version. You can expand ‘Details’ under my post to get an idea of what I’m asking for.
We can only go off what you post to the forums, so please be detailed in what was happening with your system and any steps you have tried.
Without knowing anything else. I would suggest doing a CPU and memory stress tests with a Live Linux CD. Guessing hardware issues.
