NAS reboot caused No Pools Found
What are your drives connected to?
Harddrives are directly connected to the motherboard via SATA cables
You may need to dive deeper, which I’m not comfortable with.
So you’re not without some understanding of what you tried:
  • We confirmed that the OS detects the disks and their partitions
  • Two 12-TB disks, each with a swap partition and a ZFS partition
  • zpool import claims there are no available pools to import
  • zpool import -d /dev/disk/by-partuuid cannot even detect the ZFS metadata on the supposed partitions, even when instructed to explicitly look for them with known PARTUUIDs.
Since you’re not using an HBA or “RAID” card, it also rules those out.
Someone might come in here with zdb commands, which are too low level for my comfort.
Thanks for the explanation - I guess it’s still unknown why the sudden restart can cause the drives to suddenly be “unmounted” from the pool
(not sure if thats the correct terminology)
corrupted something perhaps leading to it being unreadable
It is concerning.
Unless the reboot was caused by faulty power or an electrical issue, and somehow managed to damage both HDDs, but not enough to make them undetecable or ruin their partition tables.
Doesn’t hurt to run a short (and if you’re willing, a long) SMART selftest on both drives.
While you’re at it, to check some SMART info before running any tests:
smartctl -l selftest /dev/sda
smartctl -l error /dev/sda
smartctl -x /dev/sda
Repeat for sdb as well.
root@truenas[~]# smartctl -l selftest /dev/sda
smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.131+truenas] (local build)
# 1  Short offline       Completed without error       00%       273         -
# 2  Short offline       Completed without error       00%       105         -
# 3  Extended offline    Completed without error       00%        23         -
# 4  Short offline       Completed without error       00%         6         -
SMART Error Log Version: 1
No Errors Logged
Device Model:     ST12000NM0127
Serial Number:    ZJV59MC0
LU WWN Device Id: 5 000c50 0b66ef478
Firmware Version: G006
User Capacity:    12,000,138,625,024 bytes [12.0 TB]
Rotation Rate:    7200 rpm
Form Factor:      3.5 inches
Device is:        Not in smartctl database [for details use: -P showall]
ATA Version is:   ACS-3 T13/2161-D revision 5
SATA Version is:  SATA 3.1, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Thu Feb 20 20:30:29 2025 EST
SMART support is: Enabled
AAM feature is:   Unavailable
APM feature is:   Unavailable
Rd look-ahead is: Enabled
Write cache is:   Enabled
DSN feature is:   Unavailable
ATA Security is:  Disabled, frozen [SEC2]
Wt Cache Reorder: Enabled
General SMART Values:
Offline data collection status:  (0x82) Offline data collection activity
                                        was completed without error.
                                        been run.
data collection:                (  567) seconds.
capabilities:                    (0x7b) SMART execute Offline immediate.
                                        command.
                                        Self-test supported.
                                        power-saving mode.
Short self-test routine
recommended polling time:        (   1) minutes.
Extended self-test routine
recommended polling time:        (1067) minutes.
Conveyance self-test routine
SCT capabilities:              (0x50bd) SCT Status supported.
                                        SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAGS    VALUE WORST THRESH FAIL RAW_VALUE
  1 Raw_Read_Error_Rate     POSR--   081   064   044    -    127227163
  3 Spin_Up_Time            PO----   093   090   000    -    0
  4 Start_Stop_Count        -O--CK   100   100   020    -    30
  5 Reallocated_Sector_Ct   PO--CK   100   100   010    -    0
  7 Seek_Error_Rate         POSR--   079   060   045    -    84227424
  9 Power_On_Hours          -O--CK   097   097   000    -    2898
 10 Spin_Retry_Count        PO--C-   100   100   097    -    0
 12 Power_Cycle_Count       -O--CK   100   100   020    -    31
184 End-to-End_Error        -O--CK   100   100   099    -    0
187 Reported_Uncorrect      -O--CK   100   100   000    -    0
188 Command_Timeout         -O--CK   100   100   000    -    0
190 Airflow_Temperature_Cel -O---K   066   053   040    -    34 (Min/Max 22/34)
192 Power-Off_Retract_Count -O--CK   100   100   000    -    125
193 Load_Cycle_Count        -O--CK   100   100   000    -    148
194 Temperature_Celsius     -O---K   034   047   000    -    34 (0 20 0 0 0)
195 Hardware_ECC_Recovered  -O-RC-   011   006   000    -    127227163
197 Current_Pending_Sector  -O--C-   100   100   000    -    0
198 Offline_Uncorrectable   ----C-   100   100   000    -    0
199 UDMA_CRC_Error_Count    -OSRCK   200   200   000    -    0
200 Multi_Zone_Error_Rate   PO---K   100   100   001    -    0
240 Head_Flying_Hours       ------   100   253   000    -    2879 (35 3 0)
241 Total_LBAs_Written      ------   100   253   000    -    19498374381
242 Total_LBAs_Read         ------   100   253   000    -    48170653765
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
                            |||____ S speed/performance
                            ||_____ O updated online
                            |______ P prefailure warning
General Purpose Log Directory Version 1
SMART           Log Directory Version 1 [multi-sector log support]
Address    Access  R/W   Size  Description
0x00       GPL,SL  R/O      1  Log Directory
0x01           SL  R/O      1  Summary SMART error log
0x02           SL  R/O      5  Comprehensive SMART error log
0x03       GPL     R/O      5  Ext. Comprehensive SMART error log
0x04       GPL     R/O    256  Device Statistics log
0x04       SL      R/O      8  Device Statistics log
0x06           SL  R/O      1  SMART self-test log
0x07       GPL     R/O      1  Extended self-test log
0x08       GPL     R/O      2  Power Conditions log
0x09           SL  R/W      1  Selective self-test log
0x0c       GPL     R/O   2048  Pending Defects log
0x10       GPL     R/O      1  NCQ Command Error log
0x11       GPL     R/O      1  SATA Phy Event Counters log
0x13       GPL     R/O      1  SATA NCQ Send and Receive log
0x15       GPL     R/W      1  Rebuild Assist log
0x21       GPL     R/O      1  Write stream error log
0x22       GPL     R/O      1  Read stream error log
0x24       GPL     R/O    768  Current Device Internal Status Data log
0x30       GPL,SL  R/O      9  IDENTIFY DEVICE data log
0x80-0x9f  GPL,SL  R/W     16  Host vendor specific log
0xa1       GPL,SL  VS      24  Device vendor specific log
0xa2       GPL     VS   16320  Device vendor specific log
0xa4       GPL,SL  VS     160  Device vendor specific log
0xa6       GPL     VS     192  Device vendor specific log
0xa8-0xa9  GPL,SL  VS     136  Device vendor specific log
0xab       GPL     VS       1  Device vendor specific log
0xad       GPL     VS      16  Device vendor specific log
0xaf       GPL,SL  VS       1  Device vendor specific log
0xbe-0xbf  GPL     VS   65535  Device vendor specific log
0xc1       GPL,SL  VS       8  Device vendor specific log
0xc3       GPL,SL  VS      32  Device vendor specific log
0xc9       GPL,SL  VS       8  Device vendor specific log
0xca       GPL,SL  VS      16  Device vendor specific log
0xd1       GPL     VS     336  Device vendor specific log
0xd2       GPL     VS   10000  Device vendor specific log
0xd4       GPL     VS    2048  Device vendor specific log
0xda       GPL,SL  VS       1  Device vendor specific log
0xe0       GPL,SL  R/W      1  SCT Command/Status
0xe1       GPL,SL  R/W      1  SCT Data Transfer
SMART Extended Comprehensive Error Log Version: 1 (5 sectors)
No Errors Logged
SMART Extended Self-test Log Version: 1 (1 sectors)
SCT Status Version:                  3
SCT Version (vendor specific):       522 (0x020a)
Device State:                        Active (0)
Current Temperature:                    34 Celsius
Power Cycle Min/Max Temperature:     21/34 Celsius
Lifetime    Min/Max Temperature:     20/47 Celsius
Under/Over Temperature Limit Count:   0/0
Vendor specific:
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 5a 01 00 00 00 00 00 00 00 00 00 00 00 00
SCT Temperature History Version:     2
Temperature Sampling Period:         3 minutes
Temperature Logging Interval:        59 minutes
Min/Max recommended Temperature:     10/40 Celsius
Min/Max Temperature Limit:            5/60 Celsius
Temperature History Size (Index):    128 (56)
Index    Estimated Time   Temperature Celsius
  57    2025-02-15 15:33    38  *******************
  58    2025-02-15 16:32    37  ******************
 ...    ..(  7 skipped).    ..  ******************
  66    2025-02-16 00:24    37  ******************
  67    2025-02-16 01:23    36  *****************
 ...    ..( 20 skipped).    ..  *****************
  88    2025-02-16 22:02    36  *****************
  89    2025-02-16 23:01    37  ******************
  90    2025-02-17 00:00    37  ******************
  91    2025-02-17 00:59    37  ******************
  92    2025-02-17 01:58    41  **********************
  93    2025-02-17 02:57    43  ************************
  94    2025-02-17 03:56    44  *************************
  95    2025-02-17 04:55    44  *************************
  96    2025-02-17 05:54    43  ************************
  97    2025-02-17 06:53    43  ************************
  98    2025-02-17 07:52    43  ************************
  99    2025-02-17 08:51    44  *************************
 100    2025-02-17 09:50    44  *************************
 101    2025-02-17 10:49    39  ********************
 ...    ..(  7 skipped).    ..  ********************
 109    2025-02-17 18:41    39  ********************
 110    2025-02-17 19:40     ?  -
 111    2025-02-17 20:39    21  **
 112    2025-02-17 21:38     ?  -
 113    2025-02-17 22:37    25  ******
 114    2025-02-17 23:36     ?  -
 115    2025-02-18 00:35    27  ********
 116    2025-02-18 01:34     ?  -
 117    2025-02-18 02:33    23  ****
 118    2025-02-18 03:32     ?  -
 119    2025-02-18 04:31    22  ***
 120    2025-02-18 05:30     ?  -
 121    2025-02-18 06:29    23  ****
 122    2025-02-18 07:28     ?  -
 123    2025-02-18 08:27    23  ****
 124    2025-02-18 09:26     ?  -
 125    2025-02-18 10:25    24  *****
 126    2025-02-18 11:24     ?  -
 127    2025-02-18 12:23    24  *****
   0    2025-02-18 13:22     ?  -
   1    2025-02-18 14:21    25  ******
   2    2025-02-18 15:20     ?  -
   3    2025-02-18 16:19    26  *******
   4    2025-02-18 17:18     ?  -
   5    2025-02-18 18:17    24  *****
   6    2025-02-18 19:16    33  **************
 ...    ..(  2 skipped).    ..  **************
   9    2025-02-18 22:13    33  **************
  10    2025-02-18 23:12     ?  -
  11    2025-02-19 00:11    33  **************
  14    2025-02-19 03:08    33  **************
  15    2025-02-19 04:07     ?  -
  16    2025-02-19 05:06    33  **************
  17    2025-02-19 06:05     ?  -
  18    2025-02-19 07:04    33  **************
  21    2025-02-19 10:01    33  **************
  22    2025-02-19 11:00    32  *************
 ...    ..(  3 skipped).    ..  *************
  26    2025-02-19 14:56    32  *************
  27    2025-02-19 15:55    33  **************
  30    2025-02-19 18:52    33  **************
  31    2025-02-19 19:51    34  ***************
  32    2025-02-19 20:50    33  **************
  33    2025-02-19 21:49    34  ***************
  34    2025-02-19 22:48    33  **************
 ...    ..(  6 skipped).    ..  **************
  41    2025-02-20 05:41    33  **************
  42    2025-02-20 06:40    32  *************
 ...    ..(  5 skipped).    ..  *************
  48    2025-02-20 12:34    32  *************
  49    2025-02-20 13:33    31  ************
  50    2025-02-20 14:32    32  *************
  51    2025-02-20 15:31    33  **************
  52    2025-02-20 16:30    33  **************
  53    2025-02-20 17:29     ?  -
  54    2025-02-20 18:28    26  *******
  55    2025-02-20 19:27     ?  -
  56    2025-02-20 20:26    21  **
SCT Error Recovery Control:
           Read:     40 (4.0 seconds)
          Write:     40 (4.0 seconds)
Device Statistics (GP Log 0x04)
Page  Offset Size        Value Flags Description
0x01  =====  =               =  ===  == General Statistics (rev 1) ==
0x01  0x008  4              31  ---  Lifetime Power-On Resets
0x01  0x010  4            2898  ---  Power-on Hours
0x01  0x018  6     19498050813  ---  Logical Sectors Written
0x01  0x020  6        99525469  ---  Number of Write Commands
0x01  0x028  6     48170650288  ---  Logical Sectors Read
0x01  0x030  6        48126654  ---  Number of Read Commands
0x01  0x038  6               -  ---  Date and Time TimeStamp
0x03  =====  =               =  ===  == Rotating Media Statistics (rev 1) ==
0x03  0x008  4      3370283146  N--  Spindle Motor Power-on Hours
0x03  0x010  4      3370283146  N--  Head Flying Hours
0x03  0x018  4             148  ---  Head Load Events
0x03  0x020  4               0  ---  Number of Reallocated Logical Sectors
0x03  0x028  4               0  ---  Read Recovery Attempts
0x03  0x030  4               0  ---  Number of Mechanical Start Failures
0x03  0x038  4               0  ---  Number of Realloc. Candidate Logical Sectors
0x03  0x040  4             125  ---  Number of High Priority Unload Events
0x04  =====  =               =  ===  == General Errors Statistics (rev 1) ==
0x04  0x008  4               0  ---  Number of Reported Uncorrectable Errors
0x04  0x010  4               0  ---  Resets Between Cmd Acceptance and Completion
0x05  =====  =               =  ===  == Temperature Statistics (rev 1) ==
0x05  0x008  1              34  ---  Current Temperature
0x05  0x010  1              32  ---  Average Short Term Temperature
0x05  0x018  1              37  ---  Average Long Term Temperature
0x05  0x020  1              47  ---  Highest Temperature
0x05  0x028  1              27  ---  Lowest Temperature
0x05  0x030  1              43  ---  Highest Average Short Term Temperature
0x05  0x038  1              32  ---  Lowest Average Short Term Temperature
0x05  0x040  1              40  ---  Highest Average Long Term Temperature
0x05  0x048  1              37  ---  Lowest Average Long Term Temperature
0x05  0x050  4               0  ---  Time in Over-Temperature
0x05  0x058  1              60  ---  Specified Maximum Operating Temperature
0x05  0x060  4               0  ---  Time in Under-Temperature
0x05  0x068  1               5  ---  Specified Minimum Operating Temperature
0x06  =====  =               =  ===  == Transport Statistics (rev 1) ==
0x06  0x008  4             124  ---  Number of Hardware Resets
0x06  0x010  4              76  ---  Number of ASR Events
0x06  0x018  4               0  ---  Number of Interface CRC Errors
0xff  =====  =               =  ===  == Vendor Specific Statistics (rev 1) ==
0xff  0x008  7               0  ---  Vendor Specific
0xff  0x018  7               0  ---  Vendor Specific
                                |||_ C monitored condition met
                                ||__ D supports DSN
                                |___ N normalized value
Pending Defects log (GP Log 0x0c)
No Defects Logged
SATA Phy Event Counters (GP Log 0x11)
ID      Size     Value  Description
0x000a  2            1  Device-to-host register FISes sent due to a COMRESET
0x0001  2            0  Command failed due to ICRC error
0x0003  2            0  R_ERR response for device-to-host data FIS
0x0004  2            0  R_ERR response for host-to-device data FIS
0x0006  2            0  R_ERR response for device-to-host non-data FIS
0x0007  2            0  R_ERR response for host-to-device non-data FIS
root@truenas[~]# smartctl -l selftest /dev/sdb
smartctl -l error /dev/sdb
smartctl -x /dev/sdb                                                        smartctl 7.2 2020-12-30 r5155 [x86_64-linux-5.15.131+truenas] (local build)
# 3  Extended offline    Completed without error       00%        24         -
No Errors Logged
Serial Number:    ZJV4YHA1
LU WWN Device Id: 5 000c50 0b614737a
Local Time is:    Thu Feb 20 20:31:50 2025 EST
                                        been run.
                                        command.
                                        power-saving mode.
recommended polling time:        (1088) minutes.
  1 Raw_Read_Error_Rate     POSR--   080   064   044    -    96752247
  3 Spin_Up_Time            PO----   091   090   000    -    0
  4 Start_Stop_Count        -O--CK   100   100   020    -    36
  7 Seek_Error_Rate         POSR--   080   060   045    -    89915664
  9 Power_On_Hours          -O--CK   097   097   000    -    2929
 12 Power_Cycle_Count       -O--CK   100   100   020    -    33
190 Airflow_Temperature_Cel -O---K   065   049   040    -    35 (Min/Max 29/35)
192 Power-Off_Retract_Count -O--CK   100   100   000    -    121
193 Load_Cycle_Count        -O--CK   100   100   000    -    153
194 Temperature_Celsius     -O---K   035   051   000    -    35 (0 20 0 0 0)
195 Hardware_ECC_Recovered  -O-RC-   009   006   000    -    96752247
240 Head_Flying_Hours       ------   100   253   000    -    2898 (41 172 0)
241 Total_LBAs_Written      ------   100   253   000    -    19506750705
242 Total_LBAs_Read         ------   100   253   000    -    71537044894
                            ||||||_ K auto-keep
                            |||||__ C event count
                            ||||___ R error rate
No Errors Logged
Power Cycle Min/Max Temperature:     29/34 Celsius
Lifetime    Min/Max Temperature:     20/51 Celsius
Vendor specific:
00 00 5d 01 00 00 00 00 00 00 00 00 00 00 00 00
Temperature History Size (Index):    128 (90)
  91    2025-02-15 15:33    36  *****************
  92    2025-02-15 16:32    39  ********************
  93    2025-02-15 17:31    42  ***********************
 ...    ..(  4 skipped).    ..  ***********************
  98    2025-02-15 22:26    42  ***********************
  99    2025-02-15 23:25    43  ************************
 100    2025-02-16 00:24    42  ***********************
 101    2025-02-16 01:23    38  *******************
 109    2025-02-16 09:15    38  *******************
 110    2025-02-16 10:14     ?  -
 111    2025-02-16 11:13    21  **
 112    2025-02-16 12:12     ?  -
 113    2025-02-16 13:11    25  ******
 114    2025-02-16 14:10     ?  -
 115    2025-02-16 15:09    28  *********
 116    2025-02-16 16:08     ?  -
 117    2025-02-16 17:07    24  *****
 118    2025-02-16 18:06     ?  -
 119    2025-02-16 19:05    22  ***
 120    2025-02-16 20:04     ?  -
 121    2025-02-16 21:03    23  ****
 122    2025-02-16 22:02     ?  -
 123    2025-02-16 23:01    23  ****
 124    2025-02-17 00:00     ?  -
 125    2025-02-17 00:59    24  *****
 126    2025-02-17 01:58     ?  -
 127    2025-02-17 02:57    24  *****
   0    2025-02-17 03:56     ?  -
   1    2025-02-17 04:55    25  ******
   2    2025-02-17 05:54     ?  -
   3    2025-02-17 06:53    26  *******
   4    2025-02-17 07:52     ?  -
   5    2025-02-17 08:51    25  ******
   6    2025-02-17 09:50    33  **************
   7    2025-02-17 10:49    34  ***************
   8    2025-02-17 11:48    33  **************
   9    2025-02-17 12:47    34  ***************
  10    2025-02-17 13:46     ?  -
  11    2025-02-17 14:45    34  ***************
 ...    ..(  2 skipped).    ..  ***************
  14    2025-02-17 17:42    34  ***************
  15    2025-02-17 18:41     ?  -
  16    2025-02-17 19:40    33  **************
  17    2025-02-17 20:39     ?  -
  18    2025-02-17 21:38    33  **************
  19    2025-02-17 22:37    34  ***************
  20    2025-02-17 23:36    34  ***************
  21    2025-02-18 00:35    33  **************
  24    2025-02-18 03:32    33  **************
  25    2025-02-18 04:31    32  *************
  26    2025-02-18 05:30    33  **************
  27    2025-02-18 06:29    33  **************
  28    2025-02-18 07:28    34  ***************
 ...    ..(  6 skipped).    ..  ***************
  35    2025-02-18 14:21    34  ***************
  36    2025-02-18 15:20    33  **************
  43    2025-02-18 22:13    33  **************
  44    2025-02-18 23:12    32  *************
  49    2025-02-19 04:07    32  *************
  50    2025-02-19 05:06    33  **************
  51    2025-02-19 06:05    33  **************
  52    2025-02-19 07:04    34  ***************
  53    2025-02-19 08:03     ?  -
  54    2025-02-19 09:02    33  **************
  55    2025-02-19 10:01     ?  -
  56    2025-02-19 11:00    38  *******************
  57    2025-02-19 11:59     ?  -
  58    2025-02-19 12:58    30  ***********
  59    2025-02-19 13:57    49  ******************************
  60    2025-02-19 14:56    51  ********************************
 ...    ..(  2 skipped).    ..  ********************************
  63    2025-02-19 17:53    51  ********************************
  64    2025-02-19 18:52    50  *******************************
  65    2025-02-19 19:51    50  *******************************
  66    2025-02-19 20:50    49  ******************************
 ...    ..(  4 skipped).    ..  ******************************
  71    2025-02-20 01:45    49  ******************************
  72    2025-02-20 02:44    48  *****************************
  73    2025-02-20 03:43    48  *****************************
  74    2025-02-20 04:42    48  *****************************
  75    2025-02-20 05:41    47  ****************************
  76    2025-02-20 06:40    33  **************
  77    2025-02-20 07:39    29  **********
  78    2025-02-20 08:38    28  *********
  79    2025-02-20 09:37    27  ********
  80    2025-02-20 10:36    27  ********
  81    2025-02-20 11:35    27  ********
  82    2025-02-20 12:34    28  *********
  83    2025-02-20 13:33    29  **********
  86    2025-02-20 16:30    29  **********
  87    2025-02-20 17:29    28  *********
  88    2025-02-20 18:28    28  *********
  89    2025-02-20 19:27     ?  -
  90    2025-02-20 20:26    29  **********
0x01  0x008  4              33  ---  Lifetime Power-On Resets
0x01  0x010  4            2929  ---  Power-on Hours
0x01  0x018  6     19506443785  ---  Logical Sectors Written
0x01  0x020  6        99326232  ---  Number of Write Commands
0x01  0x028  6     71537041164  ---  Logical Sectors Read
0x01  0x030  6       128367641  ---  Number of Read Commands
0x03  0x008  4       851180754  N--  Spindle Motor Power-on Hours
0x03  0x010  4       851180754  N--  Head Flying Hours
0x03  0x018  4             153  ---  Head Load Events
0x03  0x040  4             121  ---  Number of High Priority Unload Events
0x05  0x010  1              40  ---  Average Short Term Temperature
0x05  0x018  1              36  ---  Average Long Term Temperature
0x05  0x020  1              51  ---  Highest Temperature
0x05  0x038  1              33  ---  Lowest Average Short Term Temperature
0x05  0x048  1              36  ---  Lowest Average Long Term Temperature
0x06  0x008  4             132  ---  Number of Hardware Resets
0x06  0x010  4              88  ---  Number of ASR Events
                                ||__ D supports DSN
No Defects Logged
0x000a  2            2  Device-to-host register FISes sent due to a COMRESET
Nothing looks out of the ordinary.
With the zdb tool, and someone who is more savvy, they might be able to help figure this out.
My only other “quick” test is to boot into an Ubuntu 24.10 live ISO from a USB stick, and see if the command zpool import -d /dev/disk/by-partuuid detects an available pool to import.
This can maybe rule out TrueNAS.
EDIT: Don’t actually import or mount anything. You’re only testing to see if it can detect an importable pool from a clean Ubuntu 24.10 environment.
with respect to your expertise, i’ve tried the zpool imports thru ubuntu prior to coming to the forums and it returned “no pool available” as well
Then it leaves this:
sounds intimidating and very unfortunate that my issue is deeper than “surface level” all due to a random unknown restart.
im hoping and praying for some support to recover the data. unlucky me for the incident, but lucky me for the forum members support
Forgot to ask. There is no Proxmox or hypervisor or VM involved? Pure bare metal PC with TrueNAS installed directly on it?
correct, just a PC with TrueNAS as the OS
reading upon some of the deeper zdb commands - i should be doing a backup of the disks? in their unreadable state?
do i need to back up both? or only 1 of them since they’re mirrored? I have an uninitialized external harddrive thats 14TB - not sure if i can back up both sda and sdb if they’re 12TB (10.9T)
At this point, we may as well tag @HoneyBadger :pray:
I tested these commands on my own SCALE system before recommending them. I have no idea why it doesn’t work on your SCALE system.
Actually yes, it is very useful. The START sector of the partition is not essential. This shows that the disks for the missing pool are visible to Linux, and that the ZFS partitions exist and have partuuids.
However ZFS is unable to find and import the disks for some reason. Please run:
  • sudo zpool import -d /dev/disk/by-partuuid
and post the results here.
really unsure why everything is returning no pools available. it returns as follows
root@truenas[~]# sudo zpool import -d /dev/disk/by-partuuid
no pools available to import
@honeybadger Are you able to help?
:sweat_smile: I really appreciate everyone’s help. My optimism is undoubtedly fading. Things looking dire? Are my options running out?
I would assume that the data is on the disk somewhere just inaccessible
Be optimistic - I could probably make a guess at the command you need to try, but rather than hoping I get it right you would probably be better off waiting to see if Chris can help with less guesswork and more expertise.
